  3. Home Assistant HVAC Serial gateway (fan speed)
1 Posts 1 Posters 328 Views 1 Watching
  • Willie-wortelW
    Willie-wortelW
    Willie-wortel
    Hi there,
    Can someone confirm that a setup with Serial Gateway using local connected HVAC sensor should work in Home Assistant? Especially in regards to the V_HVAC_SPEED variable?
    Also, I'm using an Arduino micro (Atmega32u4) to test this. Sometimes I see that a heater entity is added, but it does not support V_HVAC_SPEED variable, only the HVAC state.
    It seems the same problem as described here: link!
    The code I'm using:
    // Enable serial gateway
    #define MY_GATEWAY_SERIAL
    #define MY_BAUD_RATE 38400
    #define CHILD_ID_HVAC 0
    #define SN "Test sketch"
    #define SV "2.3.2"
    MyMessage msgHVACSpeed(CHILD_ID_HVAC, V_HVAC_SPEED);
    MyMessage msgHVACSetPointC(CHILD_ID_HVAC, V_HVAC_SETPOINT_COOL);
    MyMessage msgHVACFlowState(CHILD_ID_HVAC, V_HVAC_FLOW_STATE);
    String  MODE_STATE_TXT;
    String  FAN_STATE_TXT;
    int     FAN_STATE;
    int     TEMP_STATE;
    bool    initialValueSent = false;
      //pinMode(LED_BUILTIN, OUTPUT);
      sendSketchInfo(SN, SV);
      present(CHILD_ID_HVAC, S_HVAC, "Thermostat");
      if (!initialValueSent)
        FAN_STATE_TXT = "Min";         // default fan start state
        TEMP_STATE = 20;               // default start temperature
        MODE_STATE_TXT = "CoolOn";     // default mode state
        send(msgHVACSpeed.set(FAN_STATE_TXT.c_str()));
        send(msgHVACSetPointC.set(TEMP_STATE));
        send(msgHVACFlowState.set(MODE_STATE_TXT.c_str()));
        initialValueSent = true;
      //wait(1000);
      if (message.isAck())
         //Serial.println("This is an ack from gateway");
         return;
      //Serial.print("Incoming message for: ");
      //Serial.print(message.sensor);
      String recvData = message.data;
      recvData.trim();
      //Serial.print(", New status: ");
      //Serial.println(recvData);
      switch (message.type)
        case V_HVAC_SPEED:
          //Serial.println("V_HVAC_SPEED");
          if(recvData.equalsIgnoreCase("auto")) FAN_STATE = 0;
          else if(recvData.equalsIgnoreCase("min")) FAN_STATE = 1;
          else if(recvData.equalsIgnoreCase("normal")) FAN_STATE = 2;
          else if(recvData.equalsIgnoreCase("max")) FAN_STATE = 3;
          FAN_STATE_TXT = recvData;
        break;
      //sendHeatpumpCommand(); // apply setting!
      sendNewStateToGateway();
    void sendNewStateToGateway()
      Serial.println("Status update send to HA:");
      Serial.println("*************************");
      Serial.println("Mode = " + MODE_STATE_TXT + "(" + (String)MODE_STATE + ")");
      Serial.println("Fan = " + FAN_STATE_TXT + "(" + (String)FAN_STATE + ")");
      Serial.println("Temp = " + (String)TEMP_STATE);
