  3. Same value from 2 different placed DS18B20
2 Posts 2 Posters 1.6k Views 1 Watching
  • H
    H
    Hausner
    wrote on last edited by Hausner
    I'm having a hard time figuring out, why i'm getting the same value from 2 different DS18B20 from the same node. Both DS18 are on Pin 3.
    I know for SURE, that the values/readings can never be the same, as they are placed 2 different places. It's ALWAYS the second DS that somehow get the first DS's value, and that is then transmitted. The node is monitoring a DIY solar water heating system. 1 DS18B20 (S=1) is placed in the collection tank (55 gal water), and the other is placed inside the waterhose to monitor the heat in the panel.
    Sketch:
    // Running DS temperature sensor(s) and relay(s) on one mysensor arduino node
        // Combines Onewire and Relay code
        // 2014-10-14 Pego: Tested and Running on Uno/Clone and MQTT gateway
        // Example sketch showing how to send in OneWire temperature readings
        // Example sketch showing how to control physical relays.
        // This example will remember relay state even after power failure.
        #include <OneWire.h>
        #define RELAY_1  5  // Arduino Digital I/O pin number for first relay (second on pin+1 etc)
        unsigned long SLEEP_TIME = 30000; // Sleep time between reads (in milliseconds) 30000 orig
        OneWire oneWire(ONE_WIRE_BUS);
        int numSensors=0;
        boolean metric = true;
        MyMessage msg(0,V_TEMP);
          // Startup OneWire
          sensors.begin();
          //gw.begin();
          gw.sendSketchInfo("Temp and Relays", "1.0");
             gw.present(i, V_TEMP);
          // Fetch relay status
            gw.present(sensor, S_LIGHT);
            pinMode(pin, OUTPUT);
            digitalWrite(pin, gw.loadState(sensor)?RELAY_ON:RELAY_OFF);
          gw.process();
            // Only send data if temperature has changed more then 1 degC and no error
            if ((lastTemperature[i]) != temperature && temperature != -127.00 && temperature != 85.00) { //added integer
          delay(1000);
          //gw.sleep(SLEEP_TIME); //no sleep for relays!!!!
          if (message.type==V_LIGHT) {
             // Change relay state
             // Store state in eeprom
             // Write some debug info
             Serial.print(message.sensor);
    Readings on node serial port:
    repeater started, id 41
    send: 41-41-33-0 s=255,c=0,t=18,pt=0,l=5,st=ok:1.4.1
    send: 41-41-33-0 s=255,c=3,t=6,pt=1,l=1,st=ok:33
    read: 0-33-41 s=255,c=3,t=6,pt=0,l=1:M
    send: 41-41-33-0 s=255,c=3,t=11,pt=0,l=15,st=ok:Temp and Relays
    send: 41-41-33-0 s=255,c=3,t=12,pt=0,l=3,st=ok:1.0
    send: 41-41-33-0 s=0,c=0,t=0,pt=0,l=5,st=ok:1.4.1
    send: 41-41-33-0 s=1,c=0,t=0,pt=0,l=5,st=ok:1.4.1
    send: 41-41-33-0 s=1,c=0,t=3,pt=0,l=5,st=ok:1.4.1
    send: 41-41-33-0 s=2,c=0,t=3,pt=0,l=5,st=ok:1.4.1
    send: 41-41-33-0 s=0,c=1,t=0,pt=7,l=5,st=ok:30.1
    send: 41-41-33-0 s=1,c=1,t=0,pt=7,l=5,st=ok:24.0
    read: 0-33-41 s=2,c=1,t=2,pt=0,l=1:1
    Incoming change for sensor:2, New status: 1
    send: 41-41-33-0 s=0,c=1,t=0,pt=7,l=5,st=ok:30.2
    send: 41-41-33-0 s=0,c=1,t=0,pt=7,l=5,st=ok:30.6
    send: 41-41-33-0 s=0,c=1,t=0,pt=7,l=5,st=ok:31.1
    send: 41-41-33-0 s=0,c=1,t=0,pt=7,l=5,st=ok:31.0
    send: 41-41-33-0 s=0,c=1,t=0,pt=7,l=5,st=ok:30.8
    send: 41-41-33-0 s=0,c=1,t=0,pt=7,l=5,st=ok:29.9
    send: 41-41-33-0 s=0,c=1,t=0,pt=7,l=5,st=ok:29.8
