  3. OpenHAB
  4. openHAB 2.0 binding
openHAB 2.0 binding
534 Posts 88 Posters 675.9k Views 99 Watching
  • T TimO
    @rob There definitely is a problem with the link between node(s) and the gateway. This is not related to the binding / controller.
    Often this is related to a weak power supply.
    Do you have MySensors nodes already working with one of the gateways you've build?
    R
    R
    rob
    @TimO i powerd the gateway with a NAS server its usb port the pi its usb port more then enough power and with a wall socket adapter used for phones and a powered usb hub i also use for external hds and all gave me the same result nojoy
    • S
      stoffej
      Any progress? Since I also can not see the sensors after updating to openhab 2.1.
      S 1 Reply Last reply
      • S stoffej
        stoffej
        @stoffej ...fixed it ... I realised that the code in the sensors is waiting for the openhab to send a message to the sensor during startup of the sensor. So I had to add that into openhab..and now it works...
        • T TimO
          Hey @Nicklas-Starkel !
          Actually there is a PR for MQTT support which is a huge leap forward and needs testing: https://github.com/tobof/openhab2-addons/pull/75
          I'm 90% done on fulfilling the OH2 development compliance: https://github.com/openhab/openhab2-addons/pull/2066 which I'm working on since weeks (months). :o
          My road map is:
          1. Finish the work on the compliance. (Maybe this week, for sure next week)
          2. Move repository to 2.2.0 snapshot
          3. Integrate RGB(W)
          4. Integrate MQTT
          RGB(W) needs some more attention, because there is a bug in the conversion and it needs some more testing.
          The current work is a second refactoring with many changes. Also a few options (names) have changed which need some attention by the users because configurations need to be adjusted. Hopefully the names now speak more for itself. :-)
          I've also extended the JUnit Testing of the binding (which I'll need to quickly fix the RGB(W) bug).
          I need to catch up with the development of the openhab2-addons base. This is done after the OH2 compliance is done. At the moment I can't compile a MQTT testversion of the binding because the repository needs to be moved to 2.2.0 Snapshot.
          Sadly the process for OH2 compliance is at the moment blocking the enhancements of the binding. I had no idea this would take so long.
          TimO
          @TimO said in openHAB 2.0 binding:
          My road map is:
          Finish the work on the compliance. (Maybe this week, for sure next week) :white_check_mark:
          Move repository to 2.2.0 snapshot :white_check_mark:
          Integrate RGB(W)
          Integrate MQTT
          • T
            Timo Engelgeer
            wrote on last edited by Timo Engelgeer
            #505
            I'm trying to make a energy/Watt meter based on a ATM90E26 to send Watt, VAR, VA etc to OpenHab. But I'm running into two problems.
            First, not all channels show up in OpenHab. Only Watt, KWH (which should be named kWh), Battery level and Last Update show up from my S_POWER sensor. VAR, VA and PowerFactor are missing. Also V_VAR1 (the custom values) are not showing.
            Second problem is with decimal places. From my sensor I send a value with a decimal place. The log shows me:
            11074 TSF:MSG:SEND,2-2-0-0,s=1,c=1,t=38,pt=0,l=6,sg=0,ft=0,st=OK:236.16
            for a voltage of 236.16V. Only OpenHab ignores the decimal place most of the time. It just shows 236.0V. Somethings for a fraction of a second a non-zero decimal is shown.
            Both is with OpenHAB 2.0.0 and MySensors Binding 2.1.0
            T 1 Reply Last reply
            • T Timo Engelgeer
              TimO
              Hi @Timo-Engelgeer !
              1. KWH -> kWH.
              2. VAR, VA & Power Factor added.
              3. Decimal place: Did you check your item definition? kWH should be shown with two decimal places.
              4. Is it possible for you to use the CustomSensor with var1-var5 (with a separate childId)?
              Looks like this now in PaperUI:
              I'll push these changes with the next release I'm working on.
              • F
                F
                Fabien
                Since last update, I have to reinstall mysensors binding from IOT marketplace. But lot of warning when I'm starting :
                14:21:30.964 [WARN ] [.smarthome.config.core.Configuration] - Could not set field value for field 'nodeId': Can not set int field org.openhab.binding.mysensors.config.MySensorsSensorConfiguration.nodeId to java.lang.String
                java.lang.IllegalArgumentException: Can not set int field org.openhab.binding.mysensors.config.MySensorsSensorConfiguration.nodeId to java.lang.String
                	at sun.reflect.UnsafeFieldAccessorImpl.throwSetIllegalArgumentException(UnsafeFieldAccessorImpl.java:167)[:1.8.0_131]
                	at sun.reflect.UnsafeFieldAccessorImpl.throwSetIllegalArgumentException(UnsafeFieldAccessorImpl.java:171)[:1.8.0_131]
                	at sun.reflect.UnsafeIntegerFieldAccessorImpl.set(UnsafeIntegerFieldAccessorImpl.java:98)[:1.8.0_131]
                	at java.lang.reflect.Field.set(Field.java:764)[:1.8.0_131]
                	at org.apache.commons.lang.reflect.FieldUtils.writeField(FieldUtils.java:523)[30:org.apache.commons.lang:2.6.0]
                	at org.apache.commons.lang.reflect.FieldUtils.writeField(FieldUtils.java:500)[30:org.apache.commons.lang:2.6.0]
                	at org.apache.commons.lang.reflect.FieldUtils.writeField(FieldUtils.java:560)[30:org.apache.commons.lang:2.6.0]
                	at org.eclipse.smarthome.config.core.Configuration.as(Configuration.java:96)[94:org.eclipse.smarthome.config.core:0.9.0.201706270841]
                	at org.eclipse.smarthome.core.thing.binding.BaseThingHandler.getConfigAs(BaseThingHandler.java:248)[105:org.eclipse.smarthome.core.thing:0.9.0.201706270841]
                And now I can't control my shutters :
                14:22:11.672 [WARN ] [ensors.handler.MySensorsThingHandler] - Variable not found, cannot handle command for thing mysensors:cover:ESPgw:VoletBureau of type cover
                14:22:11.674 [INFO ] [smarthome.event.ItemCommandEvent    ] - Item 'VoletBureau' received command UP
                14:22:11.682 [INFO ] [marthome.event.ItemStateChangedEvent] - VoletBureau changed from NULL to 0
                14:22:13.198 [WARN ] [ensors.handler.MySensorsThingHandler] - Variable not found, cannot handle command for thing mysensors:cover:ESPgw:VoletBureau of type cover
                14:22:13.200 [INFO ] [smarthome.event.ItemCommandEvent    ] - Item 'VoletBureau' received command STOP
                14:22:14.063 [WARN ] [ensors.handler.MySensorsThingHandler] - Variable not found, cannot handle command for thing mysensors:cover:ESPgw:VoletBureau of type cover
                14:22:14.064 [INFO ] [smarthome.event.ItemCommandEvent    ] - Item 'VoletBureau' received command UP
                14:22:17.362 [DEBUG] [rsAbstractConnection$MySensorsReader] - Message from gateway received: 211;0;1;0;52;464.1
                bundle info :
                223 | Active   |  80 | 2.2.0.201707181152     | MySensors Binding
                • F Fabien
                  bundle info :
                  TimO
                  Hey @Fabien !
