  2. Feature Requests
  3. Monitoring node sensors down / Nagios
5 Posts 3 Posters 3.5k Views 1 Watching
    mickaelh51
    I'm looking for a solution to monitor when a node sensor is down (power outage, etc ...).
    Is there a list of node connected to gateway (MQTT gateway) ?
    Ex:
    Nagios script checks MQTT broker (Mosquitto) with special command, Mosquitto forwards this command to MQTT gateway (GatewayW5100MQTTClient) and gateway send a list of available nodes connected.
    it's already exist ?
    thanks in adavance
    Controller: OpenVZ :: OpenHab 1.8.0 :: MQTT Broker
    Gateway: Arduino UNO :: W5100 :: MQTTClient
    Software: MySensors 1.6beta
      I am using check_json to fetch sensor information from Domoticz. Have no experience checking mqtt directly but finding a plugin shouldn't be that hard.
        mickaelh51
        Thanks @mfalkvidd
        it's possible to parse many informations from gateway, it's a good new.
        For Nagios plugin, it's no a problem I'm going to develop one ;)
        My question is: when a node sensor is down, my mqtt broker have in own memory the last data and it dont know that sensor is down :(
        is there a mysensors "ping" like between sensor nodes and gateway ?
        thanks in adavance
        • sundberg84S
          Hi!
          Im using LUA in my controller (Domoticz) to check when a node was updated last time. If not updated when expected i get a notification.
            mickaelh51
            Thanks @sundberg84,
            I'm already using this method with openhab ;)
            I will be continue to use it.
