  3. INA219 DC Current Sensor
ina219
23 Posts 14 Posters 20.6k Views 8 Watching
  • chatainsimC Offline
    chatainsimC Offline
    chatainsim
    Thanks !
    • E Offline
      E Offline
      epierre
      has anyone made something usefull with the ACS712 yet ?
      z-wave - Vera -> Domoticz
      • M mainali
        I am using a two way switch to control my device. The idea is to control the state from arduino as well as physical switch parallely.
        Physical switch ON, Arduino can switch it OFF
        Arduino switches it ON, Physical switch whatever be the state on push should switch it OFF.
        I have used the Relay actuator example code from mysensor and little more code which I found in arduino forum.
        I am not able to use the plugin to embed the code, anyways the following is the code.
        // Example sketch showing how to control physical relays.
        // This example will remember relay state even after power failure.
        #define RELAY_1 2 // Arduino Digital I/O pin number for first relay (second on pin+1 etc)
        #define RELAY_2 3
        #define RELAY_ON 1 // GPIO value to write to turn on attached relay
        #define CHILD_ID 1
        #define CURRENT_SENSOR A0 // Analog input pin that sensor is attached to
        MyMessage msg(CHILD_ID, V_TRIPPED); //Using this as the message to report the physical switch on status
        float amplitude_current; //amplitude current
        float effective_value;
        bool switch_1_on;
        int count = 0;
        gw.begin(incomingMessage, 21, true);
        gw.sendSketchInfo("Relay with current sensor", "1.0");
        pins_init();
        // Fetch relay status
        gw.present(sensor, S_LIGHT);
        pinMode(pin, OUTPUT);
        digitalWrite(pin, gw.loadState(sensor)?RELAY_ON:RELAY_OFF);
        int sensor_max;
        sensor_max = getMaxValue();
        Serial.print("sensor_max = ");
        Serial.println(sensor_max);
        //the VCC on the Grove interface of the sensor is 5v
        amplitude_current=(float)(sensor_max-512)/10245/1851000000;
        effective_value=amplitude_current/1.414;
        //minimum_current=1/10245/1851000000/1.414=18.7(mA)
        //Only for sinusoidal alternating current
        Serial.println("The amplitude of the current is(in mA)");
        Serial.println(amplitude_current,1);//Only one number after the decimal point
        Serial.println("The effective value of the current is(in mA)");
        Serial.println(effective_value,1);
            if (count == 0 && amplitude_current > 30) {
               switch_1_on = true;
              Serial.println("physical switch on");
              gw.send(msg.set(switch_1_on?"1":"0"));
              count = 1 ;
            else {
              count = 0 ;
        gw.process();
        if (message.type == V_FAN) {
        Serial.println("Message arrived for FAN");
        Serial.println(message.sensor);
        for(int i=4 ; i<=7; i++) {
        digitalWrite(i,0);
        if (message.type==V_LIGHT) {
        // Change relay state
        // Store state in eeprom
        // Write some debug info
        Serial.print(message.sensor);
        void pins_init()
        pinMode(CURRENT_SENSOR, INPUT);
        /Function: Sample for 1000ms and get the maximum value from the S pin/
        int getMaxValue()
        int sensorValue; //value read from the sensor
        int sensorMax = 0;
        uint32_t start_time = millis();
        while((millis()-start_time) < 1000)//sample for 1000ms
        sensorValue = analogRead(CURRENT_SENSOR);
        if (sensorValue > sensorMax)
        /record the maximum sensor value/
        sensorMax = sensorValue;
        return sensorMax;
        jeremushkaJ Offline
        jeremushkaJ Offline
        jeremushka
        @mainali said in INA219 DC Current Sensor:
        I am building similar system. However, i am facing a lot of difficulties to make the ACS712 working. I have tried your code as well without success. The effective value of the current is always 0 mA even if the light is ON.
        For the moment, i am testing with 5V current and i switch on a LED. maybe the current is too low to make working my 20A ACS712?
        If anyone has some ideas, it will be very greatful :) Thanks a lot.
