  3. Homeassistant in docker dont connect with serial gateway
1 Posts 1 Posters 333 Views 1 Watching
  • B
    B
    badisensors
    I have installed homeassistant with docker and i have made the RPi serial gateway in port /dev/ttyUSB020 . I also have map the port in docker-compose.yml
    devices:
    - /dev/serial/by-id/usb-0658_0200-if00:/dev/serial/by-id/usb-0658_0200-if00
    - /dev/ttyUSB020:/dev/ttyUSB020
    When i try to add the mysensors integration in homeassistant it cant see the port. How can i fix that?
