  3. ESP WiFi hung solution
1 Posts 1 Posters 757 Views 1 Watching
  • F
    F
    fsgraz
    This is how I solved the issue of ESP32 GW hanging when WiFi connection is lost or not established. It is not 100% my original work, it has been put together using bits and pieces, but it works.
    I simply use a watchdog timer:
    #include "esp_system.h" // added for WDT
    hw_timer_t* timer = NULL;
    // WDT related
    void IRAM_ATTR resetModule() {
    	Serial.println("reboot\n");
    	ESP.restart();
    void WdtReset()
        timerWrite(timer, 0); //reset timer (feed watchdog)
    void StartWatchDog()
        timer = timerBegin(0, 240, true); //timer 0, div 80
        timerAttachInterrupt(timer, &resetModule, true);
        timerAlarmWrite(timer, 5000000, false); //set time in us
        timerAlarmEnable(timer); //enable interrupt
    IPAddress ConnectWiFi()
        Serial.println();
        Serial.println();
        Serial.print("Connecting to ");
        Serial.println(MY_WIFI_SSID);
        /* Explicitly set the ESP to be a WiFi-client, otherwise, it by default,
           would try to act as both a client and an access-point and could cause
           network-issues with your other WiFi-devices on your WiFi-network. */
    #ifdef ESP32
        WiFi.persistent(false);
        WiFi.mode(WIFI_STA);
    #endif // ESP32
        WiFi.begin(MY_WIFI_SSID, MY_WIFI_PASSWORD);
        while (WiFi.status() != WL_CONNECTED) {
            digitalWrite(LED_BUILTIN, LED_ON);
            wait(500);
            Serial.print(".");
            digitalWrite(LED_BUILTIN, LED_OFF);
            wait(500);
    #ifdef ESP32
        WiFi.setAutoReconnect(true);
    #endif // ESP32
        return WiFi.localIP();
    void before()
        StartWatchDog();
        // We start by connecting to a WiFi network
        localIP = ConnectWiFi();
        myHostname = WiFi.getHostname();
        WdtReset();
        Serial.println("");
        Serial.println("WiFi connected");
        Serial.println("IP address: ");
        Serial.println(localIP);
        Serial.println(myHostname);
    // do other stuff ...
        // check WiFi connection
        if (WiFi.status() != WL_CONNECTED) return; // the WDT is not reset
        WdtReset();
    Hope it helps
