  3. Scene controller are not find in inclusion
2 Posts 1 Posters 921 Views 1 Watching
  • N
    N
    NBM
    Hi
    I have i problem with inclusion a scener controller to my vera lite with a seriel gateway version 1.4 and 1.5 lib.
    When i'm uploading an other sketch to the arduino pro mini and including the sensor it finds the sensor. So it is not an connect problem with the wires.
    My sketch look like this:
    // Simple SceneController
    #include <Bounce2.h>
    #define CHILD_ID 3
    // PIN for the buttons
    byte buttons[] = {3, 4, 5, 6};
    #define NUMBUTTONS sizeof(buttons)
    byte pressed[NUMBUTTONS], justpressed[NUMBUTTONS], justreleased[NUMBUTTONS];
    Bounce debouncer[NUMBUTTONS];
    int oldValue[NUMBUTTONS];
    MyMessage msgOn(CHILD_ID,V_SCENE_ON);
    MyMessage msgOff(CHILD_ID,V_SCENE_OFF);
      gw.begin();
      gw.sendSketchInfo("LK 4-Tryk", "1.0");
      gw.present(CHILD_ID, S_SCENE_CONTROLLER);
      /// Make input & enable pull-up resistors on switch pins
      for (short i=0; i < NUMBUTTONS; i++){
        pinMode(buttons[i], INPUT);
        digitalWrite(buttons[i], HIGH);
        oldValue[i] = -1;
        debouncer[i].attach(buttons[i]);
        debouncer[i].interval(5);
        debouncer[i].update();
        // Get the update value
        int value = debouncer[i].read();
        if (value != oldValue[i]) {
           // Send in the new value
           if (value==HIGH) {
             gw.send(msgOff.set(i));
           else {
             gw.send(msgOn.set(i));
           oldValue[i] = value;
    Can anyone help me?
    And do anyone have an ide how to make the sketch battery friendly? So it uses as little power as possible.
    Thank you.
    /Nikolaj
    • N
      N
      NBM
      I'm getting this on the vera. I have update the firmware on vera lite.
