  3. No LAN connection ESP8266 gateway
esp8266
21 Posts 4 Posters 3.9k Views 4 Watching
  • OldSurferDudeO OldSurferDude
    @mfalkvidd @Bramz @electrik
    When I saw 2.6.2 I was thinking the MySensors Library (2.3.2)! It never occurred to me it was the board manager.
    So, yes! it works for me. :)
    I just checked to see if Domoticz has an MQTT interface and it appears that it does. @Bramz, look into that. Once you have that, then it may be easy to connect other devices, like Tasmota devices, to Domoticz. MQTT requires an always-on computer connected to your network.
    I have a headless (needs dummy monitor plug or 3x 75Ω resistors to boot), refurbished computer on which I run Linux OS, then both MQTT and Home Assistant running in Virtual Box.
    Thanks everyone!
    OSD
    B
    B
    Bramz
    Still, there seems to be 'someting rotten in the state of Network' where my LAN is concerned. Although the Arduino serial monitor says:
    13:03:55.821 -> connected with XXX, channel 6
    13:03:55.868 -> ip:192.168.178.4,mask:255.255.255.0,gw:192.168.178.1
    13:03:55.915 -> ip:192.168.178.4,mask:255.255.255.0,gw:192.168.178.1
    13:04:04.826 -> pm open,type:2 0
    when I ping the IP-address I get:
    Pinging 192.168.178.4 with 32 bytes of data:
    Request timed out.
    Request timed out.
    Request timed out.
    Request timed out.
    Ping statistics for 192.168.178.4:
        Packets: Sent = 4, Received = 0, Lost = 4 (100% loss),
    When I use the tool 'Wireless Network Watcher' I do see that a device is connected at 192.168.178.4 with the correct MAC address.
    However, when I look at the management page of my FritzBox 7490 modem/router no device is mentioned at 192.168.178.4.
    I remain at a loss here.
