  3. OpenHAB
  4. openHAB binding
openHAB binding
89 Posts 30 Posters 75.3k Views 33 Watching
  • Peter ŠuľajP
    Peter ŠuľajP
    Peter Šuľaj
    Hello I have a trouble with binding.
    My gateway 1.5.4 still only show
    [DEBUG] [.b.m.internal.MySensorsBinding] - Gateway Version: 1.5.4
    2016-07-20 15:30:58.044 [DEBUG] [.b.m.internal.MySensorsBinding] - I_LOG_MESSAGE: read: 255-255-0 s=255,c=3,t=3,pt=0,l=0,sg=0:
    2016-07-20 15:31:00.060 [DEBUG] [.b.m.internal.MySensorsBinding] - I_LOG_MESSAGE: read: 255-255-0 s=255,c=3,t=3,pt=0,l=0,sg=0:
    2016-07-20 15:31:02.067 [DEBUG] [.b.m.internal.MySensorsBinding] - I_LOG_MESSAGE: read: 255-255-0 s=255,c=3,t=3,pt=0,l=0,sg=0:
    2016-07-20 15:31:04.074 [DEBUG] [.b.m.internal.MySensorsBinding] - I_LOG_MESSAGE: read: 255-255-0 s=255,c=3,t=3,pt=0,l=0,sg=0:
    but nothing else .
    I tested lot of sensor but still same error.
    Have you any idea ?
    jerseyguy1996J 1 Reply Last reply
    • Peter ŠuľajP Peter Šuľaj
      but nothing else .
      Have you any idea ?
      jerseyguy1996J
      jerseyguy1996J
      jerseyguy1996
      @Peter-Šuľaj I'm fairly new to this stuff, but curious if you are trying to auto-assign node ID? I don't believe the MySensorsBinding supports auto-assign so you have to define it as static and use:
      #define NODEID  3 //or whatever
      //and then call this in your setup instead of Sensor.begin();
      Sensor.begin(NULL, NODEID);
      in your script. Again, not sure if this is your problem but I figured I would chime in.
      • bklB bkl
        @NickBuilder
        Hi
        No need for a new version, baudrate is configurable
        just set.
        mysensors:baudrate=38400
        NickBuilderN
        NickBuilderN
        NickBuilder
        @bkl
        Hello again!
        Is there also support for sending the ack bit from the gw in some way? I saw that this is actually possible in the 2.0 binding. If it's possible how is a "not ack" handled? This would be very useful for e.g. a relay sensor.
        I also noticed that you're not the author of the 2.0 binding, I'm sorry for making that assumption.
        Thanks!
        • jerseyguy1996J
          jerseyguy1996J
          jerseyguy1996
          This binding works perfectly! Thanks for putting it together!
          • HenryWhiteH
            HenryWhiteH
            HenryWhite
            Thanks for the Binding! It would be very nice if you could implement SmartSleep, so that the node sends a heartbeat message to the Controller when waking up.
            • Alex SchickA
              Alex SchickA
              Alex Schick
              I had a working serial Gateway and one temp sensor setup.
              I now updated to 2.0 version for both but I can't see the gateway working with openhap while the sensor can send it's data fine it looks.
              Any idea what could be the problem?
              Sensor Serial log:
              TSM:INIT
              TSM:RADIO:OK
              TSP:ASSIGNID:OK (ID=1)
              TSM:FPAR
              TSP:MSG:SEND 1-1-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=bc:
              TSP:MSG:READ 0-0-1 s=255,c=3,t=8,pt=1,l=1,sg=0:0
              TSP:MSG:PAR OK (ID=0, dist=1)
              TSM:FPAR:OK
              TSM:ID
              TSM:CHKID:OK (ID=1)
              TSM:UPL
              TSP:PING:SEND (dest=0)
              TSP:MSG:SEND 1-1-0-0 s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=ok:1
              TSP:MSG:READ 0-0-1 s=255,c=3,t=25,pt=1,l=1,sg=0:1
              TSP:MSG:PONG RECV (hops=1)
              TSP:CHKUPL:OK
              TSM:UPL:OK
              TSM:READY
              TSP:MSG:SEND 1-1-0-0 s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=ok:0100
              !TSP:MSG:SEND 1-1-0-0 s=255,c=0,t=17,pt=0,l=5,sg=0,ft=0,st=fail:2.0.0
              TSP:MSG:SEND 1-1-0-0 s=255,c=3,t=6,pt=1,l=1,sg=0,ft=1,st=ok:0
              TSP:MSG:SEND 1-1-0-0 s=255,c=3,t=11,pt=0,l=18,sg=0,ft=0,st=ok:Temperature Sensor
              TSP:MSG:SEND 1-1-0-0 s=255,c=3,t=12,pt=0,l=3,sg=0,ft=0,st=ok:1.1
              TSP:MSG:SEND 1-1-0-0 s=0,c=0,t=6,pt=0,l=0,sg=0,ft=0,st=ok:
              Request registration...
