  3. Combine Relay Actuator (with button) and BinarySwitch examples?
7 Posts 4 Posters 5.6k Views 1 Watching
  • T
    TommySharp
    Have to say firstly that I'm still a novice so hopefully someone can help me out....
    I've managed to use the examples to create a Relay Actuator with button and a separate Binary Switch sensor using two separate arduino nanos.
    I'm now trying to combine the two sketches into one and don't quite know what I'm doing....
    Any help would be appreciated....
    • greglG
      greglG
      gregl
      Hi
      I'm a bit confused what sketches you are trying to combine..
      I take it you are starting with
      http://www.mysensors.org/build/relay#relaywithbuttonactuator-example
      as a base?
      • T
        TommySharp
        Yeah I'm just using the examples provided by this website...
        • T
          TommySharp
          Ideally I'd start with the relay with button script and then I want to add 2 window/door sensors for my garage doors.
          • Sander StolkS
            Sander StolkS
            Sander Stolk
            I have this as an example but it's not showing the buttons in my controller:
            The relays on the other hand I can control
            // Example sketch showing how to control physical relays.
            // This example will remember relay state even after power failure.
            #include <Bounce2.h>
            #define CHILD_ID 2
            #define RELAY_1  4  // Arduino Digital I/O pin number for first relay (second on pin+1 etc)
            #define RELAY_ON 0  // GPIO value to write to turn on attached relay
            #define RELAY_OFF 1 // GPIO value to write to turn off attached relay
            #define CHILD_ID 3
            #define BUTTON_PIN_1 3  // Arduino Digital I/O pin for button/reed switch
            #define BUTTON_PIN_2 8  // Arduino Digital I/O pin for button/reed switch
            Bounce debouncer = Bounce();
            int oldValue=-1;
              gw.sendSketchInfo("Relay", "1.0");
              gw.present(CHILD_ID, S_DOOR);
              // Fetch relay status
                gw.present(sensor, S_LIGHT);
                pinMode(pin, OUTPUT);
                digitalWrite(pin, gw.loadState(sensor)?RELAY_ON:RELAY_OFF);
               // Setup the button
              pinMode(BUTTON_PIN_1,INPUT);
              // Activate internal pull-up
              digitalWrite(BUTTON_PIN_1,HIGH);
              pinMode(BUTTON_PIN_2,INPUT);
              digitalWrite(BUTTON_PIN_2,HIGH);
              debouncer.attach(BUTTON_PIN_1);
              debouncer.interval(5);
              debouncer.attach(BUTTON_PIN_2);
              gw.process();
                debouncer.update();
              // Get the update value
              int value = debouncer.read();
              if (value != oldValue) {
                 // Send in the new value
                 gw.send(msg.set(value==HIGH ? 1 : 0));
                 oldValue = value;
              if (message.type==V_LIGHT) {
                 // Change relay state
                 // Store state in eeprom
                 // Write some debug info
                 Serial.print(message.sensor);
            E 1 Reply Last reply
            • Sander StolkS Sander Stolk
              #define CHILD_ID 2
              #define CHILD_ID 3
              int oldValue=-1;
                 // Setup the button
                gw.process();
                  debouncer.update();
                   oldValue = value;
              E
              E
              ewgor
              @Sander-Stolk are you using Openhab? can you share your config please?
              • Sander StolkS
                Sander StolkS
                Sander Stolk
                Well well well...
                I've got it working with 2 relays and 2 door sensors.
                See my sketch below!
                The problem is the relays which are configured by counting and adding up numbers and the child_id's for 1 button and the debouncer missing config in the skecth.
                With this sketch you can monitor 2 doors and 2 relays
                Bounce debouncer_1 = Bounce();
                Bounce debouncer_2 = Bounce();
                int oldValue_1=-1;
                int oldValue_2=-1;
                MyMessage msgGK(BUTTON_PIN_1,V_TRIPPED);
                MyMessage msgGD(BUTTON_PIN_2,V_TRIPPED);
                  gw.sendSketchInfo("Garagebox", "1.0");
                // Setup the doorsensor
                  //pinMode(BUTTON_PIN,INPUT);
                  //digitalWrite(BUTTON_PIN,HIGH);
                  //debouncer.attach(BUTTON_PIN);
                  //debouncer.interval(5);
                  debouncer_1.attach(BUTTON_PIN_1);
                  debouncer_1.interval(5);
                  debouncer_2.attach(BUTTON_PIN_2);
                  debouncer_2.interval(5);
                  gw.present(BUTTON_PIN_1, S_DOOR);
                  gw.present(BUTTON_PIN_2, S_DOOR);
                  gw.process();
                  debouncer_1.update();
                  int value_1 = debouncer_1.read();
                  if (value_1 != oldValue_1) {
                     gw.send(msgGK.set(value_1==HIGH ? 1 : 0));
                     oldValue_1 = value_1;
                    debouncer_2.update();
                  int value_2 = debouncer_2.read();
                  if (value_2 != oldValue_2) {
                     gw.send(msgGD.set(value_2==HIGH ? 1 : 0));
                     oldValue_2 = value_2;
