  3. Happy Standby Node :)
3 Posts 2 Posters 2.0k Views 2 Watching
  • berkseoB Offline
    berkseoB Offline
    berkseo
    turn off your gateway and try..
    bool flag_find_parent = 0;
    bool flag_find_parent_process = 0;
    bool q = 0;
    bool flag_nogateway_mode = 0;
    bool flag_no_present = 0;
    bool flag_update_transport_param = 0;
    bool Ack_HB;
    bool Ack_FP;
    bool bin = 0;
    byte mypar;
    byte myid;
    byte mydis;
    byte err_delivery_beat;
    byte friend_node = 10;
    word mtwr;
    unsigned long interval_hb = 0;
    unsigned long interval_friend_node = 0;
    unsigned long interval_find_parent = 0;
    unsigned int  sec_interval_hb = 15000;
    unsigned int  sec_interval_friend_node = 10000;
    unsigned int  sec_interval_find_parent = 5000;
    #define MY_TRANSPORT_WAIT_READY_MS (mtwr)
    #define CHILD_ID 0
    #define CHILD_ID_1 1
    MyMessage msg(CHILD_ID, V_TEMP);
    MyMessage msg_to_friend(CHILD_ID_1, V_STATUS);
    void before() {
      if (hwReadConfig(EEPROM_NODE_ID_ADDRESS) == 0) {
        hwWriteConfig(EEPROM_NODE_ID_ADDRESS, 255);
      if (hwReadConfig(EEPROM_NODE_ID_ADDRESS) == 255) {
        mtwr = 0;
        mtwr = 30000;
      sendSketchInfo("Happy Standby Node", "1.01");
      present(CHILD_ID, S_TEMP);
      myid = getNodeId();
      if (isTransportReady() == true) {
        mydis = _transportConfig.distanceGW;
        mypar = _transportConfig.parentNodeId;
        loadState(103);
        if (mydis != loadState(103))
          saveState(103, mydis);
        if (mypar != loadState(101))
          saveState(101, mypar);
      if (isTransportReady() == false)
        CORE_DEBUG(PSTR("MyS: STANDBY TRANSPORT MODE\n"));
        no_present();
        happy_node_mode();
        gateway_fail();
        err_delivery_beat = 3;
      interval_friend_node = millis();
      interval_hb = millis();
        if (millis() - interval_friend_node > sec_interval_friend_node)    {
          _transportConfig.parentNodeId = friend_node;
          bin = !bin;
          bool friend_sent = send(msg_to_friend.setDestination(friend_node).set(bin));
          if (friend_sent == 1) {
            _transportConfig.parentNodeId = mypar;
            _transportSM.failedUplinkTransmissions = 0;
        if (flag_nogateway_mode == 0) {
          if (flag_find_parent_process == 1) {
            flag_update_transport_param = 1;
            CORE_DEBUG(PSTR("MyS: STANDART TRANSPORT MODE IS RESTORED\n"));
          if (millis() - interval_hb > sec_interval_hb)    {
            send_to_gateway();
        if (flag_update_transport_param == 1) {
          CORE_DEBUG(PSTR("MyS: UPDATE TRANSPORT CONFIGURATION\n"));
          loadState(103);
          if (flag_no_present == 1) {
            CORE_DEBUG(PSTR("MyS: SEND PRESENTATION AFTER RESTORING STANDART TRANSPORT MODE \n"));
            presentNode();
            wait(1000);
            send_to_gateway();
            CORE_DEBUG(PSTR("MyS: SEND LITTLE PRESENT:) WITH PARENT ID IN CONTRILER AFTER RESTORING STANDART TRANSPORT MODE \n"));
            present_only_parent();
            wait(1000);
            send_to_gateway();
      if (_transportSM.failureCounter > 0) {
        happy_node_mode();
        gateway_fail();
      if (flag_nogateway_mode == 1) {
        if (millis() - interval_find_parent > sec_interval_find_parent)    {
          check_parent();
          interval_find_parent = millis();
      if (q == 1) {
        if (_msg.sensor == 255) {
          if (mGetCommand(_msg) == 3) {
            if (_msg.type == 8) {
              Ack_FP = 1;
              CORE_DEBUG(PSTR("MyS: PARENT RESPONSE FOUND\n"));
        if (Ack_FP == 1) {
          CORE_DEBUG(PSTR("MyS: FIND PARENT PROCESS\n"));
          q = 0;
          Ack_FP = 0;
          transportSwitchSM(stParent);
          flag_find_parent_process = 1;
          _transportSM.findingParentNode = false;
          q = 0;
          CORE_DEBUG(PSTR("MyS: PARENT RESPONSE NOT FOUND\n"));
    void receive(const MyMessage & message) {
      if (message.isAck()) {
        if (message.sensor == 0) {
          if (message.type == 0) {
            Ack_HB = 1;
    void update_parent() {
      _sendRoute(build(_msgTmp, 0, NODE_SENSOR_ID, 3, 6).set(mypar));
      wait(1000, 3, 6);
    void no_present() {
      _coreConfig.presentationSent = true;
      _coreConfig.nodeRegistered = true;
      flag_no_present = 1;
    void happy_node_mode() {
      _transportConfig.nodeId = myid;
      _transportConfig.parentNodeId = loadState(101);
      _transportConfig.distanceGW = loadState(103);
      _transportSM.transportActive = true;
      _transportSM.uplinkOk = true;
      _transportSM.pingActive = false;
      transportSwitchSM(stReady);
      _transportSM.failureCounter = 0;
    void gateway_fail() {
      flag_nogateway_mode = 1;
    void check_parent() {
      q = 1;
      _transportSM.findingParentNode = true;
      CORE_DEBUG(PSTR("MyS: SEND FIND PARENT REQUEST, WAIT RESPONSE\n"));
      _sendRoute(build(_msg, 255, NODE_SENSOR_ID, 3, 7).set(""));
      wait(3000, 3, 8);
    void present_only_parent() {
      wait(1000, 3, 6);
    void send_to_gateway () {
      send(msg.set(25.0 + random(0, 30) / 10.0, 2), 1);
      wait(2000, 1, 0);
      if (Ack_HB == 0) {
        if (err_delivery_beat < 3) {
          err_delivery_beat++;
        if (err_delivery_beat == 2) {
          gateway_fail();
          CORE_DEBUG(PSTR("MyS: LOST GATEWAY MODE\n"));
        Ack_HB = 0;
        err_delivery_beat = 0;
    • CrankyCoderC Offline
      CrankyCoder
      could you provide a quick summary of what this does?
      Home Automation Tinkerer
      www.CrankyCoder.net
      Gateway: MQTTClientGateway
      MySensors: 2.3
      berkseoB 1 Reply Last reply
      • CrankyCoderC CrankyCoder
        berkseoB Offline
        berkseoB Offline
        berkseo
        @crankycoder https://translate.google.com/translate?sl=ru&tl=en&js=y&prev=_t&hl=ru&ie=UTF-8&u=http%3A%2F%2Fmysensors.ru%2Fforum%2Fviewtopic.php%3Ff%3D5%26t%3D380&edit-text=