              TSP:MSG:SEND 1-1-0-0 s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=ok:2
              TSP:MSG:READ 0-0-1 s=255,c=3,t=27,pt=1,l=1,sg=0:1
              Node registration=1
              Init complete, id=1, parent=0, distance=1, registration=1
              TSP:MSG:SEND 1-1-0-0 s=0,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=ok:24.7
              Openhab:
              2016-08-22 10:23:43.295 [DEBUG] [ySensorsGenericBindingProvider] - New Item "tempWhz1 (Type=NumberItem, State=Uninitialized)" based on configuration "1;0;V_TEMP"
              2016-08-22 10:23:43.331 [DEBUG] [.b.m.internal.MySensorsBinding] - activate
              2016-08-22 10:23:43.342 [DEBUG] [.o.b.m.internal.gateway.Serial] - Serial port '/dev/ttyAMA0' has been found.
              2016-08-22 10:23:43.353 [INFO ] [.service.AbstractActiveService] - MySensors Refresh Service has been started
              And nothing else more on the openhab.log even I restart the sensor node.
              Alex SchickA 1 Reply Last reply
              • Alex SchickA Alex Schick
                Sensor Serial log:
                TSM:INIT
                TSM:RADIO:OK
                TSM:FPAR
                TSM:FPAR:OK
                TSM:ID
                TSM:CHKID:OK (ID=1)
                TSM:UPL
                TSP:CHKUPL:OK
                TSM:UPL:OK
                TSM:READY
                Node registration=1
                Openhab:
                Alex SchickA
                Alex SchickA
                Alex Schick
                wrote on last edited by Alex Schick
                #67
                @Alex-Schick
                I recognized that baudrate switched for gateway to 74880 instead of 115200 as before.
                That is related to https://forum.mysensors.org/topic/1483/trouble-with-115200-baud-on-3-3v-8mhz-arduino-like-serial-gateway-solution-change-baudrate/9
                Changed by adding setting in open hab mysensors:baudrate=74880
                But opening serial on the raspberry I only see rubish (fine when connected to PC). So connection seems to be not ok....
                EDIT: Got it sorted. Flashed for 16mhz and it worked fine with baud rate 38400.
                  momanz11
                  wrote on last edited by momanz11
                  #68
                  Greetings All,
                  I would very much like to download this binding, but the download link appears to be broken. Any possibility we could fix the link or repost the binding jar file.
                  Looks like the server is back up!
                  Thanks!
                  Momanz
                  • S
                    sensorchecker
                    wrote on last edited by sensorchecker
                    #69
                    Hello all,
                    i use a ATMEGA328P with internal clock (MysBootloader) and have a 4-channel relay board connected at the Arduino outputs D3-D6 (current MySensors Example Sketch).
                    As central unit i use a RaspberryPi with openhab 1.8 and a serial gateway (Arduino Nano) and the MySensors- OpenHAB serial binding of @bkl
                    The OpenHab item looks like this:
                    Switch Lights_Downlights_Front "Downlights Front" <selfLight> (Outdoor, Lights_Outdoor) {mysensors="54;1;V_STATUS"}
                    Unfortunately I can not switch the relays ON or OFF.
                    Many other sensors (Temp, Hum, Rain) works fine with this environment.
                    Any help is appreciated!
                    Greets & Thanks
                    NickBuilderN 1 Reply Last reply
                    • NickBuilderN
                      NickBuilderN
                      NickBuilder
                      Hi @bkl and all other user of this great binding!
                      I would like to know if its possible to send a message using this binding. I will try to explain my problem.
                      I've built the "EnergyMeterPulseSensor.ino" sensor and I have it up and running. The sketch request a starting number for the count loop and if the item in Openhab has been initialized this value is sent back per request.
                      This request function is only active before the actual count begins.
                      I would now like to be able to reset the counter each midnight but as the sensor only requests the start count value at each startup I would have to manually restart the sensor at the same time as I have "reinitialized" the count item with a "0".
                      I now see two ways of doing this if this binding allows it:
                      • 1: Send a "I_REBOOT" in some way through the binding directly after manually updating the count item with a "0".
                      • 2: Sending a new count value via the V_VAR1 parameter. This would be preferable I guess.
                      In this thread @stoffej is after the same thing. I've tried the same approach using a myPulsecountItem.sendCommand(0) but other than adding a "0" to the persistence service nothing happens. The count continues where it left off. So my guess is that there is no actual message sent to the sensor. Sadly I don't get any useful information from the debug-xml. I don't know where @stoffej got the debug message I_LOG_MESSAGE:..., my serial debugging interface towards the gateway is occupied.
