  3. Best platform (currently) for running RFM69HW?
46 Posts 10 Posters 31.7k Views 7 Watching
  • fetsF fets
    @NeverDie are you sure RFM69 pin pitch matches these adapters ?
    NeverDieN
    NeverDieN
    #21
    Good catch. I just now measured the pitch of the RFM69HW, and it's 2.0mm. So, you're right, those particular adapters wouldn't work.
    I have seen 1.0mm pitch adapters which I presume would work(?) by using every other solder line. I haven't tried looking for 2.0mm pitch adapters yet, but I guess now I will.
    • scalzS
      scalzS
      thx. RFM69 is on the same nrf plane. on overview you can see a port of the rfm69 footprint, under nrf. for rfm69, it is same pinout as the moteino. will post more soon.
      I am note sure what do you mean by FETS? I don't see your question...
      • scalzS
        scalzS
        ahaha now I understand your question! yes pitch is 2mm.
        • NeverDieN
          NeverDieN
          FYI, There is an a RFM69 adapter board for a teensie: file:///C:/Users/LR/Downloads/Teensy3%20RFM69_OSH%20plus%20RFM69-RFM22%20diag%20softw.pdf
          Now just need to find the equivalent for a pro mini....
          SparkmanS 1 Reply Last reply
          • NeverDieN
            NeverDieN
            #25
            It would be a total kludge, but with the correct pins and two adapters per radio, it might work: http://www.aliexpress.com/item/1-27MM-2-0MM-2-54MM-8-pin-adapter-plate/32386544730.html Actually, maybe not even then.
            I really hope someone has something better to suggest.
            NeverDieN 1 Reply Last reply
            • NeverDieN
              NeverDieN
              #26
              Or possibly use something like this, but attach 4 wires directly to the radio, one at each corner of the radio.
              http://www.ebay.com/itm/5pcs-SOP24-SOIC-1mm-to-DIP24-Adapter-PCB-Board-Converter-Double-Sides-NEW-F67-/171246416055?hash=item27df14f0b7
              You'd only solder to every other solder pad.
              I guess it might work.
              • NeverDieN NeverDie
                SparkmanS
                SparkmanS
                Sparkman
                wrote on last edited by Sparkman
                #27
                @NeverDie Here's the link to the OSH Park Teensy adapter board: https://oshpark.com/shared_projects/RIumMBtN
                These guys have an an adapter board as well, but a bit pricey: http://modtronicsaustralia.com/shop/rfm69hw-breakout-board-bare-pcb-rf-wireless-module/
                Cheers
                Al
                • SparkmanS Sparkman
                  Cheers
                  Al
                  NeverDieN
                  NeverDieN
                  Cheers
                  Al
                  Thanks, Al!
                  I suppose if I were to need an SMA connector, that modtronics board would be the only way (at the moment) of getting it.
                    NeverDieN
                    NeverDieN
                    #29
                    @NeverDie said:
                    It would be a total kludge, but with the right pins and two adapters per radio, it might work: http://www.aliexpress.com/item/1-27MM-2-0MM-2-54MM-8-pin-adapter-plate/32386544730.html Actually, maybe not even then.
                    Amazingly, the idea actually does work. Somebody with the same desperate need already did it:
                    https://www.gorilladistribution.com.au/product/prototyping-adapter-kit-for-hoperf-modules/
                    • NeverDieN
                      NeverDieN
                      #30
                      This guy demonstrates how it can be done using protoboard: http://jdesbonnet.blogspot.com/2014/12/experiments-with-rfm69-433mhz-digital.html
                      but it was nasty looking, so he later spun his own PCB.
                      • SparkmanS
                        SparkmanS
                        Sparkman
                        Here's another option: https://github.com/uChip/RFM69W_BOB
                        • SparkmanS
                          SparkmanS
                          Sparkman
                          And this one which is interesting as it adapts the RFM to an NRF pinout: https://hallard.me/rfm12b-breakout/ which could be very useful to use boards like the Sensebender with and RFM69.
                          Cheers
                          Al
                          • scalzS scalz
                            @NeverDie : hi. look at here if you want http://forum.mysensors.org/topic/1419/sensor-board-with-booster-and-supervisor. it is not updated yet. I will do soon. I am waiting for my second batch as I had some mistakes. I have to wait two weeks to receive; I can't wait!
                            you will be able to solder what you need. dc booster can provide constant voltage even if battery is low. it will be possible to solder just some parts, it depends what you will need. I have made a version with nrf_smd+rfm69 footprints too.
                            I think I will like it. Maybe others...
                            It is opensource so you will be able too build it.
                            Note: on overview this is not the pro mini I use (I have not the good 3d model). I use these http://s.click.aliexpress.com/e/feUvNFufi
                            Too bad I didn't see the MYSXConnector before. Next time I will take care :wink:
                            NeverDieN
                            NeverDieN
                            Have you picked out a box yet for mounting it in, and do they mate well? As corny as it sounds, having the total solution can really tip the scales toward your solution. If I go the hybrid route (two different kinds of radios), I think I might find this quite attractive.
                            Good to know, because that's exactly the source I was thinking of too!
                            How does MYSX connector relate to this?
                              Cheers
                              Al
                              NeverDieN
                              NeverDieN
                              #34
                              Cheers
                              Al
                              That's interesting: judging from the photos apparently only 9 pins on the RFM69HW are used in the hookup. Maybe that's why loosing 2 pins to make a RFM69CW is no big deal....
