  3. Adafruit RFM69HCW Raspberry Gateway issue
2 Posts 1 Posters 829 Views 1 Watching
  • T
    tchoblond59
    wrote on last edited by tchoblond59
    Hi guys,
    I buy several things from adafruit
    RFM69HCW
    Feather 32u4 RFM
    Both in 915Mhz.
    I can run RelayActuator example from MySensors with this define
    #define MY_RADIO_RFM69
    #define MY_RFM69_FREQUENCY RFM69_915MHZ // Set your frequency here
    #define MY_IS_RFM69HW // Omit if your RFM is not "H"
    #define MY_RFM69_CS_PIN 8
    #define MY_RFM69_IRQ_PIN 7
    #define MY_RFM69_IRQ_NUM 4
    #define MY_NODE_ID 55
    But it only works with the serial gateway on another feather 32u4.
    I try to run mqtt gateway on rpi but it doesn't works.
    RST pin on afadruit RFM69HCW is wiring to GND
    G0 (Di0) is on pin 22
    I compile mysgw with
    ./configure --my-transport=rfm69 --my-rfm69-frequency=915 --my-is-rfm69hw --my-gateway=mqtt --my-controller-ip-address=127.0.0.1 --my-mqtt-publish-topic-prefix=mysensors-out --my-mqtt-subscribe-topic-prefix=mysensors-in --my-mqtt-client-id=mygateway1
    Here is the debus log when i launch mysgw
    Jan 09 10:29:12 INFO  Starting gateway...
    Jan 09 10:29:12 INFO  Protocol version - 2.3.1
    Jan 09 10:29:12 DEBUG MCO:BGN:INIT GW,CP=RPNGL---,REL=255,VER=2.3.1
    Jan 09 10:29:12 DEBUG TSF:LRT:OK
    Jan 09 10:29:12 DEBUG TSM:INIT
    Jan 09 10:29:12 DEBUG TSF:WUR:MS=0
    Jan 09 10:29:12 DEBUG TSM:INIT:TSP OK
    Jan 09 10:29:12 DEBUG TSM:INIT:GW MODE
    Jan 09 10:29:12 DEBUG TSM:READY:ID=0,PAR=0,DIS=0
    Jan 09 10:29:12 DEBUG MCO:REG:NOT NEEDED
    Jan 09 10:29:12 DEBUG MCO:BGN:STP
    Jan 09 10:29:12 DEBUG MCO:BGN:INIT OK,TSP=1
    Jan 09 10:29:12 DEBUG GWT:RMQ:MQTT RECONNECT
    Jan 09 10:29:12 DEBUG connected to 127.0.0.1
    Jan 09 10:29:12 DEBUG GWT:RMQ:MQTT CONNECTED
    Jan 09 10:29:12 DEBUG GWT:TPS:TOPIC=mysensors-out/0/255/0/0/18,MSG SENT
    Jan 09 10:29:12 DEBUG TSM:READY:NWD REQ
    Jan 09 10:29:12 DEBUG TSF:MSG:SEND,0-0-255-255,s=255,c=3,t=20,pt=0,l=0,sg=0,ft=0,st=OK:
    Jan 09 10:29:36 DEBUG GWT:IMQ:TOPIC=mysensors-in/55/1/1/0/2, MSG RECEIVED
    Jan 09 10:29:36 DEBUG !TSF:RTE:55 UNKNOWN
    Jan 09 10:29:37 DEBUG !TSF:MSG:SEND,0-0-55-55,s=1,c=1,t=2,pt=0,l=1,sg=0,ft=0,st=NACK:1
    I try to send via mqtt but always get NACK.
    Can someone help here ?
    T 1 Reply Last reply
    • T tchoblond59
      Hi guys,
      RFM69HCW
      Feather 32u4 RFM
      Both in 915Mhz.
      tchoblond59
      I finally solve it !
      I forget to add #define MY_RFM69_NEW_DRIVER on the arduino node side ! Now it seems working fine
