  3. Number of decimals in sketches
3 Posts 3 Posters 1.7k Views 1 Watching
    moskovskiy82
    I don't want the emperature humidity to be as precise as in the sketch which has 2 decimal points.
    So for the humidity i rewrote the sketch as such
      float hum_floa = dht.getHumidity();
      float humidity = round (hum_floa);
    It works but the data is still sent as yy.xx
    Is there a simple way to make it as yy only?
    • sundberg84S
      There are probably better ways but:
      hum_floa.remove(temp.indexOf('.') + 2)
      Dont know the dht lib, maybe you can set some settings there to recieve without decimals.
      This will not round but just cut/remove the last digits after "."
      • E
        E
        ericvdb
        If you use Set to send your temp/hum you can define how many decimals you want:
        MyMessage& set(float value, uint8_t decimals);
        For example:
        will send you the value with 1 decimal.
        Reference: here
