  3. Led Rx,Tx,Err for ESP8266 Wifi gateway not working.
1 Posts 1 Posters 249 Views 1 Watching
  • G
    G
    Gerard_Tlse
    I have a small problem: I am using the Gateway Mysensor EPS8266 WIFi.
    Everything is correctly working except the leds:
    in the code mysensor code , there was:
    // Flash leds on rx / tx / err
    // Led pins used if blinking feature is enabled above
    define MY_DEFAULT_ERR_LED_PIN 16 // Error led pin
    define MY_DEFAULT_RX_LED_PIN 16 // Receive led pin
    define MY_DEFAULT_TX_LED_PIN 16 // the PCB, on board LED
    I replaced by:
    #define MY_DEFAULT_ERR_LED_PIN 1 // Error led pin
    #define MY_DEFAULT_RX_LED_PIN 3 // Receive led pin
    #define MY_DEFAULT_TX_LED_PIN 4 // the PCB, on board LED
    and it does not work: the LEDs are always on.
    can you tell me if these pins are used for other things and only led 16 is available?
    Thanks for your help
    Gerard
