Adapter for RFM69 on NRF24L01+ pinout-header
Thanks @alexsh1, that answers that.
One other quick question. Other than ordering the PCB's from dirtypcb's; any other hardware for the board required? I know I will need wire for an antenna, but wasn't sure if there was any need for capacitors or resistors. I looked through the thread and found no parts list so i'm leaning towards no.
Thanks again,
Thanks again,
@drock1985 I am not sure what board you would like to order from dirtypcb, there are no links in this thread. Under "hardware" what do you mean? Soldering iron? Components?
In relation to RFM69, you need the board itself and an antenna (a wire 16.5cm for 433Mhz or uFL-SMA connector with antenna). I have a capacitor on my node, but it was more designed for nrf24l01+. I do not think the capacitor is required for a 2xAA batteries powered node for RFM69 , but it is a matter of the trial-and-error. I have some NRF24L01+ working fine without caps.
More or less if there was any components to solder to the board (components). I know with the NRF you have to have a 4.7mf capacitor for the radio; wasn't sure if RFM was the same or not. The only component I see needing is the 2x4 pin header.
Thanks again.
Thanks again.
@drock1985 OK, for the RFM69*** it depends how you are mounting it. On the photo above I mounted it instead of nrf24l01+ into 2x4 header. Not sure if you can see it from the photo. So i needed the following:
- The adapter RFM69CW to nrf24l01+
- Obviously, RFM69CW
- In my case for the adapter, I needed angled pins (2 rows by 4 to be soldered to the board) - http://www.aliexpress.com/item/10pcs-1x40-Pin-2-54mm-Right-Angle-Single-Row-Male-Pin-Header-Connector/32326283091.html?spm=2114.30010308.3.48.ewITwH&ws_ab_test=searchweb201556_10,searchweb201602_5_10037_10017_405_507_10033_406_10032,searchweb201603_2&btsid=5c8ce6ee-912d-494d-86b1-6fcd11e14771
- That's it.
As I said the cap is on the node and is there for nrf24l01+ (you can see it from the photo). I also had one cap, one resistor and one LED on the adapter (all 0805 SMD), but this is not compulsory.
- That's it.
Perfect, that answers that. Thanks again. Only complaint is the RFM is not as inexpensive as the NRF's. lol.
cheers,
@drock1985 I know, RFM95 is even more expensive!
