  3. Ethernet-MQTT GW problem
5 Posts 2 Posters 989 Views 2 Watching
  • MasMatM
    MasMatM
    MasMat
    wrote on last edited by MasMat
    I'm getting desperate with my gw. Two days ago a lightning blasted my house and MyS network. Gw destroyed, so I built a new one to figure out which nodes might be alive. I built an exact replica. The lightning also took out my network switch and router. Both bought new and are working well. New ethernet wires too.
    Below is my sketch for my gw, log output. The hardware is ProMini5V, W5100 module (with resistor on pins at bottom: https://forum.arduino.cc/index.php?topic=351477.msg3215306#msg3215306), NRF24+PA+LNA. And lots of caps and a voltage regulator mcp1700-3200.
    I have checked the parameters of my router and also checked with computer that ethernet lines actually work.
     * Version 1.0 - Henrik Ekblad
     * The W5100 MQTT gateway sends radio network (or locally attached sensors) data to your MQTT broker.
     * The node also listens to MY_MQTT_TOPIC_PREFIX and sends out those messages to the radio network
    #define MY_RADIO_RF24
    #define MY_MQTT_PUBLISH_TOPIC_PREFIX "domoticz/in/MyMQTT"
    #define MY_MQTT_SUBSCRIBE_TOPIC_PREFIX "domoticz/out/MyMQTT"
    // radio on the same spi bus.
    #define MY_SOFTSPI
    #ifndef MY_RF24_CE_PIN
    #define MY_RF24_CE_PIN 5
    #ifndef MY_RF24_CS_PIN
    #define MY_RF24_CS_PIN 6
    //#define MY_RF24_IRQ_PIN 2
    //#define MY_RX_MESSAGE_BUFFER_FEATURE
    #define MY_MQTT_USER "xxxxxxx"
    #define MY_MQTT_PASSWORD "yyyyyyyyy"
    #define MY_IP_ADDRESS 192,168,0,201
    //#define MY_MAC_ADDRESS 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED
    #define MY_IP_GATEWAY_ADDRESS 192,168,0,1      // Router IP
    #define MY_CONTROLLER_IP_ADDRESS 192, 168, 0, 100
    #define MY_PORT 1883
    // Enable inclusion mode
    // Set blinking period
    // Flash leds on rx/tx/err
    #include <Ethernet.h>
      sendSketchInfo("MQTT_GW2", "v13072019");
    MCO:BGN:INIT GW,CP=RNNGA---,REL=255,VER=2.3.1
    4 TSM:INIT
    5 TSF:WUR:MS=0
    11 TSM:INIT:TSP OK
    13 TSM:INIT:GW MODE
    15 TSM:READY:ID=0,PAR=0,DIS=0
    17 MCO:REG:NOT NEEDED
    579 GWT:TPC:IP=0.0.0.0
    1582 MCO:BGN:STP
    1584 MCO:BGN:INIT OK,TSP=1
    2146 GWT:TPC:IP=0.0.0.0
    3148 GWT:RMQ:MQTT RECONNECT
    3151 TSM:READY:NWD REQ
    3188 TSF:MSG:SEND,0-0-255-255,s=255,c=3,t=20,pt=0,l=0,sg=0,ft=0,st=OK:
    3756 GWT:TPC:IP=0.0.0.0
    4757 GWT:RMQ:MQTT RECONNECT
    5320 GWT:TPC:IP=0.0.0.0
    6323 GWT:RMQ:MQTT RECONNECT
    6886 GWT:TPC:IP=0.0.0.0
    7888 GWT:RMQ:MQTT RECONNECT
    8451 GWT:TPC:IP=0.0.0.0
    9453 GWT:RMQ:MQTT RECONNECT
    10016 GWT:TPC:IP=0.0.0.0
    11019 GWT:RMQ:MQTT RECONNECT
    11582 GWT:TPC:IP=0.0.0.0
    12583 GWT:RMQ:MQTT RECONNECT
    13147 GWT:TPC:IP=0.0.0.0
    14149 GWT:RMQ:MQTT RECONNECT
    14712 GWT:TPC:IP=0.0.0.0
    15715 GWT:RMQ:MQTT RECONNECT
    16278 GWT:TPC:IP=0.0.0.0
    17281 GWT:RMQ:MQTT RECONNECT
    17844 GWT:TPC:IP=0.0.0.0
    18846 GWT:RMQ:MQTT RECONNECT
    Also I have checked my connections three times. And verified that my Mosquitto is listening and ready.
    I need fresh ideas. My whole system is pretty dead in the water.
    • MasMatM MasMat
      #define MY_SOFTSPI
      4 TSM:INIT
      5 TSF:WUR:MS=0
      11 TSM:INIT:TSP OK
      13 TSM:INIT:GW MODE
      1582 MCO:BGN:STP
      rozpruwaczR
      rozpruwaczR
      rozpruwacz
      @masmat Check if You can connect to the broker from another computer. Check if You can ping your gateway from another computer.
      • MasMatM
        MasMatM
        MasMat
        The Mosquitto is running on RPi, it can be ssh:d easily. Mosquitto service is running and listening.
        My router's setup page doesn't show gw as a client (nothing on 192.168.0.201) so I cant connect to it. I connected the ethernet cable directly to the router but the result is the same. The W5100 module lights up fine and the blinking etc seems proper but it's not connecting I think. The ip=0.0.0.0 seems strange.
        Exact same behavior when cable is disconnected..
        • rozpruwaczR
          rozpruwaczR
          rozpruwacz
          Maybe spi wiring to the ethernet module od bad ?
          MasMatM 1 Reply Last reply
          • rozpruwaczR rozpruwacz
            MasMatM
            MasMatM
            MasMat
            @rozpruwacz Got lucky and found an extra W5100 without the 100ohm resistors. Also disabled the static ip (I set it from the routers ip table instead).
            Now, it seems the gw is breathing..