                  I've switched to a new release please look here for further information: https://forum.mysensors.org/topic/7176/openhab-2-2-binding
                  I've added a download link to the old version too in case you won't have time to change your configuration. ;-)
                  • F
                    F
                    Fabien
                    Thann you @TimO. I will try it.
                    • T
                      Timo Engelgeer
                      #510
                      @TimO Thanks for your answers!
                      1. The symbol for hour really is a small h ;) https://en.wikipedia.org/wiki/Kilowatt_hour
                      2. Great! And you'r right, it's indeed var, not VAR (weirdly enough...) Right on time for the demo :package:
                      3. I've lost where I can check that :no_mouth: But weird thing is, OpenHAB does show it with decimals, they're just zero most of the time...
                      4. Could do, I just used it with S_POWER because the MySensors doc said they should work with any device. Which I think does make sense in order not to cluther things with S_CUSTOMS. But then again, S_POWER having a V_VOLTAGE also makes sense :p
                      • T Timo Engelgeer
                        TimO
                        @Timo-Engelgeer
                        1. Yes, of course! It's changed by now.
                        2. Did you define something in the *.items file? "%d" instead of "%.2f" ?
                        3. It is very easy for me to add all var1-var5 channels to all things. It's just a litte copy & paste. The reason I've not done this so far is, that all channels are displayed and configured in the control section of the PaperUI (in simple mode). So if you've a temperature sensor, you additionally get: battery, lastUpdate, var1, var2, var3, var4 and var5. All of them can be disabled easily though.
                        • T
                          Timo Engelgeer
                          Heyy @TimO (are you really called the same as me?) Thanks for getting back to me!
                          1. Thanks!
                          2. Nope, for now I just used the simple mode so no .items file.
                          3. Yeah, I agree it can make it feel a bit more cluttered. But then again, battery is also not used in every device (and useless in wall powered sensors). Also other channels you might not use them all as well. For example, I use S_MULTIMETER for voltage and current (because weirdly S_POWER lacks that) but impedance is an useless/meaningless channel here.
                          • FejiF
                            FejiF
                            Feji
                            This post is deleted!
                            • seeersS
                              seeersS
                              seeers
                              Hi, I use OpenHAB 2.1 with the OpenHAB 2.0 Binding on a Raspberry Pi with a serial RS485 gateway connected with a FTDI to USB. Sometimes the gateway freezes (at the moment i don´t know why). After pushing the reset button everything works for the next hours/days.
                              I´d like to reset the gateway automatically from openhab. Is it possible to reset the Gateway with this binding ? (Send DTR to the FTDI)
                              • seeersS seeers
                                TimO
                                Hi @seeers !
                                Interesting idea. I suppose the arduino IDE is doing this via avrdude and we won't be able to call avrdude from within the binding. If someone has an idea on how to reset an arduino via serial/usb from within java I could look into it.
                                G 1 Reply Last reply
                                • T TimO
                                  Hi @seeers !
                                  G
                                  G
                                  gonzalonal
                                  wrote on last edited by gonzalonal
                                  #516
                                  @TimO you just need to toggle the DTR line.
                                  Try:
                                  serialPort.setDTR(true);
                                  Thread.sleep(500);
                                  serialPort.open();
                                  serialPort.setDTR(false);
                                  • G gonzalonal
                                    Try:
                                    Thread.sleep(500);
                                    serialPort.open();
                                    TimO
                                    @gonzalonal Thanks for the hint!
                                    For that a switch of NRSerial library to SerialPort is neccessary. A first try looks promising, but I'm not able to test it against hardware yet. Maybe @seeers might give it a try:
                                    JAR-File
                                    I've tested with the following bridge configuration:
                                    Bridge mysensors:bridge-ser:gateway [ serialPort="/dev/pts/20", hardReset=false, sendDelay=200, startupCheckEnabled=true, networkSanCheckEnabled=true, networkSanCheckInterval=1, networkSanCheckConnectionFailAttempts=1 ] {
                                    The sanity check needs to fail two times. After that it will try to disconnect (and do the hardReset via DTR) and reconnect.
                                    Log (in debug) should look like:
                                    [DEBUG] [.p.s.MySensorsSerialConnection:138  ] - Trying to reset of attached gateway with DTR
                                    [DEBUG] [.p.s.MySensorsSerialConnection:146  ] - Finished reset of attached gateway with DTR
                                    I suppose only FTDI based gateways will react on that? What about sensebender gateway?
                                    • seeersS
                                      seeersS
                                      seeers
                                      Thanks for the suggestions and the change. Maybe it`s not necessary. Today I could observe how the gateway was rebooted by openhab by Shutting down the serial connection.
                                      I have added a "heartbeat" to my gateway, every minute a Serial.writeline "State:OK". Of course an exception appears in the openhab binding... I do not understand why the binding was down: ...Shutting down serial connection!...
                                      11:29:43.176 [DEBUG] [rsAbstractConnection$MySensorsReader] - Message from gateway received: State:OK
                                      11:29:43.177 [WARN ] [rsAbstractConnection$MySensorsReader] - Exception on reading from connection
                                      java.text.ParseException: class java.text.ParseException : Message length is not > 4   .....
                                      11:29:43.181 [DEBUG] [col.serial.MySensorsSerialConnection] - Request disconnection flag setted to: true
                                      11:29:44.873 [INFO ] [col.serial.MySensorsSerialConnection] - Connection request disconnection...
                                      11:29:44.874 [DEBUG] [col.serial.MySensorsSerialConnection] - Request disconnection flag setted to: false
                                      11:29:44.874 [DEBUG] [col.serial.MySensorsSerialConnection] - Shutting down serial connection!
