  3. Domoticz
  4. virtual switch
virtual switch
1 Posts 1 Posters 670 Views 1 Watching
    mickaelr30
    I am using domoticz and I would need a virtual switch to change a time base in mysensors
    I have the virtual switch in domoticz but whether or not I activate the switch, the time base never changes .
    I have another question: is it possible to send a pressure in bars and not in hpa ?
    thanks
    * The ArduinoGateway prints data received from sensors on the serial link.
    * The gateway accepts input on serial which will be sent out on radio network.
    * The GW code is designed for Arduino Nano 328p / 16MHz
    * Wire connections (OPTIONAL):
    * - Inclusion button should be connected between digital pin 3 and GND
    * - RX/TX/ERR leds need to be connected between +5V (anode) and digital pin 6/5/4 with resistor 270-330R in a series
    * LEDs (OPTIONAL):
    * - To use the feature, uncomment any of the MY_DEFAULT_xx_LED_PINs
    * - RX (green) - blink fast on radio message received. In inclusion mode will blink fast only on presentation received
    * - ERR (red) - fast blink on error during transmission error or receive crc error
    #define MY_RADIO_RF24
    //#define MY_RADIO_NRF5_ESB
    //#define MY_RADIO_RFM95
    // Enable serial gateway
    #define MY_GATEWAY_SERIAL
    // Define a lower baud rate for Arduinos running on 8 MHz (Arduino Pro Mini 3.3V & SenseBender)
    #if F_CPU == 8000000L
    #define MY_BAUD_RATE 38400
    // Enable inclusion mode
    // Set blinking period
    // Flash leds on rx/tx/err
    #define CHILD_ID_SENSE_BARO 13
    #define CHILD_ID_CALIBRATION 15
    #define BARO_SENSE 0
    bool Calibration;
    float Pression = 0;
    const unsigned long SEND_BARO = 90000;
    unsigned long previousMillisbaro = 0;
    MyMessage pressure_msg(CHILD_ID_SENSE_BARO, V_FORECAST);
      sendSketchInfo("Piscine_Mesure", "2.0");
       present (CHILD_ID_CALIBRATION, S_BINARY);
       present (CHILD_ID_SENSE_BARO, S_BARO);
      if (message.getType()==V_STATUS) {
        Calibration = message.getBool();
        if (Calibration ==0) {
         previousMillisbaro = 900000;
        if (Calibration ==1) {
         previousMillisbaro = 300;
    pressure();
    void pressure()
       int Lecture_adc = analogRead(BARO_SENSE);
       Pression = (((Lecture_adc*10/1024.0)-1.0)/1.7)*1000;
        if(millis()-previousMillisbaro >= SEND_BARO) {
         previousMillisbaro = millis();
         send(pressure_msg.set(Pression, 0));
