  3. OpenHAB
  4. openHAB 2.0 binding
openHAB 2.0 binding
534 Posts 88 Posters 675.9k Views 99 Watching
    matt shepherd
    Have you tried using Mqtt? I've recently set up a motion sensor with a mqtt gateway and it seems to be more reliable. The motion just sends a 1 for motion or 0 for no motion (obvs). I have a rule that says turn lights on if motion state =1 .You don't have to worry about connecting 'things' with openhab as you use the mqtt binding.
    S 1 Reply Last reply
    • M matt shepherd
      stolly82
      @matt-shepherd
      for now not.
      The problem is more, that openhab 2 accepts only one device per Node with the 2.0 binding. It doesn´t matter if it it a motion sensor or if it is a second relay.
      Alway´s if I setup a second thing with a existing ChildID,... the first Thing is not working anymore (LOG = Child x not present in Node x ).
      I tried to install on a second Raspberry with OpenHab2 and MySensors2.0 binding (Openhabian) and there is the same issue.
      That´s really really strange.
      • mickM
        mickM
        mick
        I would like to attempt the irrigation controller with this binding, I believe the "light" thing is used. This only has channels: Status, Battery, LastUpdate. Is it possible to add more channels to the light thing ?, ie: V_VAR1 ... V_VAR3, regards.
        andreacioniA 1 Reply Last reply
        • mickM mick
          andreacioniA
          andreacioniA
          andreacioni
          wrote on last edited by andreacioni
          #524
          @mick you aren't the first asking that :sweat_smile: . I opened a new issue on GitHub (https://github.com/tobof/openhab2-addons/issues/95) to discuss about adding it to the binding.
          mickM 1 Reply Last reply
          • andreacioniA andreacioni
            mickM
            mickM
            mick
            Cheers @andreacioni - fingers crossed :+1:
            • T TimO
              Features
              • Serial Gateway supported (with variable baud rate)
              • Ethernet Gateway supported
              • Supported sensors: S_TEMP, S_HUM, S_VOLTAGE, S_LIGHT, S_POWER, S_BARO, S_DOOR, S_MOTION, S_SMOKE, S_DIMMER, S_COVER (Stop not implemented in OH2 yet), S_WIND, S_RAIN, S_UV, S_WEIGHT, S_DISTANCE, S_LIGHT_LEVEL
              • Request for an ID is answered (random free number is given)
              • Discovery of devices, to use it: start the scan for devices in OpenHAB 2.0 and restart your nodes
              Pictures
              Discovery:
              What is not working yet:
              • no reconnect after lost connection
              How to test:
              Visit the wiki on the GitHub Repo.
              D
              D
              doctor64
              @TimO just updated to version 2.2.0.201708090807 of binding and get exception in network check
              22:41:33.015 [DEBUG] [rsAbstractConnection$MySensorsWriter] - Sending to MySensors: 0;0;3;0;2;
              22:41:33.029 [DEBUG] [rsAbstractConnection$MySensorsReader] - Message from gateway received: 0;255;3;0;2;2.1.1
              22:41:36.015 [DEBUG] [ateway.MySensorsNetworkSanityChecker] - Network sanity check: PASSED
              22:41:36.015 [DEBUG] [ateway.MySensorsNetworkSanityChecker] - Sending I_HEARTBEAT_REQUESTs
              22:41:36.016 [DEBUG] [rsAbstractConnection$MySensorsWriter] - Sending to MySensors: 0;255;3;0;18;
              22:41:36.032 [DEBUG] [rsAbstractConnection$MySensorsReader] - Message from gateway received: 0;255;3;0;22;436674305
              22:41:36.116 [DEBUG] [rsAbstractConnection$MySensorsWriter] - Sending to MySensors: 1;255;3;0;18;
              22:41:36.217 [DEBUG] [rsAbstractConnection$MySensorsWriter] - Sending to MySensors: 2;255;3;0;18;
              22:41:36.317 [DEBUG] [rsAbstractConnection$MySensorsWriter] - Sending to MySensors: 3;255;3;0;18;
              22:41:36.398 [DEBUG] [rsAbstractConnection$MySensorsReader] - Message from gateway received: 3;255;3;0;22;717683
              22:41:36.418 [DEBUG] [rsAbstractConnection$MySensorsWriter] - Sending to MySensors: 4;255;3;0;18;
              22:41:36.518 [DEBUG] [rsAbstractConnection$MySensorsWriter] - Sending to MySensors: 5;255;3;0;18;
              22:41:36.619 [DEBUG] [rsAbstractConnection$MySensorsWriter] - Sending to MySensors: 6;255;3;0;18;
              22:41:36.652 [DEBUG] [rsAbstractConnection$MySensorsReader] - Message from gateway received: 5;255;3;0;22;9428217
              22:41:36.683 [DEBUG] [rsAbstractConnection$MySensorsReader] - Message from gateway received: 6;255;3;0;22;3111897
