  3. 2.4Ghz RF Module for new users [2018]
9 Posts 3 Posters 2.8k Views 4 Watching
  • P Offline
    P Offline
    Prakhar Birla
    wrote on last edited by Prakhar Birla
    Hello All,
    I am new to MySensors and have decided to use this platform for creating a sensor network to monitor greenhouse crops. I have spent a fair bit of time reading the forums and the website. I am still undecided about which RF Module (& supplier) to use.
    I'm based in India, we have a non standard ISM band allocation so 868 & 915Mhz are not available for public use while 433 requires a HAM radio licence to operate which leaves only 2.4Ghz.
    There has been lots of discussions on problems with NRF24 clones, and now there are the new NRF51 & Nrf52 ICs that don't need a separate MCU which I want to avoid atm because it's new hardware with much to learn.
    I have listed down the ebyte red modules and one with a SMA connector for the gateway along with the itead nrf24l01+ modules.
    Which to use to have a stable sensor network?
    Sorry for the long post l
    J 1 Reply Last reply
    • alowhumA Offline
      alowhumA Offline
      alowhum
      The red eByte modules are a good choice.
      P 1 Reply Last reply
      • P Prakhar Birla
        Hello All,
        J Offline
        J Offline
        jkandasa
        @prakhar-birla Hi I too from India. Recently I have pushed a PR to use India standard for RFM69. You may have a look at https://github.com/mysensors/MySensors/issues/1184
        • alowhumA alowhum
          P Offline
          P Offline
          Prakhar Birla
          @alowhum said in 2.4Ghz RF Module for new users [2018]:
          Great, will order a bunch of those. Thanks for sharing your experience.
          For the gateway should I use the same chip or a different eByte with an external antenna?
          • J jkandasa
            P Offline
            P Offline
            Prakhar Birla
            @jkandasa said in 2.4Ghz RF Module for new users [2018]:
            Hello! This a great, I didn't bother checking the range in the data sheet. Now I need to get some RFM69 ones too. Are you using any yourself?
            • P Prakhar Birla
              J Offline
              J Offline
              jkandasa
              @prakhar-birla Yes, I am using in my house. I see a good range between concrete walls.
              I was using NRF24L01+ Chinese version and was facing range issue. I used to have Gateway for each floor.
              But now only single gateway with RFM69HW.
              I have replaced RFM69HW with NRF24L01+ couple of weeks ago. I am just experimenting with coverage with RFM69HW. So far I do not face any issue.
              • J jkandasa
                P Offline
                P Offline
                Prakhar Birla
                @jkandasa Thanks for sharing! Which vendor do you buy from?
                • alowhumA Offline
                  alowhumA Offline
                  alowhum
                  @Prakhar-Birla for the gateway get the ebyte PA LNA module. It's more powerful. It's also shielded, which you really need.
                  RFM69 is the better option overall. More range, and using a less crowded band (433mhz). But it's more difficult to connect the hardware (in my opinion).
                  The NRF24 units can be plug and play if you buy the Arduino Nano Wireless Board. I build all my nodes that way. But if you want to go for battery power, using that board might not be your best choice.
                  • P Prakhar Birla
                    J Offline
                    J Offline
                    jkandasa
                    @prakhar-birla I do buy in Aliexpress, you can see some of the links in https://www.mysensors.org/build/connect_radio