                                      11:29:44.875 [DEBUG] [rsAbstractConnection$MySensorsWriter] - Stopping Writer thread
                                      11:29:44.876 [WARN ] [rsAbstractConnection$MySensorsWriter] - Interrupted MySensorsWriter
                                      11:29:44.877 [DEBUG] [rsAbstractConnection$MySensorsReader] - Stopping Reader thread
                                      11:29:44.882 [WARN ] [rsAbstractConnection$MySensorsReader] - Interrupted MySensorsReader
                                      11:29:44.901 [INFO ] [me.event.ThingStatusInfoChangedEvent] - 'mysensors:temperature:gateway:Temp_OG_KSued_2' changed from ONLINE to OFFLINE (COMMUNICATION_ERROR)
                                      11:29:44.905 [INFO ] [me.event.ThingStatusInfoChangedEvent] - 'mysensors:humidity:gateway:Hum__OG_KSued' changed from ONLINE to OFFLINE (COMMUNICATION_ERROR)
                                      11:29:48.132 [DEBUG] [rsAbstractConnection$MySensorsReader] - Message from gateway received: 0;255;3;0;14;Gateway startup complete.
                                      11:29:48.132 [INFO ] [rs.internal.gateway.MySensorsGateway] - Node 0 available again!
                                      11:29:48.133 [DEBUG] [rsAbstractConnection$MySensorsReader] - Message from gateway received: 0;255;0;0;18;2.1.1
                                      11:29:48.133 [WARN ] [col.serial.MySensorsSerialConnection] - Skipping I_VERSION connection test, not recommended...
                                      11:29:48.137 [DEBUG] [ensors.factory.MySensorsCacheFactory] - Writing on cache given_ids, content: [0,32,1,33,34,35,11,12,13,14,21,22,23,24,26,27,31]
                                      11:29:48.138 [INFO ] [col.serial.MySensorsSerialConnection] - Successfully connected to MySensors Bridge.
                                      11:29:48.138 [DEBUG] [rs.internal.gateway.MySensorsGateway] - Presentation Message received
                                      11:29:48.138 [DEBUG] [ensors.handler.MySensorsThingHandler] - MySensors Bridge Status updated to ONLINE for device: mysensors:temperature:gateway:Temp_KG_Flur_1
                                      11:29:48.140 [DEBUG] [ensors.handler.MySensorsThingHandler] - MySensors Bridge Status updated to ONLINE for device: mysensors:humidity:gateway:Hum__KG_Wasch
                                      11:29:48.142 [INFO ] [me.event.ThingStatusInfoChangedEvent] - 'mysensors:bridge-ser:gateway' changed from OFFLINE to ONLINE
                                      • S
                                        stolly82
                                        • S
                                          stolly82
                                          wrote on last edited by stolly82
                                          #520
                                          Dear together,
                                          I can´t find out, why one things are not working if I save another thing with the same NodeID but different ChildID.
                                          Example:
                                          I have two things, one button and one door sensor.
                                          The button is working until I add a new thing with the same nodeID (Relay).
                                          If I save the button again, it´s working again but the Relay isn´t working again.
                                          21:07:58.514 [INFO ] [smarthome.event.ThingUpdatedEvent   ] - Thing 'mysensors:light:Relais_Wohnzimmer_hinten_1' has been updated.
                                          21:07:58.518 [DEBUG] [rs.internal.gateway.MySensorsGateway] - Adding device MySensorsNode [nodeId=16, childNumber=1, chidldList={1=MySensorsChild [childId=1, nodeValue={V_WATT=MySensorsVariableVWatt [value=null], V_STATUS=MySensorsVariableVStatus [value=null], V_VAR2=MySensorsVariableVVar2 [value=null], V_VAR1=MySensorsVariableVVar1 [value=null], V_VAR3=MySensorsVariableVVar3 [value=null], V_VAR4=MySensorsVariableVVar4 [value=null], V_VAR5=MySensorsVariableVVar5 [value=null]}]}]
                                          21:07:58.520 [DEBUG] [ensors.handler.MySensorsThingHandler] - Event listener for node 16-1 not registered yet, registering...
                                          21:08:00.332 [DEBUG] [rsAbstractConnection$MySensorsReader] - Message from gateway received: 14;2;1;0;16;1
                                          21:08:00.337 [DEBUG] [rs.internal.gateway.MySensorsGateway] - Node 14 found in gateway
                                          21:08:00.347 [DEBUG] [rs.internal.gateway.MySensorsGateway] - Child 2 found in node 14
                                          21:08:00.352 [DEBUG] [ensors.handler.MySensorsThingHandler] - Updating channel: tripped(V_TRIPPED) value to: OPEN
                                          21:08:00.370 [DEBUG] [ensors.handler.MySensorsThingHandler] - Setting last update for node/child 14/2 to 2017-09-09T21:08:00.000+0200
                                          21:08:10.860 [DEBUG] [rsAbstractConnection$MySensorsReader] - Message from gateway received: 16;2;1;0;16;0
                                          21:08:10.865 [DEBUG] [rs.internal.gateway.MySensorsGateway] - Node 16 found in gateway
                                          21:08:10.869 [DEBUG] [rs.internal.gateway.MySensorsGateway] - Child 2 not present in node 16
                                          21:08:10.944 [DEBUG] [rsAbstractConnection$MySensorsReader] - Message from gateway received: 16;2;1;0;16;1
                                          21:08:10.949 [DEBUG] [rs.internal.gateway.MySensorsGateway] - Node 16 found in gateway
                                          21:08:10.952 [DEBUG] [rs.internal.gateway.MySensorsGateway] - Child 2 not present in node 16
                                          21:08:11.012 [DEBUG] [rsAbstractConnection$MySensorsReader] - Message from gateway received: 14;2;1;0;16;1
                                          21:08:11.016 [DEBUG] [rs.internal.gateway.MySensorsGateway] - Node 14 found in gateway
                                          21:08:11.019 [DEBUG] [rs.internal.gateway.MySensorsGateway] - Child 2 found in node 14
                                          21:08:11.022 [DEBUG] [ensors.handler.MySensorsThingHandler] - Updating channel: tripped(V_TRIPPED) value to: OPEN
                                          21:08:11.050 [DEBUG] [ensors.handler.MySensorsThingHandler] - Setting last update for node/child 14/2 to 2017-09-09T21:08:11.000+0200
                                          21:08:11.241 [DEBUG] [rsAbstractConnection$MySensorsReader] - Message from gateway received: 16;1;1;0;2;1
                                          21:08:11.247 [DEBUG] [rs.internal.gateway.MySensorsGateway] - Node 16 found in gateway
                                          21:08:11.251 [DEBUG] [rs.internal.gateway.MySensorsGateway] - Child 1 found in node 16
