  3. Domoticz
  4. Water leak
Water leak
5 Posts 2 Posters 4.2k Views 1 Watching
  • alexsh1A Offline
    alexsh1A Offline
    alexsh1
    Hello all,
    Does anyone have a sketch for a water leak (on batteries) please?
    I know there is an irrigation sketch discussed here
    http://forum.mysensors.org/topic/1866/how-do-i-add-the-soil-moisture-sensor-to-domoticz/2
    but I'd like to have a simple sketch:
    1. yes / no leak
    2. battery voltage
    probably, I need to start with a door/winter open/close detection and work it out for a water leak (S_WATER_LEAK)
    Alex
    • S Offline
      Have a look here http://forum.mysensors.org/topic/1761/water-leak-detection/2
      • alexsh1A Offline
        alexsh1A Offline
        alexsh1
        @sundberg84 Thanks - I saw this post, but it is far too complex for my needs. I need a simple detection. I have built one on Particle Photon similar to this, but it is not cost efficient as now I need 3-4 of such nodes (Particle Core + sensor = Euro 25-30).
        All I need is Pro mini sleeping and if there is water detected, sending notification to Domoticz.
        • S Offline
          @alexsh1 - Dont know how safe it will be, but the simpliest would be to have a standard mysensorslink text button/reed switch sketch. Strip two wires and put side by side where you dont want water and when water arrives it will short the wires, causing an interupt and trigger a notification.
          With stripped wires, check this: https://www.youtube.com/watch?v=wXdzyjNHsLQ
          alexsh1A 1 Reply Last reply
          • S sundberg84
            alexsh1A Offline
            alexsh1A Offline
            alexsh1
            I finally decided to go for a similar detection as pictured, but with Arduino Pro Mini powered by a battery in a sleeping mode.
            12.2k
