  3. MY_SOFTSPI on Sensebender-Micro Derivate
3 Posts 2 Posters 961 Views 1 Watching
    marcoMD
    wrote on last edited by marcoMD
    The Background
    I have a simple question regarding the MY_SOFTSPI functionality. I designed my own pcb for a Sensebender Micro derviate that is utilizing a ATMEGA328-MMH chip (the 4x4mm SMD version) and mainly 0402 SMD parts.
    Here some impressions:
    The PCBs are equipped with both footprints for the DIP and the SMD version of the NRF24 modules. However, I made a stupic mistake when wiring the SMD footprint and swapped the MISO and SCK connections.
    Here the thing (grrrrrr):
    The Issue
    I hoped to resolve this stupid mistake with these lines of code to swap the connections again:
    #define   MY_SOFTSPI
    #define   MY_SOFT_SPI_SCK_PIN    12
    #define   MY_SOFT_SPI_MISO_PIN   13
    #define   MY_SOFT_SPI_MOSI_PIN   11
    ... but it doesn't work out.
    The serial outputs is:
     __  __       ____
    16 MCO:BGN:INIT NODE,CP=RNNNA---,VER=2.3.0
    26 TSM:INIT
    28 TSF:WUR:MS=0
    34 !TSM:INIT:TSP FAIL
    36 TSM:FAIL:CNT=1
    38 TSM:FAIL:DIS
    40 TSF:TDI:TSL
    10045 TSM:FAIL:RE-INIT
    10047 TSM:INIT
    10053 !TSM:INIT:TSP FAIL
    10057 TSM:FAIL:CNT=2
    10059 TSM:FAIL:DIS
    10061 TSF:TDI:TSL
    If I unsolder the NRF24-SMD version, plug the DIP version in (edit: and modify the code so that the hardware-SPI is used again), it is working instantly.
    So my guess is that it is not possible to use the native SPI pins as softSPI pins. Is this correct?
    Regards from cold Germany,
    Marco
      never tried this way, but I don't see why it wouldn't work. it's software spi..
      Maybe show us your sketch, and add this define, so you can check in logs which pins are really used by the radio driver
      #define MY_DEBUG_VERBOSE_RF24
      imho, hardware spi is always preferable, so I would have fixed it the other way, like cutting traces and soldering thin wires to get it working again
        marcoMD
        Hi @scalz ,
        thanks for the rapid reaction. Sure. Let's try this.
        Here is my code:
        /* --- Bathroom Environment Data Logging Node --- */
        // +-+-+-+-+-+-+-+-+ DECLARATION +-+-+-+-+-+-+-+-+
        // --- MYSENSORS DEFINITIONS ---
        // sketch
        #define SKETCH_NAME        "EnvBad"
        #define SKETCH_VERSION     "1.1"
        // debug prints
        #define MY_BAUD_RATE              (115200)
        // soft SPI settings
        #define   MY_SOFTSPI
        #define   MY_SOFT_SPI_SCK_PIN     12 // (usually at pin 13)
        #define   MY_SOFT_SPI_MISO_PIN    13 //(usually at pin 12)
        // NRF24
        #define MY_RF24_PA_LEVEL          (RF24_PA_HIGH)
        #define MY_RF24_CE_PIN            9
        #define MY_RF24_CS_PIN            10
        #define MY_RF24_IRQ_PIN           2   // need to be enabled using the solder jumper at the top side of the PCB
        // LEDs
        #define MY_DEFAULT_TX_LED_PIN     6
        #define MY_DEFAULT_RX_LED_PIN     5
        #define MY_DEFAULT_ERR_LED_PIN    7
        // node ID
        #define MY_NODE_ID                (100)
        // child IDs
        #define CHILD_ID_TEMPERATURE      (0)
        #define CHILD_ID_HUMIDITY         (1)
        #define CHILD_ID_LIGHT            (2)
        // --- CONSTANTS ---
        // pin definitions
        const uint8_t phResistorEnPin = 4;
        const uint8_t PHOTO_RESISTOR_PIN = A0 ;
        // Timing constants
        const uint32_t ENV_VARS_CHECK_PERIOD_MS = 60UL*1000UL;
        const uint32_t LIGHT_CHECK_PERIOD_MS = 1UL*1000UL;
        // --- LIBRARIES ---
        #include <SHT3x.h>            // temp and humidity sensor
        // --- Objects
        SHT3x Sensor;
        //                                S E T U P
          Serial.println(F("-- " SKETCH_NAME " " SKETCH_VERSION));
          Sensor.Begin();
        //                                L O O P
          float tSHT;
          float hSHT;
