  3. Get STM32 blue pill to run
5 Posts 2 Posters 809 Views 3 Watching
  • karlheinz2000K
    karlheinz2000K
    karlheinz2000
    I struggle since 2 days to get a node based on STM32 to run. It is my first test with STM32. I installed the arduino libs. I can upload "blink" and this works, serial output also.
    But when I include <MySensors.h> the STM seems not to start/run. LED doesn't blink, no output on serial. I would expect some some lib prints on serial, but nothing.
    Compile and upload is with no error.
    It doesn't matter if radio is connected or not.
    Any special things need to be considered for STM32?
    #define MY_DEBUG            //MYSENSOR Lib
    #define   MY_TRANSPORT_WAIT_READY_MS   100
    #define MY_NODE_ID 49 // id of the node
    //#define MY_PARENT_NODE_ID 55
    //#define MY_PARENT_NODE_IS_STATIC
    // ++++++++++++++ NRF24 +++++++++++++++++
    // This is needed if you use an STM32 board:
    #define MY_RF24_CE_PIN PB0
    #define MY_DEBUGDEVICE Serial1
    #include "MySensors.h"
    ///////////////////////////////// BEFORE ////////////////////////////////////////////////////////////////////
    void before()
      Serial1.begin(115200);
      Serial1.print("before");
    /////////////////////////////////////// SETUP ///////////////////////////////////////////////////////////////
      Serial1.print("setup");
      pinMode(PC13, OUTPUT);
    /////////////////////////////////////// LOOP ////////////////////////////////////////////////////////////////
      digitalWrite(PC13, HIGH);   // turn the LED on (HIGH is the voltage level)
      delay(1000);              // wait for a second
      digitalWrite(PC13, LOW);    // turn the LED off by making the voltage LOW
    • fritsF
      fritsF
      frits
      I wasn't aware of a MY_DEBUGDEVICE, so I was courious and found this thread:
      https://forum.mysensors.org/topic/9381/no-my_debugdevice-begin
      It basically says you should add MY_DEBUGDEVICE.begin ( baud ) in preHwInit(), then wait until ready...
      • karlheinz2000K
        karlheinz2000K
        karlheinz2000
        This helped a lot! Got the serial to work. But...
        13:29:37.828 ->  __  __       ____
        13:29:37.828 -> |  \/  |_   _/ ___|  ___ _ __  ___  ___  _ __ ___
        13:29:37.862 -> | |\/| | | | \___ \ / _ \ `_ \/ __|/ _ \| `__/ __|
        13:29:37.862 -> | |  | | |_| |___| |  __/ | | \__ \  _  | |  \__ \
        13:29:37.862 -> |_|  |_|\__, |____/ \___|_| |_|___/\___/|_|  |___/
        13:29:37.862 ->         |___/                      2.4.0-alpha
        13:29:37.862 ->
        13:29:37.862 -> 18 MCO:BGN:INIT NODE,CP=RNNNM---,FQ=72,REL=0,VER=2.4.0-alpha
        13:29:37.862 -> 29 !MCO:BGN:HW ERR
        Looks like these cheap blue pills have some issue with EEPROM?
        I later connected a Maple Mini board, which goes straight to "loop" as expected.
        • fritsF
          fritsF
          frits
          STM32F1, like SAMD, has no EEPROM as far as I know.
          • karlheinz2000K
            karlheinz2000K
            karlheinz2000
            Yes, no real EERPOM, but emulation in flash. EEPROM failure was the first finding when checking for this error message. Maybe somthing else...
            Now complete sketch is ported from AVR ProMini to STM32 and is runnig fine :+1:
