  3. Read string from serial port and send it to gateway
11 Posts 4 Posters 5.7k Views 4 Watching
  • Andreas HenrikssonA
    Andreas HenrikssonA
    Andreas Henriksson
    Hello
    I have play with my sensors a lot and it works perfect (only try standard sensors).
    But now i want to create a sensor that read/write on the serial port (pin 0 and 1) and send it to the gateway
    My C skills are very low but i try to learn :-)
    This is my sketch:
    #define CHILD_ID 0
    String readString;
    MyMessage msg(CHILD_ID,V_VAR1);
      gw.begin();
      Serial.begin(115200);
      gw.sendSketchInfo("test", "1.0");
      gw.present(CHILD_ID, S_CUSTOM);
      while (Serial.available()) {
        delay(3);  //delay to allow buffer to fill
        if (Serial.available() >0) {
          char c = Serial.read();  //gets one byte from serial buffer
          readString += c; //makes the string readString
      if (readString.length() >0) {
          Serial.println(readString); //see what was received
    	  gw.send(msg.set(readString));
    	  readString="";
    The string from serial port looks like this: "4. ERO 11421"
    But when i verify the sketch in codebender i get this error:
    Test_sensor.ino:69:16: error: no matching member function for call to 'set'
    Any idea how to fix this
    Thanks Andreas
    • T
      TimO
      According to:
      https://github.com/mysensors/Arduino/blob/master/libraries/MySensors/MyMessage.cpp
      There is no set method that accepts String type. You could use this one instead:
      MyMessage& MyMessage::set(const char* value)
      Greetings,
      Tim
        Andreas HenrikssonA
        Andreas Henriksson
        Bu ti don't know how to fix this in my sketch :-( , can you please point me to the right direction ??
        Andreas H
        • T
          TimO
          Hmmm, I'm out, when it comes to pure C, so I'm not sure if I'm really able to help you.
          The first question that comes to my mind, when I read your sketch is: when does the loop end, that reads the characters?
          If the string you receive ends for example with a newline, you could use something like: https://www.arduino.cc/en/Serial/ReadBytesUntil
          where buffer is char[] and could be passed to msg.set().
          Please keep in mind that the message content must not exceed 25 bytes.
            Andreas HenrikssonA
            Andreas Henriksson
            Opps . i missed that in this sketch :-(
            But the main problem is howto send a string och many chars :-(
            • fetsF
              fetsF
              fets
              @Adreas Henriksson
              I think that if you use String, you should call c_str() method to get char *.
              Your have then to change the line with : gw.send(msg.set(readString.c_str()));
              Hope this works.
                Andreas HenrikssonA
                Andreas Henriksson
                Hello
                I dont get any error when i compile, so i will make a test later today.
                Andreas H
                  Andreas HenrikssonA
                  Andreas Henriksson
                  This did the trick.
                  Thanks for this :-)
                  Andreas H
                  eSumoE 1 Reply Last reply
                  • Andreas HenrikssonA Andreas Henriksson
                    This did the trick.
                    Thanks for this :-)
                    Andreas H
                    eSumoE
                    eSumoE
                    eSumo
                    @Andreas-Henriksson
                    Hello. I need something like this ...
                    Can you show your functional version?
                    Thanks...
                      Andreas HenrikssonA
                      Andreas Henriksson
                      wrote on last edited by Andreas Henriksson
                      Hello, i don't using this any more but i found this on my laptop.
                      I can't confirm that i work, but it the latest version i have.