          static uint8_t lightLev = 0, lightLevPrev = 200;
          static uint32_t t1 = millis(), t2 = 0;
          readPhRest(&lightLev);
          if ( abs(lightLevPrev - lightLev) >= 2 ) {
            lightLevPrev = lightLev;
            send( MyMessage(CHILD_ID_LIGHT,           V_LIGHT_LEVEL).set(lightLev) );
          if ( t2 - t1 >= ENV_VARS_CHECK_PERIOD_MS ) {
            readSHT3x(&tSHT, &hSHT);
            send( MyMessage(CHILD_ID_TEMPERATURE,     V_TEMP).set(double(tSHT), 2 /*#decimals*/) );
            send( MyMessage(CHILD_ID_HUMIDITY,        V_HUM).set(double(hSHT), 2 /*#decimals*/) );
            t1 = t2;
          wait(LIGHT_CHECK_PERIOD_MS);
          t2 = millis();
        //                      SUB - ROUTINES
        // ----------------------- presentation --------------------------
          Serial.println(F("-- Init MySensors"));
          Serial.print(F("NodeID: "));
          Serial.println(getNodeId());
          present(CHILD_ID_TEMPERATURE,     S_TEMP,         "Bad_Temp");
          present(CHILD_ID_HUMIDITY,        S_HUM,          "Bad_LuFeu");
          present(CHILD_ID_LIGHT,           S_LIGHT_LEVEL,  "Bad_Hell");
        // ----------------------- readSHT3x --------------------------
        void readSHT3x(float *_tSHT, float *_hSHT){
          Sensor.UpdateData();
          *_tSHT = Sensor.GetTemperature();
          *_hSHT = Sensor.GetRelHumidity();
          Serial.print("Temperature: ");
          Serial.print(*_tSHT);
          Serial.write("\xC2\xB0"); //The Degree symbol
          Serial.println("C");
          Serial.print("Humidity: ");
          Serial.print(*_hSHT);
          Serial.println("%");
        // ----------------------- readPhRest --------------------------
        void readPhRest(uint8_t *_lLevel) {
          pinMode(phResistorEnPin,OUTPUT);
          digitalWrite(phResistorEnPin,LOW);
          *_lLevel = 100 - (uint8_t) ( ( (float)analogRead(PHOTO_RESISTOR_PIN) /10.24 ) + 0.5 ) ;
          pinMode(phResistorEnPin,INPUT);
          Serial.print  ("PhotoResistor: ");
          Serial.print  (*_lLevel);
          Serial.println();
        and here my debug print:
         __  __       ____
        26 TSM:INIT
        28 TSF:WUR:MS=0
        30 RF24:INIT
        30 RF24:INIT:PIN,CE=9,CS=10
        34 RF24:WBR:REG=0,VAL=14
        43 RF24:WBR:REG=3,VAL=3
        45 RF24:WBR:REG=4,VAL=95
        47 RF24:WBR:REG=5,VAL=76
        49 RF24:WBR:REG=6,VAL=37
        53 RF24:WBR:REG=16,VAL=115
        55 RF24:WBR:REG=29,VAL=4
        57 RF24:RBR:REG=6,VAL=0
        61 !RF24:INIT:SANCHK FAIL
        63 !TSM:INIT:TSP FAIL
        65 TSM:FAIL:CNT=1
        67 TSM:FAIL:DIS
        69 TSF:TDI:TSL
        71 RF24:SLP
        71 RF24:WBR:REG=0,VAL=12
        10074 TSM:FAIL:RE-INIT
        10076 TSM:INIT
        10078 RF24:INIT
        10080 RF24:INIT:PIN,CE=9,CS=10
        10082 RF24:WBR:REG=0,VAL=14
        10090 RF24:WBR:REG=3,VAL=3
        10092 RF24:WBR:REG=4,VAL=95
        10096 RF24:WBR:REG=5,VAL=76
        10098 RF24:WBR:REG=6,VAL=37
        10102 RF24:WBR:REG=16,VAL=115
        10104 RF24:WBR:REG=29,VAL=4
        10108 RF24:RBR:REG=6,VAL=0
        10110 !RF24:INIT:SANCHK FAIL
        10115 !TSM:INIT:TSP FAIL
        10117 TSM:FAIL:CNT=2
        10119 TSM:FAIL:DIS
        10121 TSF:TDI:TSL
        10123 RF24:SLP
        10125 RF24:WBR:REG=0,VAL=12
        Moreover, I tried to re-programm an otherwise well-performing node (one with a DIP NRF24) by adding these lines to the program:
        #define   MY_SOFTSPI
        #define   MY_SOFT_SPI_SCK_PIN     13
        #define   MY_SOFT_SPI_MISO_PIN    12
        ... and i got identical errors. So it really might be a limit of the softSPI to not use the hardware SPI pins.
        And considering the hint with the manual rewiring: Well, yes, I would consider this for one board but I want to deploy between 15 and 20 of those boards in our flat for varios types of sensors. I guess if software can't fix it I would bite the bullet an order a new PCB pile.
        Regards....
