  3. Gas (Co2) sensors on batteries
24 Posts 4 Posters 14.6k Views 6 Watching
  • alexsh1A alexsh1
    @korttoma I got mine a month ago from China. I think it can be used with batteries, but it has to be something like 18650 3000mAh to last longer.
    K Offline
    K Offline
    korttoma
    @alexsh1 I was not planing on using it on batteries'. I now have an MQ-2 sensor in the ventilation fresh air intake to detect smoke but it has proven to be unreliable so I thought id try the MH-Z14 instead. Sometimes smoke comes in through the ventilation an then I want it to turn off automatically.
    • Tomas
    alexsh1A 1 Reply Last reply
    • K korttoma
      alexsh1A Offline
      alexsh1A Offline
      alexsh1
      @korttoma I think we are going the same way. I was not able to relay on my MQ135 and decided to order something more reliable.
      • K Offline
        K Offline
        korttoma
        I received my MH-Z14 yesterday hocked it up on a breadboard to test it and it seems to be working as expected. Now I need a more permanent setup so I can test and compare to a Netatmo indoor module. I may add an SI7021 to the same node.
        • Tomas
        • K korttoma
          alexsh1A Offline
          alexsh1A Offline
          alexsh1
          @korttoma I'll be adding BMP180 shortly as I need pressure and temperature to make a conversion.
