  3. Controlling mysensors actuators via MQTT - need help
2 Posts 1 Posters 1.5k Views 1 Watching
  • R
    R
    ruslan
    I just built MQTT gateway. It works fine delivering data from the sensors, but I can not figure out, how to send commands to actuators, like relays. What command, for instance, shall I send to MQTT gateway to switch on relay on node 1?
    Also, when I connect to gateway MQTT server via mosquitto_pub (publishing client) and try to publish something - it does not show in the MQTT reading client. Is this normal, or I have some problem with MQTT server?
    • R
      R
      ruslan
      Problem solved. The right command would be
      topic: MyMQTT/1/1/V_LIGHT
      message: 1
