  3. What board for battery powered 5V Sensors?
3 Posts 2 Posters 2.2k Views 2 Watching
  • bpairB
    bpairB
    bpair
    I have read over the battery powered section which uses a 3V Pro Mini. I was hoping to create a sensor that combines the following sensors
    • Soil moisture sensor (3.3-5V)
    • BH1750 Ambient Light sensor (3-5V)
    • DHT22 Humidity/Temperature Module (3.3-5V)
    I will only be recording data once every 10-20 minutes. For longest battery life would it be better to use a 3V Pro Mini( and I suppose I would need a step-up or bi-directional logic level shifter ?) or just go with the 5V Pro Mini?
    I have never created a battery powered device so I am ot really sure what will happen as the battery drains. For example if the Pro-Mini needs a regulated 3.3v supply and it is connected to a battery what happens as the voltage drops below 3 volts?
    • sundberg84S
      Hi @bpair!
      I have created a sensor with Light, Hum, Temp and Pressure. Maybe you can get some inspiration here...
      To save power/battery its better to use 3.3v that 5v. When i make battery power i use this: my-2aa-battery-sensor when i wire and setup the sensor.
      I use a 0.9-3.3v booster to suck the most out of the batteries, and this ensures 3.3v to the arduino until the battery is below 0.9v. You can the monitor the battery level 3.3v = 100% and 0.9v = 0%. Below this (or even 1-1.1v) the radio will fail and it will just be dead.
      Also there is the Sensebender Micro http://www.mysensors.org/hardware/micro you can buy and use... it will probably last even longer but I dont know much about it since i dont use it at this time.
      • bpairB
        bpairB
        bpair
        Thanks - your schematic/drawing is really helpful. I just ordered some of those step-up components and a few sensebenders.
