  2. Announcements
  3. Something's cooking in the MySensors labs...
29 Posts 14 Posters 12.9k Views 14 Watching
  • Giovanni ChivaG
    Giovanni ChivaG
    Giovanni Chiva
    Hi guys! I'm trying to enable RS485 and RF24 transports but I'm getting the following error :
    /libraries/MySensors/2.3.2/MySensors.h:290:2: error: #error Only one forward link driver can be activated
    I saw the MY_RFM69_NEW_DRIVER example and tried to apply the same logic :
    #define MY_RS485_NEW_DRIVER
    This made the error go away but the RS485 transport layer is not initialized.
    I've tried enabling only the RS485 layer and it works.
    Any idea on how to enable multitransport with RF24 and RS485 ?
    BearWithBeardB 1 Reply Last reply
    • Giovanni ChivaG Giovanni Chiva
      BearWithBeardB
      BearWithBeardB
      BearWithBeard
      @Giovanni-Chiva You need the development branch (2.4.0-alpha) for multitransport. 2.3.2, which you are using, doesn't support that. Download here: https://github.com/mysensors/MySensors/tree/development
      Giovanni ChivaG 2 Replies Last reply
      • BearWithBeardB BearWithBeard
        Giovanni ChivaG
        Giovanni ChivaG
        Giovanni Chiva
        @BearWithBeard thanks for the reply!
        Unfortunately I'm getting the same error message :
        /libraries/MySensors-development/MySensors.h:295:2: error: #error Only one forward link driver can be activated
        Am I missing something?
        Here is my gateway code :
        // Enable RS485 transport layer
        #define MY_RS485
        // Define this to enables DE-pin management on defined pin
        #define MY_RS485_DE_PIN 2
        // Set RS485 baud rate to use
        #define MY_RS485_BAUD_RATE 9600
        #define MY_RF24_CS_PIN 10     // Used by the MySensors library.
        #define MY_RF24_CE_PIN 7    // Used by the MySensors library.
        #define MY_RADIO_RF24	// Define radio module
        #define MY_RF24
        #define MY_RF24_PA_LEVEL RF24_PA_MAX // Set radio power to max
        #define MY_RF24_DATARATE RF24_1MBPS // Limit transmission to 1MBS
        // Enable serial gateway
        #define MY_GATEWAY_SERIAL
          Giovanni ChivaG
          Giovanni ChivaG
          Giovanni Chiva
          @BearWithBeard
          Apparently the main development branch does not include multitransport support. I've eventually found @tekka 's branch and was able to download it from here https://github.com/mysensors/MySensors/tree/09434a4b9fb668fbaa2d47803b5541f2d7b05d29
          The error message is gone now, however only RF24 transport layer is working. If I comment the RF24 transport, then RS485 starts working.
            @BearWithBeard
            BearWithBeardB
            BearWithBeardB
            BearWithBeard
            #25
            @Giovanni-Chiva I was certain they merged the multitransport feature into the 2.4 dev branch early on. I was wrong about that. I'm sorry. At least you were able to find the right branch from there on.
            Not sure though why you are having issues combining NRF24 and RS485. Unfortunately, I don't own any RS485 modules to make my own tests. Maybe try using a different pin for RS485 DE?
            Has this combination been tested by anyone else before?
            Giovanni ChivaG 1 Reply Last reply
              Giovanni ChivaG
              Giovanni ChivaG
              Giovanni Chiva
              @BearWithBeard No need to say sorry! You did point me to the right direction, I was clueless :)
              I've tried a different RS485 DE pin, but still no luck.
              #define MY_RS485_DE_PIN 4
              I've seen people mentioning RS485 transport here in the comments but I'm not sure if anyone actually did test this combination (RF24 & RS485).
              • Nick WillisN
                Nick WillisN
                Nick Willis
                I've been using this PR on my gateway for several months now and it's working great. I'm using a Sensebender gateway with both RFM and NRF radios with sensor nodes on both networks. I can swap radio types on a node, change the radio config in the sketch (keeping the node ID) and it flawlessly changes and continues to work in Home Assistant.
                Only thing that is behaving oddly are RFM radio nodes. When they first boot they can pair to the gateway no problem but then suffer NACKs constantly for 3 or 4 mins after which it works no problem for weeks and months... I can see the NACKed messages arriving at the gateway but the node doesn't recieve the ACK from the gateway.
                I also note that all other RFM nodes start NACKing at the same time (I have a NACK monitor sensor on all my nodes) which again clears up once the new node has been on a few minutes. It's the same whenever any RFM node is rebooted.
                I'm not using this PR version on my nodes - only the gateway - as some things would not compile.
                Hope this feedback is of use!
                • P
                  P
                  pikim
                  @BearWithBeard
                  Are you still running the multi version on an ATmega328P? What's your long term experience with it?
                  • P pikim
                    @BearWithBeard
                    BearWithBeardB
                    BearWithBeardB
                    BearWithBeard
                    @pikim No, I am not. My original plan was to deploy more and more RFM-based nodes as they seemed superior over NRF24 in general, but I realized that my NRF24 network was rock solid and reliable, so there was no need for the added complexity and cost to support and integrate another transport. Plans are made to change them. ;)
                    That being said, I used the multiRF gateway for months without issues. The gateway operated as stable as the single transport 2.3.2 gateway. No issues at all, except with the automatic TX power adjustment (ATC) of the RFM transceivers, due to what I believe might be a timing issue within the library. I described the issue in this thread. Basically, the RFM nodes were not able to reduce their transmit power, unnecessarily blasting the environment and wasting battery power. Introducing small delays in various places was all it needed to work around this issue successfully, seemingly without adverse side effects.
                    This issue has not been properly remedied since the introduction of the multiRF gateway though. For all I know, it is still tekka's personal fork of the MySensors 2.4 branch and has not been updated, so any new fixes and features for version 2.4 since March 2020 will not be available to this fork, unless you manually implement them.
                    So I guess it is up to you if you prefer to use the multiRF gateway without all the mainline 2.4 changes, or the up-to-date 2.4 branch without the multiRF feature. It should not make much of a difference currently, according the the commits since the multiRF fork, unless you want to use PJON transport or deploy NRF5-based nodes.
                    I really wish that the development on MySensors revives, as it is feeling kinda stale at the moment. It would be a shame if this project got silently abandoned. I would be glad to help out wherever I can.
