  3. Rechargeable Lithium Ion Sensor Custom PCB
71 Posts 12 Posters 36.4k Views 8 Watching
  • D dakipro
    I've been looking for some time for similar module/board,
    (was too lazy to make it myself) and somehow i never found this board.
    If I understood you are now on half the battery (after a six months) ?
    Did you had any tests with the Relay version on battery power?
    I guess it will consume quite some power if it needs to keep relay on from the battery?
    If it relay doesn't consume a lot of power then it could be very very useful to have it there (or if it is switched for short period of time and not that often)
    Project looks very good, it has all it needs for generic module, thank you for making it.
    H Offline
    H Offline
    HenryWhite
    Yes, i expect the battery to last ~12 months with one motion sensor + temp/hum sensor installed.
    When you want to use the relay, the board normally consumes a lot more power and the battery would not even last 1 month I think, because your board has to be active all the time to receive commands for the relay.
    If you do not insist on instant relay switching, you could implement the SmartSleep() functionality of mysensors. With this the battery should last way longer, maybe even as long as without relay.
    By the way, I got myself a 3D printer and designed a casing for my usecase (motion sensor -- but the case should fit a variety of other components too):
    • D Offline
      dakipro
      wrote on last edited by dakipro
      #62
      Makes sense. I am just comparing different editions, it appeared to me that the relay board could be a completelly separate project/pcb, as it would not work quite well on the rechargeable battery, and has quite a different purpose/audience I guess.
      Rev 0.3 would then be trully "rechargeable" battery sensor (as in the title), and rev 1.0 would be completelly different, or does it contain same pins as 0.3 (pluss relay which can simply be ignored?).
      I would use it for motion, temp+hum, door switch and light/lux meter, is it then safe to order rev 1.0 for such a sensor?
      And to order it, i usually/only need the .brd and sch files right?
      p.s. custom housing looks very slick :)
      H 1 Reply Last reply
      • D dakipro
        H Offline
        H Offline
        HenryWhite
        wrote on last edited by HenryWhite
        #63
        Rev 1.0 has nearly the same pins, except that you can only connect one switch (Rev 0.3: two switches) - but yes, you can simply ignore the relay, diode and transistor if you don't want to use a relay.
        Nonetheless, if you are sure that you will never use the board with a relay, I suggest that you go with Rev. 0.3.
        It depends on the pcb manufacturer, but most of the time you will need the gerber files (which can be generated with the .sch file through the CAM-processor with the .cam file (which the specific board house provides).
        PS: I ordered my boards from elecrow.
        • D Offline
          dakipro
          Thanks, I was ordering from oshpark before, but I see that elecrow has some nice prices as well.
          I noticed that you have _gerber.zip for 1.0, if you by any chance find _gerber.zip for 0.3 I would appreciate if you upload it to the thread :)
          (no, i am not lazy to convert them with eagle, but still not confortable and afreaid that I might select some wrong option :) )
          • D dakipro
            H Offline
            H Offline
            HenryWhite
            @dakipro here you go:
            0_1470866547655_Gerber_rev0.3.zip
            Be aware that this are the gerber files for the pcb service from elecrow. Other pcb services may have other specifications!
            • toufouT Offline
              toufouT Offline
              toufou
              Hi HenryWhite,
              Great job, very nice.
              I have some questions:
              • Why do you sent input voltage to A0? is it for voltage supervision?
              • Is it possible to have your sketch file?
              Thanks for your sharing,
              TouFou
              • toufouT toufou
                Hi HenryWhite,
                TouFou
                H Offline
                H Offline
                HenryWhite
                @toufou said:
                Hi HenryWhite,
                TouFou
                Hi, yes it's for measuring the battery level.
                You can find the schematics and all the other files in my first post.
                • toufouT Offline
                  toufouT Offline
                  toufou
                  Thanks for your reply.
                  In the first post, i see schematics, brd and gerber file, but i don't see .ino file to flash arduino pro mini.....
                  • toufouT toufou
                    H Offline
                    H Offline
                    HenryWhite
                    You can adapt the example sketches MySensors offers, it shouldn't be hard. Also the sketch will depend on what you plan to use the board for. (Motion, Switch, Temperature,...)
                    • toufouT Offline
                      toufouT Offline
                      toufou
                      wrote on last edited by toufou
                      #70
                      Ok!
                      I thought you had specific because your sensor is about 10month with arduino regulator! excellent.
                      Another question:
                      You use a motion sensor as i want. You make a reference to a hack to use it with 3.3V instead of 5V. Have you a link to see that?
                      • toufouT toufou
                        Ok!
                        Another question:
                        H Offline
                        H Offline
                        HenryWhite
                        Yes, here's a picture (the only thing you have to do is solder vcc to the HIGH-pad of your motion sensor):
