  3. Home Assistant
  4. Supporting cover tilt position
6 Posts 4 Posters 1.3k Views 4 Watching
  • H
    H
    hypnosiss
    In home assistant, there is an option to controll tilt of the rollershutter but currently mysensors integration is not supporting that feature.
    I decided to modify the integration and add such support. Unfortunately I've used V_VAR1 to carry position of the tilt, because it was only one I could legaly use.
    It is working fine and I would create pull request to github, but I need common understanding with you guys which type of the message should be used. Is V_VAR1 ok or new one should be introduced in mysensors?''
    Best regards,
    Mariusz
    rejoe2R 1 Reply Last reply
    • H hypnosiss
      Best regards,
      Mariusz
      rejoe2R
      rejoe2R
      rejoe2
      @hypnosiss Hi there, glad to hear someone is developing code for venetian blind covers :+1: .
      Just some thoughts on this:
      Despite using some kind of custom field might be ok or having a commonly used seperate variable might be fine as well, I personally would tend to just use a second set of the S_COVER-variables under a seperate child ID.
      Not sure, how other home automation systems deal with that, but this seems to be some kind of standard for actors supporting a venetian blind mode. E. g. newer Z-Wave devices like Fibaro FGR-223 or Tasmota (starting with 10.0.0.4?) also just present a secon "blind" to control tilt position.
      • H
        H
        hypnosiss
        In case of control under separate ID I am not sure whether Home Assistant will merge controlling tilt and cover position in one card like here
        it would be ideal to create separate variable but probably it could be a long process (update mysensors lib -> update pymysensors -> update home assistant to use never version of pymysensors -> update home assistant to support new variable and probably also modules to use newer version of mysensors).
        G 1 Reply Last reply
        • F
          F
          feanor-anglin
          Very important feature, actually I can't understand how it is still missing in MySensors. Ultimately there should be just one more percentage value with a proper name added to the same device ID. Separate ID is not a good idea, because of the reason you presented. As you say, it seems quite difficult this way, but nonetheless this should be a goal here. Using VAR1 is a good and fully functional workaround though. I'm looking forward to see your code.
          • H hypnosiss
            G
            G
            gryzli133
            @hypnosiss have you shared your code already? Could you put here a link to your solution. I would like to see how did you managed to connect V_VAR1 to second slider. Thanks in advance!
            • H
              H
              hypnosiss
              hey,
              sorry for late reply. PR for mysensors is ready to be merged:
              https://github.com/mysensors/MySensors/pull/1570
              next step is create PR in mysensors integration for home assistant.
              Best regards
              Mariusz