              22:41:39.016 [DEBUG] [ateway.MySensorsNetworkSanityChecker] - Node 1 request heartbreat answer, missing null of 10
              22:41:39.016 [ERROR] [ateway.MySensorsNetworkSanityChecker] - Exception in network sanity thread checker
              java.lang.NullPointerException
              	at org.openhab.binding.mysensors.internal.gateway.MySensorsNetworkSanityChecker.checkHeartbeatsResponse(MySensorsNetworkSanityChecker.java:178)[195:org.openhab.binding.mysensors:2.2.0.201708090807]
              	at org.openhab.binding.mysensors.internal.gateway.MySensorsNetworkSanityChecker.run(MySensorsNetworkSanityChecker.java:122)[195:org.openhab.binding.mysensors:2.2.0.201708090807]
              	at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:511)[:1.8.0_144]
              	at java.util.concurrent.FutureTask.runAndReset(FutureTask.java:308)[:1.8.0_144]
              	at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$301(ScheduledThreadPoolExecutor.java:180)[:1.8.0_144]
              	at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:294)[:1.8.0_144]
              	at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149)[:1.8.0_144]
              	at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624)[:1.8.0_144]
              	at java.lang.Thread.run(Thread.java:748)[:1.8.0_144]
              • D doctor64
                andreacioniA
                andreacioniA
                andreacioni
                Hi @doctor64, could you please post your things configuration file?
                D 1 Reply Last reply
                  D
                  D
                  doctor64
                  @andreacioni All mySensors item defined using auto-discovery, so no things file in configuration. I'm think you mean this file? 0_1506175698221_org.eclipse.smarthome.core.thing.Thing.json
                  • D doctor64
                    andreacioniA
                    andreacioniA
                    andreacioni
                    #529
                    @doctor64 it is enough, I can replicate it. Thanks for reporting this issue :smile: . You can keep track of it here: https://github.com/tobof/openhab2-addons/issues/97
                    • G
                      G
                      gonzalonal
                      Today brand new setup with fail results.
                      I have installed a brand new OH2 snapshot build #1047 and the latest relese of the binding available.
                      I am using just a single node as ethernet gateway. After a couple of minutes the binding stops sending the messages to the node. It logs as it would send them but nothing is really sent out. I have sniffed the connection with wireshark.
                      Sometimes, while looking the binding debug logs at OH2 console, it hangs and I have to restablish the connection. This last issue seems more related to OH2 itself but maybe something wrong in the binding is causing it. Again, the is not a single clue in the logs about this.
                      I have just installed the OH2.1 stable release with the latest release of the binding and everything runs great yet.
                      Anyone with a similar experience?
                      AndrewZA 1 Reply Last reply
                      • G gonzalonal
                        AndrewZA
                        AndrewZA
                        AndrewZ
                        @gonzalonal I've observed something similar on my system, as I recall the binding wasn't even able to establish the initial connection to a gateway. Have OH upgraded today from an earlier build (~3 weeks old).
                        • jocke4uJ
                          jocke4uJ
                          jocke4u
                          This post is deleted!
                          • S
                            Skorpilein
                            Is it possible to implement RS485 Gateway? Or it works with Serial Gateway?
                            • ร
                              ร
                              รอเรือ
                              wrote on last edited by รอเรือ
                              #534
                              I get this in my log sometimes:
                              [WARN ] [.discovery.MySensorsDiscoveryService] - Cannot automatic discover thing node: 0, child: 255 please insert it manually
                              I use MySensors Binding 2.3.0.201801160936 on a serial gateway with mysensors 2.2.0
                              Where shall I insert the thing node and what should it look like?
