  3. ESP8266gateway with sensor
2 Posts 2 Posters 411 Views 2 Watching
    Meister_Petz
    I would like to use the ESP8266gateway standalone with a sensor. I used the ESP8266gateway sketch and it connects without problems to my controller, but I can't get it to send a message to the controller (FHEM).
    I made a very easy code, for testing. It would just be "light level" but in this case even without a sensor, just sending "100".
    #define MY_BAUD_RATE 9600
    //#define MY_RADIO_RF24
    //#define MY_RADIO_RFM95
    #define MY_GATEWAY_ESP8266
    #define MY_WIFI_SSID "this is the SSID"
    #define MY_WIFI_PASSWORD "And the password"
    // Enable UDP communication
    //#define MY_USE_UDP  // If using UDP you need to set MY_CONTROLLER_IP_ADDRESS or MY_CONTROLLER_URL_ADDRESS below
    #define MY_HOSTNAME "ESP8266_Greenhouse"
    #define MY_PORT 5003
    //#define MY_GATEWAY_MAX_CLIENTS 2
    //#define MY_CONTROLLER_IP_ADDRESS 10, 0, 78, 204
    //#define MY_CONTROLLER_URL_ADDRESS "my.controller.org"
    // Set blinking period
    //#define MY_DEFAULT_LED_BLINK_PERIOD 300
    // Flash leds on rx/tx/err
    // Led pins used if blinking feature is enabled above
    #define CHILD_ID_LIGHT 0
    MyMessage msgLight(CHILD_ID_LIGHT, V_LIGHT_LEVEL);
    uint32_t WAIT_TIME = 1200; // Sleep time between reads (in milliseconds)
      sendSketchInfo("GreenhouseWifiNode", "1.0");
    	//Light
      int16_t lightLevel = 100;
      Serial.println(lightLevel);
      send(msgLight.set(lightLevel));
      wait(WAIT_TIME);
    This is the serial output:
    connected with Eichenstrasse, channel 3
    dhcp client start...
    ip:10.0.78.206,mask:255.255.255.0,gw:10.0.78.1
    5137 GWT:TIN:CONNECTING...
    5165 GWT:TIN:IP: 10.0.78.206
    5196 MCO:BGN:STP
    5213 MCO:REG:NOT NEEDED
    5238 MCO:BGN:INIT OK,TSP=NA
    100
    100
    100
    100
    100
    100
    100
    100
    pm open,type:2 0
    100
    100
    100
    100
    Any ideas what I do wrong?
    • GrahamG
      GrahamG
      Graham
      Here is my code for doing something equivalent. You seem to have the pinMode line missing in setup()
      // Initialize motion message
        pinMode(MOTION_SENSOR_PIN, INPUT_PULLUP);      // sets the motion sensor digital pin as input
      void presentation() {
        sendSketchInfo("Motion Sensor", "1.1");
        present(CHILD_ID, S_MOTION);
      boolean pinstate = false;
        boolean newstate = (digitalRead(MOTION_SENSOR_PIN) == HIGH);
        if (newstate != pinstate) {
          if (newstate == true) {
            send(msg.set("1"));
            Serial.println("Motion Started");
            pinstate = newstate;
          } else {
            send(msg.set("0"));
            Serial.println("Motion Stopped");
