  3. Dimmer LED with two state
2 Posts 1 Posters 1.6k Views 2 Watching
  • J
    J
    jacek
    wrote on last edited by jacek
    I did something like that based on DimmableWithRotaryEncoderButton, I changed only this part :
      if (digitalRead(8) == 0) { persons = 0;} else {persons = 1;}
      if (message.type == V_LIGHT && persons == 1) {
        // Incoming on/off command sent from controller ("1" or "0")
        int lightState = message.getString()[0] == '1';
        int newLevel = 0;
        if (lightState==LIGHT_ON) {
          // Pick up last saved dimmer level from the eeprom
          newLevel = loadLevelState(EEPROM_DIM_LEVEL_SAVE);
        // Send dimmer level back to controller with ack enabled
        gw.send(dimmerMsg.set(newLevel), true);
        // We do not change any levels here until ack comes back from gateway
        return;
      } else if (message.type == V_DIMMER && persons == 1) {
        // Incoming dim-level command sent from controller (or ack message)
        fadeTo = atoi(message.getString(convBuffer));
        // Save received dim value to eeprom (unless turned off). Will be
        // retreived when a on command comes in
        if (fadeTo != 0)
          saveLevelState(EEPROM_DIM_LEVEL_SAVE, fadeTo);
     if (persons == 1){
           saveLevelState(EEPROM_DIM_LEVEL_LAST, fadeTo);
           Serial.print("New light level received: ");
           Serial.println(fadeTo);
         if (!changedByKnob)
           knob.write(fadeTo);
           // Cancel send if user turns knob while message comes in
           changedByKnob = false;
           sendDimValue = false;
           // Stard fading to new light level
           startFade();
    } else if (persons == 0){
      gw.send(dimmerMsg.set(0), true);
     return;
    What I wanted to get?
    I wanted to achieve the effect such that when the variable persons = 1 ściamniacz operate normally, but the variable persons = 0 despite the switch is turned on in domoticzu it is to be shut down after a while or at all does not turn on . Now, this code works like that sometimes acts like he wants and sometimes not :(
    Sometimes works well like now:
    read: 0-2-4 s=1,c=1,t=3,pt=0,l=2,sg=0:27
    send: 4-4-2-0 s=1,c=1,t=3,pt=2,l=2,sg=0,st=ok:0
    read: 0-2-4 s=1,c=1,t=3,pt=2,l=2,sg=0:0
    but sometimes dont work well:
    read: 0-2-4 s=1,c=1,t=3,pt=0,l=2,sg=0:33
    and I donot know why :(
    the point is that in the read is different than 0 in domoticzu button does not become inactive .
    • J
      J
      jacek
      OK, i think it work's well now:
        if (message.getString() != 0)
                {gw.send(dimmerMsg.set(0), true);}
         else
                {return;} ```
