  3. OpenHAB
  4. MQTT & openhab
MQTT & openhab
22 Posts 4 Posters 16.9k Views 2 Watching
  • TotcheT Totche
    And tonight, the weird is back
    C:\Users\Totche>netstat -an|find "1883"
      TCP    0.0.0.0:1883           0.0.0.0:0              LISTENING
    In openHAB.fx, I can see the msgs from the node, so I suppose that the ethernet connection is working
    With MYSController, nothing displayed, no node network
    With the serial, I can see the exchanges between node and the MQTTgateway
    So what's wrong ? The Gateway, a port redirection ????
    tekkaT
    tekkaT
    tekka
    @Totche Just for clarification: MYSController is not compatible with MQTT gateways but with serial gw. .
    TotcheT 1 Reply Last reply
    • tekkaT tekka
      TotcheT
      TotcheT
      Totche
      wrote on last edited by Totche
      #22
      @tekka Ah OK, it's better to know it, thanks; ;)
      And I found the error this morning and it works great......
      To create the configuration file for openHAB, I made a copy/paste of the Mysensors example., and I haven't seen it was a space character at the beginning of each lines.
      I removed it, and it's working fine.now
      So be carefull with the spaces, it was a stupid mistake and boring to find.
      I have done this test 5 times, so I'm sure that it's the problem.
      Thank you everybody....
