  3. Hum temp rain sensor help
5 Posts 3 Posters 2.9k Views 2 Watching
  • F
    F
    floris
    i merged 2 sketches and hoped that it would work. but not. the node sends only the temp when there is a change at the rain-sensor. and i want the temp/hum be send each couple of minutes. can anyone help? here is my sketch;.
    [code]
    #include <SPI.h>
    #include <MySensor.h>
    #include <DHT.h>
    #define CHILD_ID_HUM 0
    #define CHILD_ID_TEMP 1
    #define CHILD_ID_RAIN 3
    #define HUMIDITY_SENSOR_DIGITAL_PIN 3
    #define DIGITAL_INPUT_SOIL_SENSOR_PIN 4
    #define INTERRUPT DIGITAL_INPUT_SOIL_SENSOR_PIN-2 // Usually the interrupt = pin -2 (on uno/nano anyway)
    MySensor gw;
    DHT dht;
    float lastTemp;
    float lastHum;
    boolean metric = true;
    MyMessage msgHum(CHILD_ID_HUM, V_HUM);
    MyMessage msgTemp(CHILD_ID_TEMP, V_TEMP);
    MyMessage msg(CHILD_ID_RAIN, V_TRIPPED);
    int lastSoilValue = -1;
      gw.begin();
      gw.sendSketchInfo("Floris Multi Rain+Hum", "1.0");
      gw.present(CHILD_ID_HUM, S_HUM);
      gw.present(CHILD_ID_TEMP, S_TEMP);
      pinMode(DIGITAL_INPUT_SOIL_SENSOR_PIN, INPUT); // sets the motion sensor digital pin as input
      gw.present(CHILD_ID_RAIN, S_MOTION);
     metric = gw.getConfig().isMetric;
      // Read digital soil value
      int soilValue = digitalRead(DIGITAL_INPUT_SOIL_SENSOR_PIN); // 1 = Not triggered, 0 = In soil with water
      if (soilValue != lastSoilValue) {
        Serial.println(soilValue);
        gw.send(msg.set(soilValue==0?1:0)); // Send the inverse to gw as tripped should be when no water in soil
        lastSoilValue = soilValue;
      if (isnan(temperature)) {
      } else if (temperature != lastTemp) {
        lastTemp = temperature;
        if (!metric) {
        Serial.print("T: ");
        Serial.println(temperature);
      if (isnan(humidity)) {
      } else if (humidity != lastHum) {
          lastHum = humidity;
          Serial.print("H: ");
          Serial.println(humidity);
      gw.sleep(SLEEP_TIME);
    [/code]
    TotcheT DwaltD 2 Replies Last reply
    • F floris
      [code]
      #include <SPI.h>
      #include <DHT.h>
      MySensor gw;
      DHT dht;
      float lastTemp;
      float lastHum;
        gw.begin();
          if (!metric) {
            lastHum = humidity;
      [/code]
      TotcheT
      TotcheT
      Totche
      > lastHum = humidity;
      Hello, have you a message on the serial print ? Failed reading humidity from DHT or the value ?
      If you want to send every 2 mns, you have to "sleep" 2601000 milllseconds - the processing time for your code (near 0 compared to 2 mns)
      • F
        F
        floris
        Hi Totche, thanks for reaction.
        this is the serial print;
        sensor started, id 11
        send: 11-11-20-0 s=255,c=0,t=17,pt=0,l=5,st=ok:1.4.1
        send: 11-11-20-0 s=255,c=3,t=6,pt=1,l=1,st=ok:20
        send: 11-11-20-0 s=255,c=3,t=11,pt=0,l=21,st=ok:Floris Multi Rain+Hum
        send: 11-11-20-0 s=255,c=3,t=12,pt=0,l=3,st=ok:1.0
        send: 11-11-20-0 s=0,c=0,t=7,pt=0,l=5,st=ok:1.4.1
        send: 11-11-20-0 s=1,c=0,t=6,pt=0,l=5,st=ok:1.4.1
        send: 11-11-20-0 s=3,c=0,t=1,pt=0,l=5,st=ok:1.4.1
        send: 11-11-20-0 s=3,c=1,t=16,pt=2,l=2,st=ok:0
        send: 11-11-20-0 s=1,c=1,t=0,pt=7,l=5,st=ok:22.3
        T: 22.30
        send: 11-11-20-0 s=0,c=1,t=1,pt=7,l=5,st=ok:59.0
        H: 59.00
        and after using the rain sensor:
        T: 22.30
        H: 59.00
        send: 11-11-20-0 s=3,c=1,t=16,pt=2,l=2,st=ok:1
        send: 11-11-20-0 s=0,c=1,t=1,pt=7,l=5,st=ok:59.1
        H: 59.10
        send: 11-11-20-0 s=0,c=1,t=1,pt=7,l=5,st=ok:59.4
        H: 59.40
        Then i get a update from my hum/sensor....(so after activity from the rainsensor, there is an update for hum/rain, and not automagicly). For the moment i want to keep it to 30 seconds, for testing.
        i changed the gw.sleep;
        gw.sleep(INTERRUPT, CHANGE, SLEEP_TIME);
        but no luck so far.
        • F floris
          [code]
          #include <SPI.h>
          #include <DHT.h>
          MySensor gw;
          DHT dht;
          float lastTemp;
          float lastHum;
            gw.begin();
              if (!metric) {
                lastHum = humidity;
          [/code]
          DwaltD
          DwaltD
          Dwalt
          wrote on last edited by Dwalt
          @floris I think it may have to do with the brackets { } in your loop. You have a open bracket { for your first " if" statement to check the rain and it does not appear to close } until after your "sleep" function at the bottom of the entire loop. This would cause the hum and temp readings (and sleep) to be skipped until the "if" statement is satisfied.
          F 1 Reply Last reply
          • DwaltD Dwalt
            F
            F
            floris
            @Dwalt thanks, that did the trick. now it's working! thanks!
            Floris