                                          21:08:11.254 [DEBUG] [ensors.handler.MySensorsThingHandler] - Updating channel: status(V_STATUS) value to: ON
                                          21:08:11.271 [DEBUG] [ensors.handler.MySensorsThingHandler] - Setting last update for node/child 16/1 to 2017-09-09T21:08:11.000+0200
                                          21:08:11.275 [DEBUG] [ensors.handler.MySensorsThingHandler] - Updating channel: status(V_STATUS) value to: ON
                                          21:08:11.292 [INFO ] [marthome.event.ItemStateChangedEvent] - Switch_Wohnzimmer_hinten_1 changed from OFF to ON
                                          21:08:11.295 [DEBUG] [ensors.handler.MySensorsThingHandler] - Setting last update for node/child 16/1 to 2017-09-09T21:08:11.000+0200
                                          21:08:12.196 [DEBUG] [rsAbstractConnection$MySensorsReader] - Message from gateway received: 16;1;1;0;2;0
                                          21:08:12.199 [DEBUG] [rs.internal.gateway.MySensorsGateway] - Node 16 found in gateway
                                          21:08:12.201 [DEBUG] [rs.internal.gateway.MySensorsGateway] - Child 1 found in node 16
                                          21:08:12.204 [DEBUG] [ensors.handler.MySensorsThingHandler] - Updating channel: status(V_STATUS) value to: OFF
                                          21:08:12.219 [DEBUG] [ensors.handler.MySensorsThingHandler] - Setting last update for node/child 16/1 to 2017-09-09T21:08:12.000+0200
                                          21:08:12.222 [DEBUG] [ensors.handler.MySensorsThingHandler] - Updating channel: status(V_STATUS) value to: OFF
                                          21:08:12.239 [INFO ] [marthome.event.ItemStateChangedEvent] - Switch_Wohnzimmer_hinten_1 changed from ON to OFF
                                          21:08:12.242 [DEBUG] [ensors.handler.MySensorsThingHandler] - Setting last update for node/child 16/1 to 2017-09-09T21:08:12.000+0200
                                          21:08:14.093 [DEBUG] [rsAbstractConnection$MySensorsReader] - Message from gateway received: 16;1;1;0;2;1
                                          21:08:14.097 [DEBUG] [rs.internal.gateway.MySensorsGateway] - Node 16 found in gateway
                                          21:08:14.099 [DEBUG] [rs.internal.gateway.MySensorsGateway] - Child 1 found in node 16
                                          21:08:14.101 [DEBUG] [ensors.handler.MySensorsThingHandler] - Updating channel: status(V_STATUS) value to: ON
                                          21:08:14.118 [DEBUG] [ensors.handler.MySensorsThingHandler] - Setting last update for node/child 16/1 to 2017-09-09T21:08:14.000+0200
                                          21:08:14.121 [DEBUG] [ensors.handler.MySensorsThingHandler] - Updating channel: status(V_STATUS) value to: ON
                                          21:08:14.137 [INFO ] [marthome.event.ItemStateChangedEvent] - Switch_Wohnzimmer_hinten_1 changed from OFF to ON
                                          21:08:14.147 [DEBUG] [ensors.handler.MySensorsThingHandler] - Setting last update for node/child 16/1 to 2017-09-09T21:08:14.000+0200
                                          21:08:14.574 [DEBUG] [rsAbstractConnection$MySensorsReader] - Message from gateway received: 16;1;1;0;2;0
                                          21:08:14.578 [DEBUG] [rs.internal.gateway.MySensorsGateway] - Node 16 found in gateway
                                          21:08:14.581 [DEBUG] [rs.internal.gateway.MySensorsGateway] - Child 1 found in node 16
                                          21:08:14.584 [DEBUG] [ensors.handler.MySensorsThingHandler] - Updating channel: status(V_STATUS) value to: OFF
                                          21:08:14.603 [DEBUG] [ensors.handler.MySensorsThingHandler] - Setting last update for node/child 16/1 to 2017-09-09T21:08:14.000+0200
                                          21:08:14.607 [DEBUG] [ensors.handler.MySensorsThingHandler] - Updating channel: status(V_STATUS) value to: OFF
                                          21:08:14.628 [INFO ] [marthome.event.ItemStateChangedEvent] - Switch_Wohnzimmer_hinten_1 changed from ON to OFF
                                          21:08:14.632 [DEBUG] [ensors.handler.MySensorsThingHandler] - Setting last update for node/child 16/1 to 2017-09-09T21:08:14.000+0200
                                          21:08:15.823 [DEBUG] [rsAbstractConnection$MySensorsReader] - Message from gateway received: 0;255;3;0;2;2.1.1
                                          21:08:20.282 [DEBUG] [rsAbstractConnection$MySensorsReader] - Message from gateway received: 14;2;1;0;16;1
                                          21:08:20.286 [DEBUG] [rs.internal.gateway.MySensorsGateway] - Node 14 found in gateway
                                          21:08:20.290 [DEBUG] [rs.internal.gateway.MySensorsGateway] - Child 2 found in node 14
                                          21:08:20.293 [DEBUG] [ensors.handler.MySensorsThingHandler] - Updating channel: tripped(V_TRIPPED) value to: OPEN
                                          21:08:20.319 [DEBUG] [ensors.handler.MySensorsThingHandler] - Setting last update for node/child 14/2 to 2017-09-09T21:08:20.000+0200
                                          21:08:21.117 [DEBUG] [rsAbstractConnection$MySensorsReader] - Message from gateway received: 16;2;1;0;16;0
                                          21:08:21.122 [DEBUG] [rs.internal.gateway.MySensorsGateway] - Node 16 found in gateway
                                          21:08:21.126 [DEBUG] [rs.internal.gateway.MySensorsGateway] - Child 2 not present in node 16
                                          21:08:21.232 [DEBUG] [rsAbstractConnection$MySensorsReader] - Message from gateway received: 16;2;1;0;16;1
                                          21:08:21.237 [DEBUG] [rs.internal.gateway.MySensorsGateway] - Node 16 found in gateway
                                          21:08:21.243 [DEBUG] [rs.internal.gateway.MySensorsGateway] - Child 2 not present in node 16
                                          21:08:22.162 [DEBUG] [rsAbstractConnection$MySensorsReader] - Message from gateway received: 16;2;1;0;16;0
                                          21:08:22.168 [DEBUG] [rs.internal.gateway.MySensorsGateway] - Node 16 found in gateway
                                          21:08:22.174 [DEBUG] [rs.internal.gateway.MySensorsGateway] - Child 2 not present in node 16
                                          21:08:22.592 [DEBUG] [rsAbstractConnection$MySensorsReader] - Message from gateway received: 16;2;1;0;16;1
                                          21:08:22.596 [DEBUG] [rs.internal.gateway.MySensorsGateway] - Node 16 found in gateway
                                          21:08:22.599 [DEBUG] [rs.internal.gateway.MySensorsGateway] - Child 2 not present in node 16
