  3. [Solved] Soft signing with whitelist on nodes
4 Posts 2 Posters 1.9k Views 2 Watching
  • C Offline
    C Offline
    carlierd
    wrote on last edited by carlierd
    This is what I want to do:
    • soft signing between a serial gateway and different nodes
    • serial gateway accept data from any nodes (no whitelist on it)
    • nodes only accept data from the serial gateway using whitelist
    The code in the gateway:
    uint8_t soft_serial[SHA204_SERIAL_SZ] = {0xAA,0xAA,0xAA,0xAA,0xAA,0xAA,0xAA,0xAA,0xAA};
    MySigningAtsha204Soft signer(true, 0, NULL, soft_serial);
    MyHwATMega328 hw;
    MyTransportRFM69 transport;
    MySensor gw(transport, hw, signer, RADIO_RX_LED_PIN, RADIO_TX_LED_PIN, RADIO_ERROR_LED_PIN);
    The code in the node:
    whitelist_entry_t node_whitelist[] = {
      { .nodeId = 0,
        .serial = {0xAA,0xAA,0xAA,0xAA,0xAA,0xAA,0xAA,0xAA,0xAA} }};
    uint8_t soft_serial[SHA204_SERIAL_SZ] = {0x01,0x02,0x03,0x04,0x05,0x06,0x07,0x08,0x09};
    MySigningAtsha204Soft signer(true, 1, node_whitelist, soft_serial);
    MyHwATMega328 hw;
    MySensor gw(transport, hw, signer);
    In MyConfig.h I enabled MY_SIGNING_FEATURE and MY_SECURE_NODE_WHITELISTING.
    Do you think it's correct ?
    If I enable DEBUG_SIGNINGin MySigningAtsha204Soft.cpp, on reception of a message I got a SNOKand a W?. Why ?
    David.
    A 1 Reply Last reply
    • C carlierd
      MyHwATMega328 hw;
        { .nodeId = 0,
      MyHwATMega328 hw;
      David.
      A Offline
      A Offline
      Anticimex
      @carlierd Is this a duplicate of this thread? http://forum.mysensors.org/topic/2491/verify-fail-when-enabling-whitelist-in-signing-function
      Lets continue in that one if so.
      • C Offline
        C Offline
        carlierd
        Hello !
        It's not exactly the same thing. In this post I described what I want to do and how I implemented it. It's a global vision of what I understood or not correctly understood ;)
        We can continue on the previous post.
        • A Offline
          A Offline
          Anticimex
          Well, then I do believe your vision is described in my signing thread ;)
          But let's focus on the problem you describe in the other thread.
