  3. Powering with LiPo a mini pro without regulator
25 Posts 5 Posters 18.0k Views 2 Watching
  • V
    V
    Viper_Scull
    wrote on last edited by Viper_Scull
    I intend to build a battery-powered gas sensor. Components would be Arduino Mini Pro 3.3V, nrf24L01+, a MQ-2 sensor, a step-up regulator to power the 5V sensor and a 3.7V 2000mAh LiPo ( I have a few of them from another proyect). I haven't bought any of the others components yet, so I'm totally open to changes.
    I read here that in order to save some battery, the 3.3v regulator and the led lines can be cut.
    I have a few doubts though. Would the arduino or the radio be damaged if there's no regulator due to the 3.7V input?
    If so, would you leave the regulator and keep this battery or cut the line and use a 3.3V button cell / 2x1.5V AAA?
    • Vladut GrecuV
      Vladut GrecuV
      Vladut Grecu
      Did you consider not recharging the battery over 3.3v? The nrf's 3.3v is a must. You can't go over 3.378v. (tested by me, before the poor little guy fried)
      m26872M V 2 Replies Last reply
      • epierreE
        epierreE
        epierre
        I'm not sure using a battery would be possible, datasheet says "less than 800mW", some other site "Operating current 40mA".
        I've done this test with MQ135 and it lasted... 2 minutes.;.
        z-wave - Vera -> Domoticz
        • Vladut GrecuV
          Vladut GrecuV
          Vladut Grecu
          It lasted 2 minutes because you read the sensor way to often. For an extended battery life you need to put the arduino to sleep for as much as possible and read the sensors value very rarely.
          epierreE 1 Reply Last reply
          • Vladut GrecuV Vladut Grecu
            m26872M
            m26872M
            m26872
            Any ideas then why the spec says 1.9-3.6V ?
            • Vladut GrecuV
              Vladut GrecuV
              Vladut Grecu
              wrote on last edited by Vladut Grecu
              The original nrf may support 3.6 but the chinese models that i have die faster :'/
              m26872M 1 Reply Last reply
                m26872M
                m26872M
                m26872
                @Vladut-Grecu
                Good point.
                • Vladut GrecuV
                  Vladut GrecuV
                  Vladut Grecu
                  What I don`t get is why you want to cut the 3.3v regulator when you only get a 220 micro Amps consumption reduction and the resistors that you use to measure the actual voltage over the Analog pin use way more..
                  Use the internal arduino voltage measure. You will see 3.3v even if you get over 3.3v but what you actually need know is when the voltage drops under 3.3v so you know when you have to start recharging your li-po.
                    m26872M
                    m26872M
                    m26872
                    @Vladut-Grecu
                    "the resistors that you use to measure the actual voltage over the Analog pin use way more" ??
                    The recommended voltage divider for 2AAs is 1M+470k and e.g. for 4AAs I use 1M+5M with success.. ~1uA is not that much.
                    • Vladut GrecuV
                      Vladut GrecuV
                      Vladut Grecu
                      The rezistors + the code that needs to be run? The extra cycles for you to read the Analog pin? I go with the idea that if there is allready a measuring in the arduino anyway why do i need to reinvent the wheel? The voltage divider thingy is ok if you want to measure voltages that go over the vcc value
                        m26872M
                        m26872M
                        m26872
                        @Vladut-Grecu
                        The internal method is the obvious choice when battery voltage is Vcc. Whether you need regulator, step-up/down etc or not, is determined by things like sensors and battery range etc.
                        I doubt there are extra cycles compared to the internal method. Besides, I'd say the power loss from extra cycles would be neglectable
                        Regarding the use of voltage divider above and under Vcc, I refer to my answer here.
                        • Vladut GrecuV
                          Vladut GrecuV
                          Vladut Grecu
                          You are right. But 220uA are neglectable aswell. (For me at least)
                            m26872M
                            m26872M
                            m26872
                            Sorry, but the 220uA is drawn continously. Since most of my (and many others) battery applications have long sleep durations, the sleep mode power consumption is the first priority. Second is probably limiting the radio usage (meaning you can do things with just the arduino).
                            AnticimexA 1 Reply Last reply
                              epierreE
                              epierreE
                              epierre
                              @Vladut-Grecu not really, but keep in mind that some sensors need to reach the needed temperature to be read, so you may need to heat for 10 minutes before reading and thus you will drain your battery. Also, even with a slepp, you may need an on/off on powering the gas sensor for it is continuously powered.
                                V
                                V
                                Viper_Scull
                                Sorry, I've been swamped the last couple of days.
                                LiPo batteries should not go below 3V if I'm not mistaken, so charging it to 3.3V would make me recharge it more often. The sensor is for my folks because they still have butane gas for hot water, so I'd like it to last as long as possible. If, like you say, the chinese clon can't operate at more than 3.378V, I'll stick to 2 x AA batteries.
                                As the main power drain occurs when the sensor reads and the radio sends, I thought of measuring the battery just after that happens, which in this case it'd be like a minute or so. Therefore the extra cycles to read the analog input should be negligible.
                                About the step up converter, the store has a couple listed. This one http://goo.gl/1gwmm2 has a usb input and the other one http://www.ebay.com/itm/291352631612?rmvSB=true doesn't. The second one is better to use ion this case, isn't it?
                                @epierre said in Powering with LiPo a mini pro without regulator:
                                So you say the sensor would be continuously powered even though we do a gw.sleep?? The heater has a power consumption of 900mW.
                                • Vladut GrecuV
                                  Vladut GrecuV
                                  Vladut Grecu
                                  Neither. Those will boost it till 5v. You need something like this.
                                  V 1 Reply Last reply
                                    V
                                    V
                                    Viper_Scull
                                    But that one wouldn't be enough to feed the 5V that the MQ-2 gas sensor requires, would it?
                                    • m26872M m26872
                                      AnticimexA
                                      AnticimexA
                                      Anticimex
                                      My take on low power measurement.
                                      I have not gotten around to actually build it yet but I hope to do some measurements in my "lab" this spring.
                                      • Vladut GrecuV
                                        Vladut GrecuV
                                        Vladut Grecu
                                        Oh.. for the gas sensor they are ok. Last one (green) seems a little bit more polished. The presence of the usb port is not important, you can solder it off. The usb is the output. Check the picture again. It's your choice.
                                          V
                                          V
                                          Viper_Scull
                                          Yes, you're right, it's the output. I didn't take a close look to the image. The green one seems more polished as you say. I'll try with those.
                                          That's a very interesting project. In the thread some of you say that if VBatt = Vcc (no regulator like I'd like to have) then using the divider to measure the charge is non-sense and it's way better to use the internal functionality, Am I wrong?
                                          AnticimexA m26872M 2 Replies Last reply