                                          21:08:23.331 [DEBUG] [rsAbstractConnection$MySensorsReader] - Message from gateway received: 16;2;1;0;16;0
                                          21:08:23.334 [DEBUG] [rs.internal.gateway.MySensorsGateway] - Node 16 found in gateway
                                          21:08:23.337 [DEBUG] [rs.internal.gateway.MySensorsGateway] - Child 2 not present in node 16
                                          21:08:23.491 [DEBUG] [rsAbstractConnection$MySensorsReader] - Message from gateway received: 16;2;1;0;16;1
                                          21:08:23.495 [DEBUG] [rs.internal.gateway.MySensorsGateway] - Node 16 found in gateway
                                          21:08:23.506 [DEBUG] [rs.internal.gateway.MySensorsGateway] - Child 2 not present in node 16
                                          21:08:30.411 [DEBUG] [rsAbstractConnection$MySensorsReader] - Message from gateway received: 14;2;1;0;16;1
                                          21:08:30.414 [DEBUG] [rs.internal.gateway.MySensorsGateway] - Node 14 found in gateway
                                          21:08:30.417 [DEBUG] [rs.internal.gateway.MySensorsGateway] - Child 2 found in node 14
                                          21:08:30.421 [DEBUG] [ensors.handler.MySensorsThingHandler] - Updating channel: tripped(V_TRIPPED) value to: OPEN
                                          21:08:30.447 [DEBUG] [ensors.handler.MySensorsThingHandler] - Setting last update for node/child 14/2 to 2017-09-09T21:08:30.000+0200
                                          21:08:40.313 [DEBUG] [rsAbstractConnection$MySensorsReader] - Message from gateway received: 14;2;1;0;16;1
                                          21:08:40.317 [DEBUG] [rs.internal.gateway.MySensorsGateway] - Node 14 found in gateway
                                          21:08:40.326 [DEBUG] [rs.internal.gateway.MySensorsGateway] - Child 2 found in node 14
                                          21:08:40.330 [DEBUG] [ensors.handler.MySensorsThingHandler] - Updating channel: tripped(V_TRIPPED) value to: OPEN
                                          21:08:40.352 [DEBUG] [ensors.handler.MySensorsThingHandler] - Setting last update for node/child 14/2 to 2017-09-09T21:08:40.000+0200
                                          21:08:50.328 [DEBUG] [rsAbstractConnection$MySensorsReader] - Message from gateway received: 14;2;1;0;16;1
                                          21:08:50.332 [DEBUG] [rs.internal.gateway.MySensorsGateway] - Node 14 found in gateway
                                          21:08:50.337 [DEBUG] [rs.internal.gateway.MySensorsGateway] - Child 2 found in node 14
                                          21:08:50.342 [DEBUG] [ensors.handler.MySensorsThingHandler] - Updating channel: tripped(V_TRIPPED) value to: OPEN
                                          21:08:50.367 [DEBUG] [ensors.handler.MySensorsThingHandler] - Setting last update for node/child 14/2 to 2017-09-09T21:08:50.000+0200
                                          21:08:55.944 [DEBUG] [rsAbstractConnection$MySensorsReader] - Message from gateway received: 1;5;1;0;18;4653.2749
                                          21:08:55.950 [DEBUG] [rs.internal.gateway.MySensorsGateway] - Node 1 found in gateway
                                          21:08:55.954 [DEBUG] [rs.internal.gateway.MySensorsGateway] - Child 5 found in node 1
                                          21:08:55.959 [DEBUG] [ensors.handler.MySensorsThingHandler] - Updating channel: kwh(V_KWH) value to: 4653.2749
                                          21:08:55.978 [INFO ] [marthome.event.ItemStateChangedEvent] - Stromzaeler_K changed from 4653.1982 to 4653.2749
                                          21:08:55.983 [DEBUG] [ensors.handler.MySensorsThingHandler] - Setting last update for node/child 1/5 to 2017-09-09T21:08:55.000+0200
                                          21:09:00.403 [DEBUG] [rsAbstractConnection$MySensorsReader] - Message from gateway received: 14;2;1;0;16;1
                                          21:09:00.409 [DEBUG] [rs.internal.gateway.MySensorsGateway] - Node 14 found in gateway
                                          21:09:00.413 [DEBUG] [rs.internal.gateway.MySensorsGateway] - Child 2 found in node 14
                                          21:09:00.418 [DEBUG] [ensors.handler.MySensorsThingHandler] - Updating channel: tripped(V_TRIPPED) value to: OPEN
                                          21:09:00.449 [DEBUG] [ensors.handler.MySensorsThingHandler] - Setting last update for node/child 14/2 to 2017-09-09T21:09:00.000+0200
                                          21:09:10.370 [DEBUG] [rsAbstractConnection$MySensorsReader] - Message from gateway received: 14;2;1;0;16;1
                                          21:09:10.375 [DEBUG] [rs.internal.gateway.MySensorsGateway] - Node 14 found in gateway
                                          21:09:10.378 [DEBUG] [rs.internal.gateway.MySensorsGateway] - Child 2 found in node 14
                                          21:09:10.382 [DEBUG] [ensors.handler.MySensorsThingHandler] - Updating channel: tripped(V_TRIPPED) value to: OPEN
                                          21:09:10.411 [DEBUG] [ensors.handler.MySensorsThingHandler] - Setting last update for node/child 14/2 to 2017-09-09T21:09:10.000+0200
                                          21:09:15.971 [DEBUG] [rsAbstractConnection$MySensorsReader] - Message from gateway received: 1;5;1;0;24;6979929
                                          21:09:15.974 [DEBUG] [rs.internal.gateway.MySensorsGateway] - Node 1 found in gateway
                                          21:09:15.977 [DEBUG] [rs.internal.gateway.MySensorsGateway] - Child 5 found in node 1
                                          21:09:15.980 [DEBUG] [ensors.handler.MySensorsThingHandler] - Updating channel: var1(V_VAR1) value to: 6979929
                                          21:09:15.998 [DEBUG] [ensors.handler.MySensorsThingHandler] - Setting last update for node/child 1/5 to 2017-09-09T21:09:15.000+0200
                                          21:09:16.193 [DEBUG] [rsAbstractConnection$MySensorsReader] - Message from gateway received: 1;5;1;0;18;4653.2866
                                          21:09:16.196 [DEBUG] [rs.internal.gateway.MySensorsGateway] - Node 1 found in gateway
                                          21:09:16.198 [DEBUG] [rs.internal.gateway.MySensorsGateway] - Child 5 found in node 1
                                          21:09:16.203 [DEBUG] [ensors.handler.MySensorsThingHandler] - Updating channel: kwh(V_KWH) value to: 4653.2866
                                          21:09:16.221 [INFO ] [marthome.event.ItemStateChangedEvent] - Stromzaeler_K changed from 4653.2749 to 4653.2866