                              • NeverDieN
                                NeverDieN
                                #35
                                Argh!!!! Apparently the RFM69CW has the same stupid 2.0mm pin spacing as the RFM69W.
                                As crude as it sounds, maybe all that's required in bending some pins: http://jeelabs.net/boards/6/topics/1012
                                So, the above pin bending would work for at least the RFM69CW.
                                Actually, for the RFM69W, I'd apparently only need be concerned about bending the 9 pins that actually get used....
                                • scalzS
                                  scalzS
                                  wrote on last edited by scalz
                                  #36
                                  @NeverDie :
                                  You are right. On my non-updated overview it is corny. But I have already rounded corners. And I have only one hole for screw (3mm). It is very difficult to add others because of size and component placement. But I will see later if it is a problem.
                                  You can have a look here of what I have sent to fabhouse:
                                  https://raw.githubusercontent.com/scalz/MySensors-HW/development/PowerManagementMysensors/img/top.png
                                  https://raw.githubusercontent.com/scalz/MySensors-HW/development/PowerManagementMysensors/img/bottom.png
                                  For the box, I didn't find enclosures which make me happy because of available size. It is so rectangular. Not beautiful. So I am planning to buy a 3d printer and make my own encosure based on my board. Then share my design...as I have others cool boards in project.
                                  Yes I am using same pro mini source as yours:wink:
                                  For MYSXConnector, I said this because I read this topic http://forum.mysensors.org/topic/1796/unnamed-project-usb-hub-stick . So next time, I will take care about this if possible, as I am working for me and for community too.
                                  If it is just a breakout that you are searching for, links above are interesting. I talked with Charles from hallard.me . He is doing very great job. I am a big fan! and his ulpnode will be released soon I think. Can't wait to buy one to support his work!
                                  In my side, I wanted something different (no sensors already mounted, modularity, signing and ota Mysensors feature ...). So I did mine. And Charles have gracefully proposed me to help to make my board compatible with his upcoming ultra low power lib. And it will be Mysensors compatible too. So coool!
                                  I think you will have a lot of choice...
                                  • scalzS scalz
                                    @NeverDie :
                                    NeverDieN
                                    NeverDieN
                                    #37
                                    @scalz said:
                                    @NeverDie :
                                    Not many people are going to custom print their box enclosure. You might, because you're invested in it. If you want others to use it too, consider instead first finding a good, small, inexpensive box from China that's easy to source from different suppliers to house it all in, and then work backward from that. So, for instance, there should be screw holes in your board over whatever standoffs there are in the box. Then, each end user doesn't have to scratch their head and waste time doing an independent search for what box to use to house your board. That part is known as the outset, and you can have links to Ebay and/or AliExpress on where to get it.
                                    FWIW, from an end user perspective, that's what most people will want: an easy and inexpensive and total solution. Not to be left dangling after being painted into a corner.
                                    Either that, or plan on selling your custom box along with your custom board, so at least the shipping can be combined. I imagine it will be tough competing with China though... :smirk:
                                    • scalzS
                                      scalzS
                                      #38
                                      @Neverdie: I agree with you of course. When I started to design my board, I looked to enclosure but didn't find my dream.. It is often too big, too thick or not enough, too small... often not very beautiful, and if you want to keep pcb low price you need to stay under 5cmx5cm (15$ for 10 pcb).
                                      So it was not easy deal. And enclosure are sometimes a little expensive for what it is compared to 3d printings (of course it needs to invest in a 3d printer). I am thinking to make custom enclosure a little more designed than traditional rectangular, for motion, or sensors like some members are doing here...
                                      But you are totally right, if it is for community too, I must dig in an esay, inexpensive an toal way...I will see what I can do if it can help.
                                      I don't do this for business. And not planning to sell anything. It is just share and fun. just want to release what people need to make one. But if there is demand, I will see how it could be done regarding Mysensors spirit.. But you are right I can't compete with China! even if I think it will be less expensive to build mine than asking fabhouse to build it (of course I don't look at my time making).
                                      Oh, and I hope my english is understable:smiley: and I promise I will look at your requirements. In the mean time, if you see good enclosure regarding pcb size, you can tell me if you want (maybe this topic is not the right place for enclosure...)
                                      See you soon.
                                      • scalzS scalz
                                        See you soon.
                                        NeverDieN
                                        NeverDieN
                                        #39
                                        I don't do this for business. And not planning to sell anything. It is just share and fun. just want to release what people need to make one. But if there is demand, I will see how it could be done regarding Mysensors spirit.. But you are right I can't compete with China! even if I think it will be less expensive to build mine than asking itead or others to build it (of course I don't look at my time making).
                                        Oh, and I hope my english is understable:smiley: and I promise I will look at your requirements. In the mean time, if you see good enclosure regarding pcb size, you can PM me if you want (maybe this topic is not the right place for enclosure...)
                                        See you soon.
                                        Agreed. Although important, this is getting off-topic and deserves it's own thread, so I've started one here: http://forum.mysensors.org/topic/1816/best-project-boxes-to-use-for-mysensor-s-gateway-and-sensor-nodes
                                        • Z Zeph
                                          If you want more than one kind of module, you can ask the eBay seller to combine shipping.
                                          SparkmanS
                                          SparkmanS
                                          Sparkman
                                          Thanks! I just heard back from Anarduino through the eBay site and he's confirmed that combined shipping for everything is $6.55, so that's a great deal (assuming I buy more than one item :-) )
                                          Cheers
                                          Al
