  3. Motion and lux meters combined in a single device
23 Posts 9 Posters 17.5k Views 6 Watching
  • AWIA AWI
    @mikemayers can you post your sketch?
    mikemayers
    wrote on last edited by mikemayers
    #21
    @AWI
    @jeylites
    This is what I have done....moved "gw.sleep" to the end.
    #define CHILD_ID 31   // Id of the sensor child
    #define LED_PIN 5
    // Initialize motion message
      gw.begin();
      gw.sendSketchInfo("Motion Sensor", "1.0");
      pinMode(LED_PIN, OUTPUT);
      gw.present(CHILD_ID, S_MOTION);
      // Read digital motion value
      Serial.println(tripped);
      gw.send(msg.set(tripped?"1":"0"));  // Send tripped value to gw
      if (tripped){    // from the "Blink" example sketch :-)
      digitalWrite(LED_PIN, HIGH);   // turn the LED on (HIGH is the voltage level)
       delay(100);        // wait for a second
      digitalWrite(LED_PIN, LOW);  // turn the LED off by making the voltage LOW
      delay(100);
      gw.sleep(INTERRUPT,CHANGE, SLEEP_TIME);
    • korttomaK
      korttomaK
      korttoma
      #22
      Try moving the gw.sleep outside your if statement like this:
             delay(100);
      • Tomas
      • jeylitesJ
        jeylitesJ
        jeylites
        wrote on last edited by jeylites
        #23
        With the help from @korttoma & @AWI , I put together this sketch. I've tested it and it works. Have fun!
        #define LED_PIN 5
          gw.begin();
           delay(1000);        // wait for a second
          delay(1000);