                                          21:09:16.233 [DEBUG] [ensors.handler.MySensorsThingHandler] - Setting last update for node/child 1/5 to 2017-09-09T21:09:16.000+0200
                                          21:09:16.296 [DEBUG] [rsAbstractConnection$MySensorsReader] - Message from gateway received: 0;255;3;0;2;2.1.1
                                          21:09:20.390 [DEBUG] [rsAbstractConnection$MySensorsReader] - Message from gateway received: 14;2;1;0;16;1
                                          21:09:20.394 [DEBUG] [rs.internal.gateway.MySensorsGateway] - Node 14 found in gateway
                                          21:09:20.398 [DEBUG] [rs.internal.gateway.MySensorsGateway] - Child 2 found in node 14
                                          21:09:20.402 [DEBUG] [ensors.handler.MySensorsThingHandler] - Updating channel: tripped(V_TRIPPED) value to: OPEN
                                          21:09:20.424 [DEBUG] [ensors.handler.MySensorsThingHandler] - Setting last update for node/child 14/2 to 2017-09-09T21:09:20.000+0200
                                          21:09:30.464 [DEBUG] [rsAbstractConnection$MySensorsReader] - Message from gateway received: 14;2;1;0;16;1
                                          21:09:30.470 [DEBUG] [rs.internal.gateway.MySensorsGateway] - Node 14 found in gateway
                                          21:09:30.475 [DEBUG] [rs.internal.gateway.MySensorsGateway] - Child 2 found in node 14
                                          21:09:30.481 [DEBUG] [ensors.handler.MySensorsThingHandler] - Updating channel: tripped(V_TRIPPED) value to: OPEN
                                          21:09:30.510 [DEBUG] [ensors.handler.MySensorsThingHandler] - Setting last update for node/child 14/2 to 2017-09-09T21:09:30.000+0200
                                          21:09:40.469 [DEBUG] [rsAbstractConnection$MySensorsReader] - Message from gateway received: 14;2;1;0;16;1
                                          21:09:40.473 [DEBUG] [rs.internal.gateway.MySensorsGateway] - Node 14 found in gateway
                                          21:09:40.477 [DEBUG] [rs.internal.gateway.MySensorsGateway] - Child 2 found in node 14
                                          21:09:40.482 [DEBUG] [ensors.handler.MySensorsThingHandler] - Updating channel: tripped(V_TRIPPED) value to: OPEN
                                          21:09:40.505 [DEBUG] [ensors.handler.MySensorsThingHandler] - Setting last update for node/child 14/2 to 2017-09-09T21:09:40.000+0200
                                          21:10:00.627 [DEBUG] [rsAbstractConnection$MySensorsReader] - Message from gateway received: 14;2;1;0;16;1
                                          21:10:00.629 [DEBUG] [rs.internal.gateway.MySensorsGateway] - Node 14 found in gateway
                                          21:10:00.634 [DEBUG] [rs.internal.gateway.MySensorsGateway] - Child 2 found in node 14
                                          21:10:00.640 [DEBUG] [ensors.handler.MySensorsThingHandler] - Updating channel: tripped(V_TRIPPED) value to: OPEN
                                          21:10:00.666 [DEBUG] [ensors.handler.MySensorsThingHandler] - Setting last update for node/child 14/2 to 2017-09-09T21:10:00.000+0200
                                          21:10:10.690 [DEBUG] [rsAbstractConnection$MySensorsReader] - Message from gateway received: 14;2;1;0;16;1
                                          21:10:10.696 [DEBUG] [rs.internal.gateway.MySensorsGateway] - Node 14 found in gateway
                                          21:10:10.701 [DEBUG] [rs.internal.gateway.MySensorsGateway] - Child 2 found in node 14
                                          21:10:10.707 [DEBUG] [ensors.handler.MySensorsThingHandler] - Updating channel: tripped(V_TRIPPED) value to: OPEN
                                          21:10:10.749 [DEBUG] [ensors.handler.MySensorsThingHandler] - Setting last update for node/child 14/2 to 2017-09-09T21:10:10.000+0200
                                          21:10:15.893 [DEBUG] [rsAbstractConnection$MySensorsReader] - Message from gateway received: 0;255;3;0;2;2.1.1
                                          21:10:17.669 [DEBUG] [rsAbstractConnection$MySensorsReader] - Message from gateway received: 1;5;1;0;18;4653.3081
                                          21:10:17.673 [DEBUG] [rs.internal.gateway.MySensorsGateway] - Node 1 found in gateway
                                          21:10:17.675 [DEBUG] [rs.internal.gateway.MySensorsGateway] - Child 5 found in node 1
                                          21:10:17.678 [DEBUG] [ensors.handler.MySensorsThingHandler] - Updating channel: kwh(V_KWH) value to: 4653.3081
                                          21:10:17.702 [DEBUG] [ensors.handler.MySensorsThingHandler] - Setting last update for node/child 1/5 to 2017-09-09T21:10:17.000+0200
                                          21:10:17.703 [INFO ] [marthome.event.ItemStateChangedEvent] - Stromzaeler_K changed from 4653.2866 to 4653.3081
                                          21:10:20.537 [DEBUG] [rsAbstractConnection$MySensorsReader] - Message from gateway received: 14;2;1;0;16;1
                                          21:10:20.541 [DEBUG] [rs.internal.gateway.MySensorsGateway] - Node 14 found in gateway
                                          21:10:20.546 [DEBUG] [rs.internal.gateway.MySensorsGateway] - Child 2 found in node 14
                                          21:10:20.551 [DEBUG] [ensors.handler.MySensorsThingHandler] - Updating channel: tripped(V_TRIPPED) value to: OPEN
                                          21:10:20.590 [DEBUG] [ensors.handler.MySensorsThingHandler] - Setting last update for node/child 14/2 to 2017-09-09T21:10:20.000+0200
                                          21:10:30.566 [DEBUG] [rsAbstractConnection$MySensorsReader] - Message from gateway received: 14;2;1;0;16;1
                                          21:10:30.569 [DEBUG] [rs.internal.gateway.MySensorsGateway] - Node 14 found in gateway
                                          21:10:30.576 [DEBUG] [rs.internal.gateway.MySensorsGateway] - Child 2 found in node 14
                                          21:10:30.582 [DEBUG] [ensors.handler.MySensorsThingHandler] - Updating channel: tripped(V_TRIPPED) value to: OPEN
                                          21:10:30.602 [DEBUG] [ensors.handler.MySensorsThingHandler] - Setting last update for node/child 14/2 to 2017-09-09T21:10:30.000+0200
                                          21:10:34.691 [DEBUG] [ensors.handler.MySensorsThingHandler] - Configuation update for thing 16-2: {nodeUpdateTimeout=-1, smartSleep=false, requestHeartbeatResponse=false, childUpdateTimeout=-1, childId=2, nodeId=16, revertState=true, requestAck=false}
                                          21:10:34.727 [INFO ] [smarthome.event.ThingUpdatedEvent   ] - Thing 'mysensors:door:Button_Wohnzimmer_1' has been updated.
