  3. STM32L0 support
STM32L0 support
6 Posts 3 Posters 1.3k Views 2 Watching
    Marcell Gerzsenyi
    Is there any plans for porting this library to STM32L0 devices?
    As I see, the lib uses the STM32DUINO lib as HAL which only supports the STM32F1 chip, but there is the Arduino_Core_STM32 which supports many more devices ( and supported by ST itself as I know). Maybe the developers consider to change the hal to Arduino_Core_STM32 for wider HW support.
    Thanks, Marcell
    tekkaT 1 Reply Last reply
    • M Marcell Gerzsenyi
      Thanks, Marcell
      tekkaT
      tekkaT
      tekka
      @Marcell-Gerzsenyi I've added initial support for the Arduino STM32 core, but things move slowly with limited bandwith. Please feel free to test and report back:
      https://github.com/tekka007/MySensors/tree/STM32duinoUpdate
      M 2 Replies Last reply
      • tekkaT tekka
        Marcell Gerzsenyi
        @tekka Thank you very much! I was able to build a simple sensor I will test it soon and report back.
        • tekkaT tekka
          Marcell Gerzsenyi
          @tekka Thank you again :) It works! I made a custom board with STM32L073RZ and tested it with MySensor over my RS485 network. As a first step I made only a simple sensor with one digital input now I start to write a sophistacated raditaor valve controller with MySenesors library :)
            tekkaT
            tekkaT
            tekka
            @Marcell-Gerzsenyi Perfect, thanks for reporting back!
            • rozpruwaczR
              rozpruwaczR
              rozpruwacz
              @tekka
              Is there something I could help to spped up merging STM32duinoUpdate branch into master ?
              At the moment I have couple of blue pill boards (STM32F103C8) and want to test RS485 network with MySensors.
              And that I have one question, Is it possible to use two hardware serial ports - one for rs485 and another for debug prints ? What I tried is:
              • using AltSoftSerial for rs485 but STM32 platform is not supported there
              • using #define MY_RS485_HWSERIAL Serial1 and #define MY_DEBUGDEVICE Serial2 but Serial2 does not exist
              • using SoftwareSerial but it seems that the code hangs somwhere and does not even get into setup() function (SoftwareSerial uses some timers so maybe they interferre with MySensors)