    send: 41-41-33-0 s=0,c=1,t=0,pt=7,l=5,st=ok:29.6
    send: 41-41-33-0 s=0,c=1,t=0,pt=7,l=5,st=ok:29.5
    send: 41-41-33-0 s=0,c=1,t=0,pt=7,l=5,st=ok:29.2
    send: 41-41-33-0 s=1,c=1,t=0,pt=7,l=5,st=ok:29.2
    send: 41-41-33-0 s=0,c=1,t=0,pt=7,l=5,st=ok:27.7
    send: 41-41-33-0 s=0,c=1,t=0,pt=7,l=5,st=ok:27.3
    send: 41-41-33-0 s=0,c=1,t=0,pt=7,l=5,st=ok:27.0
    send: 41-41-33-0 s=0,c=1,t=0,pt=7,l=5,st=ok:26.5
    read: 0-33-41 s=2,c=1,t=2,pt=0,l=1:0
    Incoming change for sensor:2, New status: 0
    send: 41-41-33-0 s=0,c=1,t=0,pt=7,l=5,st=ok:26.2
    send: 41-41-33-0 s=0,c=1,t=0,pt=7,l=5,st=ok:26.1
    send: 41-41-33-0 s=0,c=1,t=0,pt=7,l=5,st=ok:26.0
    send: 41-41-33-0 s=1,c=1,t=0,pt=7,l=5,st=ok:24.1
    send: 41-41-33-0 s=1,c=1,t=0,pt=7,l=5,st=ok:26.0
    send: 41-41-33-0 s=0,c=1,t=0,pt=7,l=5,st=ok:26.3
    send: 41-41-33-0 s=0,c=1,t=0,pt=7,l=5,st=ok:26.4
    send: 41-41-33-0 s=1,c=1,t=0,pt=7,l=5,st=ok:26.5
    send: 41-41-33-0 s=0,c=1,t=0,pt=7,l=5,st=ok:26.6
    send: 41-41-33-0 s=0,c=1,t=0,pt=7,l=5,st=ok:26.7
    send: 41-41-33-0 s=0,c=1,t=0,pt=7,l=5,st=ok:26.8
    send: 41-41-33-0 s=1,c=1,t=0,pt=7,l=5,st=ok:24.2
    send: 41-41-33-0 s=1,c=1,t=0,pt=7,l=5,st=ok:26.9
    send: 41-41-33-0 s=0,c=1,t=0,pt=7,l=5,st=ok:27.1
    send: 41-41-33-0 s=0,c=1,t=0,pt=7,l=5,st=ok:27.4
    send: 41-41-33-0 s=0,c=1,t=0,pt=7,l=5,st=ok:27.5
    send: 41-41-33-0 s=0,c=1,t=0,pt=7,l=5,st=ok:27.6
    send: 41-41-33-0 s=0,c=1,t=0,pt=7,l=5,st=ok:27.8
    send: 41-41-33-0 s=0,c=1,t=0,pt=7,l=5,st=ok:27.9
    send: 41-41-33-0 s=0,c=1,t=0,pt=7,l=5,st=ok:28.0
    send: 41-41-33-0 s=0,c=1,t=0,pt=7,l=5,st=ok:28.1
    send: 41-41-33-0 s=0,c=1,t=0,pt=7,l=5,st=ok:28.2
    send: 41-41-33-0 s=0,c=1,t=0,pt=7,l=5,st=ok:28.3
    send: 41-41-33-0 s=0,c=1,t=0,pt=7,l=5,st=ok:28.5
    send: 41-41-33-0 s=0,c=1,t=0,pt=7,l=5,st=ok:28.6
    send: 41-41-33-0 s=1,c=1,t=0,pt=7,l=5,st=ok:28.7
    send: 41-41-33-0 s=0,c=1,t=0,pt=7,l=5,st=ok:28.8
    send: 41-41-33-0 s=0,c=1,t=0,pt=7,l=5,st=ok:28.9
    send: 41-41-33-0 s=1,c=1,t=0,pt=7,l=5,st=ok:28.9
    send: 41-41-33-0 s=0,c=1,t=0,pt=7,l=5,st=ok:29.0
    send: 41-41-33-0 s=1,c=1,t=0,pt=7,l=5,st=ok:29.0
    send: 41-41-33-0 s=0,c=1,t=0,pt=7,l=5,st=ok:29.1
    send: 41-41-33-0 s=0,c=1,t=0,pt=7,l=5,st=ok:29.3
    send: 41-41-33-0 s=0,c=1,t=0,pt=7,l=5,st=ok:29.4
    send: 41-41-33-0 s=1,c=1,t=0,pt=7,l=5,st=ok:29.5
    send: 41-41-33-0 s=0,c=1,t=0,pt=7,l=5,st=ok:29.7
    send: 41-41-33-0 s=0,c=1,t=0,pt=7,l=5,st=ok:30.0
    send: 41-41-33-0 s=0,c=1,t=0,pt=7,l=5,st=ok:30.3
    As you can see, every once in a while S=1 reports the same value as S=0. I've tried to add a delay in the loop section, but without any luck. So now I'm stuck :(
    • BulldogLowellB
      BulldogLowellB
      BulldogLowell
      wrote on last edited by BulldogLowell
      @Hausner
      Even though you are converting to floats, these sensors still return integers, so you may be seeing the (not so obvious) limitations of the precision of the sensors.
      the numbers (if different) are close, so you should put a heat source near one (hair dryer?) to get them to be at a much bigger differential.
      Or return fahrenheit for one of the two like this:
      if (i == 0)
        float temperature = static_cast<float>(static_cast<int>sensors.getTempCByIndex(i)* 10.) / 10.;
      else
        float temperature = static_cast<float>(static_cast<int>sensors.getTempFByIndex(i)* 10.) / 10.;
      So you can really see what's happening.