                                          21:10:34.726 [DEBUG] [ensors.handler.MySensorsThingHandler] - Configuration: MySensorsSensorConfiguration [nodeId=16, childId=2, requestAck=false, revertState=true, smartSleep=false, childUpdateTimeout=-1, nodeUpdateTimeout=-1, requestHeartbeatResponse=false]
                                          21:10:34.740 [DEBUG] [rs.internal.gateway.MySensorsGateway] - Adding device MySensorsNode [nodeId=16, childNumber=1, chidldList={2=MySensorsChild [childId=2, nodeValue={V_VAR2=MySensorsVariableVVar2 [value=null], V_VAR1=MySensorsVariableVVar1 [value=null], V_TRIPPED=MySensorsVariableVTripped [value=null], V_VAR3=MySensorsVariableVVar3 [value=null], V_VAR4=MySensorsVariableVVar4 [value=null], V_VAR5=MySensorsVariableVVar5 [value=null], V_ARMED=MySensorsVariableVArmed [value=null]}]}]
                                          21:10:34.752 [DEBUG] [ensors.handler.MySensorsThingHandler] - Event listener for node 16-2 not registered yet, registering...
                                          21:10:37.699 [DEBUG] [rsAbstractConnection$MySensorsReader] - Message from gateway received: 1;5;1;0;24;6979975
                                          21:10:37.704 [DEBUG] [rs.internal.gateway.MySensorsGateway] - Node 1 found in gateway
                                          21:10:37.709 [DEBUG] [rs.internal.gateway.MySensorsGateway] - Child 5 found in node 1
                                          21:10:37.714 [DEBUG] [ensors.handler.MySensorsThingHandler] - Updating channel: var1(V_VAR1) value to: 6979975
                                          21:10:37.734 [DEBUG] [ensors.handler.MySensorsThingHandler] - Setting last update for node/child 1/5 to 2017-09-09T21:10:37.000+0200
                                          21:10:37.821 [DEBUG] [rsAbstractConnection$MySensorsReader] - Message from gateway received: 1;5;1;0;18;4653.3169
                                          21:10:37.827 [DEBUG] [rs.internal.gateway.MySensorsGateway] - Node 1 found in gateway
                                          21:10:37.833 [DEBUG] [rs.internal.gateway.MySensorsGateway] - Child 5 found in node 1
                                          21:10:37.839 [DEBUG] [ensors.handler.MySensorsThingHandler] - Updating channel: kwh(V_KWH) value to: 4653.3169
                                          21:10:37.859 [INFO ] [marthome.event.ItemStateChangedEvent] - Stromzaeler_K changed from 4653.3081 to 4653.3169
                                          21:10:37.875 [DEBUG] [ensors.handler.MySensorsThingHandler] - Setting last update for node/child 1/5 to 2017-09-09T21:10:37.000+0200
                                          21:10:40.611 [DEBUG] [rsAbstractConnection$MySensorsReader] - Message from gateway received: 14;2;1;0;16;1
                                          21:10:40.616 [DEBUG] [rs.internal.gateway.MySensorsGateway] - Node 14 found in gateway
                                          21:10:40.621 [DEBUG] [rs.internal.gateway.MySensorsGateway] - Child 2 found in node 14
                                          21:10:40.626 [DEBUG] [ensors.handler.MySensorsThingHandler] - Updating channel: tripped(V_TRIPPED) value to: OPEN
                                          21:10:40.647 [DEBUG] [ensors.handler.MySensorsThingHandler] - Setting last update for node/child 14/2 to 2017-09-09T21:10:40.000+0200
                                          21:10:46.592 [DEBUG] [rsAbstractConnection$MySensorsReader] - Message from gateway received: 16;1;1;0;2;1
                                          21:10:46.598 [DEBUG] [rs.internal.gateway.MySensorsGateway] - Node 16 found in gateway
                                          21:10:46.602 [DEBUG] [rs.internal.gateway.MySensorsGateway] - Child 1 not present in node 16
                                          21:10:48.047 [DEBUG] [rsAbstractConnection$MySensorsReader] - Message from gateway received: 16;1;1;0;2;0
                                          21:10:48.052 [DEBUG] [rs.internal.gateway.MySensorsGateway] - Node 16 found in gateway
                                          21:10:48.056 [DEBUG] [rs.internal.gateway.MySensorsGateway] - Child 1 not present in node 16
                                          21:10:50.179 [DEBUG] [rsAbstractConnection$MySensorsReader] - Message from gateway received: 16;2;1;0;16;0
                                          21:10:50.184 [DEBUG] [rs.internal.gateway.MySensorsGateway] - Node 16 found in gateway
                                          21:10:50.186 [DEBUG] [rs.internal.gateway.MySensorsGateway] - Child 2 found in node 16
                                          21:10:50.188 [DEBUG] [ensors.handler.MySensorsThingHandler] - Updating channel: tripped(V_TRIPPED) value to: CLOSED
                                          21:10:50.200 [INFO ] [marthome.event.ItemStateChangedEvent] - Switch_Wohnzimmer_hinten_2 changed from OPEN to CLOSED
                                          21:10:50.204 [DEBUG] [ensors.handler.MySensorsThingHandler] - Setting last update for node/child 16/2 to 2017-09-09T21:10:50.000+0200
                                          21:10:50.387 [DEBUG] [rsAbstractConnection$MySensorsReader] - Message from gateway received: 16;2;1;0;16;1
                                          21:10:50.389 [DEBUG] [rs.internal.gateway.MySensorsGateway] - Node 16 found in gateway
                                          21:10:50.391 [DEBUG] [rs.internal.gateway.MySensorsGateway] - Child 2 found in node 16
                                          21:10:50.393 [DEBUG] [ensors.handler.MySensorsThingHandler] - Updating channel: tripped(V_TRIPPED) value to: OPEN
