  3. Help understanding the serial monitor.
6 Posts 4 Posters 1.9k Views 2 Watching
  • Cliff KarlssonC
    Cliff KarlssonC
    Cliff Karlsson
    Starting sensor (1.6.0-beta)
    Radio init successful.
    send: 3-3-0-0 s=255,c=0,t=17,pt=0,l=10,sg=0,st=fail:1.6.0-beta
    send: 3-3-0-0 s=255,c=3,t=6,pt=1,l=1,sg=0,st=fail:0
    send: 3-3-0-0 s=255,c=3,t=11,pt=0,l=18,sg=0,st=fail:Temperature Sensor
    send: 3-3-0-0 s=255,c=3,t=12,pt=0,l=3,sg=0,st=fail:1.1
    Init complete, id=3, parent=0, distance=1
    I am trying to use the dallastemperature sketch but I am not getting anything in domoticz. This is what shows in the serial monitor. What could be wrong?
    • L
      L
      LastSamurai
      Everything is explained here if you don't understand the serial output read this.
      • sundberg84S
        st=fail is radio issues, if you are using a nrf radio its normally fixed with a 4.7uf Cap from Grn to Vcc or check if there is anything drawing much power (like relay) and disturbs the radio.
        In Domoticz you will not get anything untill the first value is sent, which you do not have in the log atleast.
        When you have sent the first temp from your node it will pop up.
        • Cliff KarlssonC
          Cliff KarlssonC
          Cliff Karlsson
          Ok it is a pro mini with only a RFM69W and a tempsensor attached
          • FrancoisF
            FrancoisF
            Francois
            wrote on last edited by Francois
            @Cliff-Karlsson I had the same issue and didn't know what was the problem was so today i move over to Mysensor 1.6 Beta change relevant setting in MyConfig.h and recompile my serial gateway and some of my sensor and the problem when away. On what version of Domoticz are you?
            I am also use the RFM69W with an mini pro
            Just compile the DallasTemp sketch and it is working.
            send: 101-101-0-0 s=255,c=0,t=17,pt=0,l=10,sg=0,st=ok:1.6.0-beta
            send: 101-101-0-0 s=255,c=3,t=6,pt=1,l=1,sg=0,st=ok:0
            read: 0-0-101 s=255,c=3,t=6,pt=0,l=1,sg=0:M
            send: 101-101-0-0 s=255,c=3,t=11,pt=0,l=18,sg=0,st=ok:Temperature Sensor
            send: 101-101-0-0 s=255,c=3,t=12,pt=0,l=3,sg=0,st=ok:1.1
            Init complete, id=101, parent=0, distance=1
            • Cliff KarlssonC
              Cliff KarlssonC
              Cliff Karlsson
              Ok, will try to resolder the radio to see if it helps
