  3. Using optocoupler as actuator in node
22 Posts 9 Posters 14.1k Views 1 Watching
  • daulagariD daulagari
    Had this problem myself, controlling Somfy blinds using my computer/smartphone.
    Did read in a forum on a Somfy RS-485 solution (way to expensive) and about somebody that took his remote control and replaced the buttons by relays and had those relays controlled by a zWave (dual) binary switch. Also quite expensive solution to my opinion and not that supported.
    Recently, but before I knew mysensors, RFXCOM came with the RFXtrx433E so I went for that. Quite nice, you can pair the Somfy blinds with the RFXtrx433E and control everything.
    Knowing mysensors, taking the remote control and replacing the buttons using relays controlled by an Arduino Pro Mini would also be a good option.
    Z
    Z
    Zeph
    Or better still, optocouplers or an analog switch as described above...
    daulagariD 1 Reply Last reply
    • Z Zeph
      daulagariD
      daulagariD
      daulagari
      Yes, that's a better option as relays are quite power hungry and bulky.