                                          21:10:50.413 [INFO ] [marthome.event.ItemStateChangedEvent] - Switch_Wohnzimmer_hinten_2 changed from CLOSED to OPEN
                                          21:10:50.422 [DEBUG] [ensors.handler.MySensorsThingHandler] - Setting last update for node/child 16/2 to 2017-09-09T21:10:50.000+0200
                                          21:10:50.616 [DEBUG] [rsAbstractConnection$MySensorsReader] - Message from gateway received: 14;2;1;0;16;1
                                          21:10:50.619 [DEBUG] [rs.internal.gateway.MySensorsGateway] - Node 14 found in gateway
                                          21:10:50.621 [DEBUG] [rs.internal.gateway.MySensorsGateway] - Child 2 found in node 14
                                          21:10:50.623 [DEBUG] [ensors.handler.MySensorsThingHandler] - Updating channel: tripped(V_TRIPPED) value to: OPEN
                                          21:10:50.665 [DEBUG] [ensors.handler.MySensorsThingHandler] - Setting last update for node/child 14/2 to 2017-09-09T21:10:50.000+0200
                                          21:11:00.858 [DEBUG] [rsAbstractConnection$MySensorsReader] - Message from gateway received: 14;2;1;0;16;1
                                          21:11:00.865 [DEBUG] [rs.internal.gateway.MySensorsGateway] - Node 14 found in gateway
                                          21:11:00.869 [DEBUG] [rs.internal.gateway.MySensorsGateway] - Child 2 found in node 14
                                          21:11:00.871 [DEBUG] [ensors.handler.MySensorsThingHandler] - Updating channel: tripped(V_TRIPPED) value to: OPEN
                                          21:11:00.889 [DEBUG] [ensors.handler.MySensorsThingHandler] - Setting last update for node/child 14/2 to 2017-09-09T21:11:00.000+0200
                                          And it´s really with any type of things like that. All nodes are working perfect in OH2 if I have only one childID as a thing. If I add the second the first is not longer working.
                                          21:37:34.353 [DEBUG] [rsAbstractConnection$MySensorsReader] - Message from gateway received: 14;2;1;0;16;1
                                          21:37:34.358 [DEBUG] [rs.internal.gateway.MySensorsGateway] - Node 14 found in gateway
                                          21:37:34.363 [DEBUG] [rs.internal.gateway.MySensorsGateway] - Child 2 not present in node 14
                                          21:37:44.381 [DEBUG] [rsAbstractConnection$MySensorsReader] - Message from gateway received: 14;2;1;0;16;1
                                          21:37:44.386 [DEBUG] [rs.internal.gateway.MySensorsGateway] - Node 14 found in gateway
                                          21:37:44.390 [DEBUG] [rs.internal.gateway.MySensorsGateway] - Child 2 not present in node 14
                                          21:37:54.400 [DEBUG] [rsAbstractConnection$MySensorsReader] - Message from gateway received: 14;2;1;0;16;1
                                          21:37:54.405 [DEBUG] [rs.internal.gateway.MySensorsGateway] - Node 14 found in gateway
                                          21:37:54.409 [DEBUG] [rs.internal.gateway.MySensorsGateway] - Child 2 not present in node 14
                                          21:38:04.417 [DEBUG] [rsAbstractConnection$MySensorsReader] - Message from gateway received: 14;2;1;0;16;1
                                          21:38:04.419 [DEBUG] [rs.internal.gateway.MySensorsGateway] - Node 14 found in gateway
                                          21:38:04.425 [DEBUG] [rs.internal.gateway.MySensorsGateway] - Child 2 not present in node 14
                                          21:38:10.730 [DEBUG] [rs.internal.gateway.MySensorsGateway] - Node 14 found in gateway
                                          21:38:10.738 [DEBUG] [rs.internal.gateway.MySensorsGateway] - Child 1 found in node 14
                                          21:38:10.738 [INFO ] [marthome.event.ItemStateChangedEvent] - Switch_Aussenstrahler_hinten changed from OFF to ON
                                          21:38:10.742 [DEBUG] [rsAbstractConnection$MySensorsWriter] - Sending to MySensors: 14;1;1;0;2;1
                                          21:38:10.744 [INFO ] [smarthome.event.ItemCommandEvent    ] - Item 'Switch_Aussenstrahler_hinten' received command ON
                                          21:38:13.428 [DEBUG] [rs.internal.gateway.MySensorsGateway] - Node 14 found in gateway
                                          21:38:13.430 [DEBUG] [rs.internal.gateway.MySensorsGateway] - Child 1 found in node 14
                                          21:38:13.432 [INFO ] [smarthome.event.ItemCommandEvent    ] - Item 'Switch_Aussenstrahler_hinten' received command OFF
                                          21:38:13.437 [INFO ] [marthome.event.ItemStateChangedEvent] - Switch_Aussenstrahler_hinten changed from ON to OFF
                                          21:38:13.437 [DEBUG] [rsAbstractConnection$MySensorsWriter] - Sending to MySensors: 14;1;1;0;2;0
                                          21:38:14.454 [DEBUG] [rsAbstractConnection$MySensorsReader] - Message from gateway received: 14;2;1;0;16;1
                                          21:38:14.457 [DEBUG] [rs.internal.gateway.MySensorsGateway] - Node 14 found in gateway
                                          21:38:14.459 [DEBUG] [rs.internal.gateway.MySensorsGateway] - Child 2 not present in node 14