                      #include <DHT.h>
                      #define CHILD_ID_INFO 0
                      #define CHILD_ID_SOC 1
                      #define CHILD_ID_STATE 2
                      #define CHILD_ID_ERROR 3
                      #define CHILD_ID_SET_STATE 4
                      #define CHILD_ID_TEMP 5
                      #define CHILD_ID_HUM 6
                      //Pin
                      MyMessage info(CHILD_ID_INFO, V_VAR1);
                      MyMessage soc(CHILD_ID_SOC, V_VAR2);
                      MyMessage state(CHILD_ID_STATE, V_VAR3);
                      MyMessage error(CHILD_ID_ERROR, V_VAR4);
                      MyMessage temp(CHILD_ID_TEMP, V_TEMP);
                      MyMessage hum(CHILD_ID_HUM, V_HUM);
                      DHT dht;
                      //DHT Sensor
                      const byte numChars = 25;
                      char receivedChars[numChars];
                      float lastTemp;
                      float lastHum;
                      boolean metric = true;
                      //MySensorr
                      int mySensorType;
                      int mySensorMsg;
                      String mySensorStr;
                      String mySensorRaw;
                      String mySensorRawSoc;
                      String mySensorStrSoc;
                      //Serial Read
                      boolean newData = false;
                        gw.begin(incomingMessage, 1, false);
                        gw.sendSketchInfo("Mover", "1.0");
                        gw.present(CHILD_ID_INFO, S_CUSTOM);
                        gw.present(CHILD_ID_SOC, S_CUSTOM);
                        gw.present(CHILD_ID_STATE, S_CUSTOM);
                        gw.present(CHILD_ID_ERROR, S_CUSTOM);
                        gw.present(CHILD_ID_SET_STATE, S_CUSTOM);
                        recvWithStartEndMarkers();
                        showNewData();
                        gw.process();
                        if (message.type == 28)
                          if (message.getInt() == 99)
                            //if (isnan(temperature))
                            //  Serial.println("Failed reading temperature from DHT");
                            if (temperature != lastTemp)
                              lastTemp = temperature;
                              if (!metric)
                              //Serial.print("T: ");
                              //Serial.println(temperature);
                            gw.send(temp.set(temperature, 1));
                            //if (isnan(humidity))
                            //  Serial.println("Failed reading humidity from DHT");
                            if (humidity != lastHum)
                              lastHum = humidity;
                              //Serial.print("H: ");
                              //Serial.println(humidity);
                            gw.send(hum.set(humidity, 1));
                          else {
                            //Serial.println(message.type);
                            //Serial.print("Incoming change for sensor:");
                            //Serial.println(message.sensor);
                            //Serial.print(", New status: ");
                            Serial.print(message.getInt());
                      void recvWithStartEndMarkers()
                        static boolean recvInProgress = false;
                        static byte ndx = 0;
                        char startMarker = '<';
                        char endMarker = '>';
                        char rc;
                        // if (Serial.available() > 0) {
                        while (Serial.available() > 0 && newData == false)
                          rc = Serial.read();
                          if (recvInProgress == true)
                            if (rc != endMarker)
                              receivedChars[ndx] = rc;
                              ndx++;
                              if (ndx >= numChars)
                                ndx = numChars - 1;
                            else
                              receivedChars[ndx] = '\0'; // terminate the string
                              ndx = 0;
                              newData = true;
                          else if (rc == startMarker)
                            recvInProgress = true;
                      void showNewData()
                        if (newData == true)
                          mySensorRawSoc = receivedChars;
                          mySensorStrSoc = mySensorRawSoc.substring(2, 6);
                          mySensorRaw = receivedChars;
                          mySensorStr = mySensorRaw.substring(2);
                          switch (receivedChars[0])
                            case '1':
                              gw.send(info.set(mySensorStr.c_str()));
                              break;
                            case '2':
                              gw.send(soc.set(mySensorStrSoc.c_str()));
                              break;
                            case '3':
                              gw.send(state.set(mySensorStr.c_str()));
                              break;
                            case '4':
                              gw.send(error.set(mySensorStr.c_str()));
                              break;
                          /*Serial.print ("type: ");
                          Serial.println (receivedChars[0]);
                          Serial.print ("Msg: ");
                          Serial.println (receivedChars[2]);
                          Serial.println (mySensorRaw);
                          Serial.println (mySensorStr);
                          mySensorRawSoc = "";
                          mySensorStrSoc = "";
                          mySensorRaw = "";
                          mySensorStr = "";
                          newData = false;
                      • eSumoE
                        eSumoE
                        eSumo
                        OK. Thanks. I try...