                      My count item is defined as:
                      Number  myElecVar "Elmätare pulser [%d]" {mysensors="50;1;V_VAR1"}
                      I guess if I could utilize a switch item in some way I could send a message in the same way as in the relay implementation. For a switch I know that a message is being sent as I've built one of those myself but the switch can only send "on" or "off".
                      Here's the receive function from the sketch:
                        if (message.type==V_VAR1) {
                          Serial.println(pulseCount);
                          pcReceived = true;
                      Assistance is much appreciated!
                      bklB 1 Reply Last reply
                      • S sensorchecker
                        Hello all,
                        Greets & Thanks
                        NickBuilderN
                        NickBuilderN
                        NickBuilder
                        @sensorchecker Hi!
                        Its not easy helping you using only the posted information. Any debug logs available from Openhab or the serial interface terminal?
                        My item defintion looks the same:
                        Switch Lampa <light> {mysensors="40;1;V_STATUS"}
                        • Kodiak80K
                          Kodiak80K
                          Kodiak80
                          I'm trying to get a single Dallas Temp sensor displayed in OpenHAB using the Serial Gateway. I'm running the MySensors v2 Dallas Temp sketch, and I'm seeing my sensor in the logs. However, I'm getting the following:
                          2016-09-28 07:34:21.805 [ERROR] [i.internal.GenericItemProvider] - Binding configuration of type 'mysensors' of item ?Temperature? could not be parsed correctly.
                          java.lang.NullPointerException: null
                          	at java.util.regex.Matcher.getTextLength(Matcher.java:1234) ~[na:1.7.0_101]
                          	at java.util.regex.Matcher.reset(Matcher.java:308) ~[na:1.7.0_101]
                          	at java.util.regex.Matcher.<init>(Matcher.java:228) ~[na:1.7.0_101]
                          	at java.util.regex.Pattern.matcher(Pattern.java:1088) ~[na:1.7.0_101]
                          	at org.openhab.binding.mysensors.internal.MySensorsGenericBindingProvider.validateItemType(MySensorsGenericBindingProvider.java:57) ~[na:na]
                          	at org.openhab.model.item.internal.GenericItemProvider.internalDispatchBindings(GenericItemProvider.java:347) [org.openhab.model.item_1.8.3.jar:na]
                          	at org.openhab.model.item.internal.GenericItemProvider.internalDispatchBindings(GenericItemProvider.java:324) [org.openhab.model.item_1.8.3.jar:na]
                          	at org.openhab.model.item.internal.GenericItemProvider.processBindingConfigsFromModel(GenericItemProvider.java:171) [org.openhab.model.item_1.8.3.jar:na]
                          	at org.openhab.model.item.internal.GenericItemProvider.modelChanged(GenericItemProvider.java:390) [org.openhab.model.item_1.8.3.jar:na]
                          	at org.openhab.model.core.internal.ModelRepositoryImpl.notifyListeners(ModelRepositoryImpl.java:159) [org.openhab.model.core_1.8.3.jar:na]
                          	at org.openhab.model.core.internal.ModelRepositoryImpl.addOrRefreshModel(ModelRepositoryImpl.java:100) [org.openhab.model.core_1.8.3.jar:na]
                          	at org.openhab.model.core.internal.folder.FolderObserver.checkFolder(FolderObserver.java:142) [org.openhab.model.core_1.8.3.jar:na]
                          	at org.openhab.model.core.internal.folder.FolderObserver.run(FolderObserver.java:99) [org.openhab.model.core_1.8.3.jar:na]
                          My item definition looks like the following:
                          Number  Temperature           "Temp [%s °C]"     <temperature>   (gBio,gTemperature)     {mysensors=105;1;V_TEMP}
                          As a follow-on, I've been trying to understand the {mysensors=105;1;V_TEMP} binding and what the semicolon separated values represent. So far I've been following example code, and haven't found the right documentation. Can someone point me to the right place? I appreciate any help.
                          • NickBuilderN NickBuilder
                                pcReceived = true;
                            bklB
                            bklB
                            bkl
                            @NickBuilder
                            From what i know sendCommand should be the way to go.
                            myElecVar.sendCommand(0);
                            That should send the value to your sensor, and then update its value of pulseCount
                            • Kodiak80K Kodiak80
                              bklB
                              bklB
                              bkl
                              Hi @Kodiak80
                              Your are missing the " item definition should be.
                              Number  Temperature           "Temp [%s °C]"     <temperature>   (gBio,gTemperature)     {mysensors="105;1;V_TEMP"}
                              The values is just
                              node-id;child-sensor-id;sub-type
                              • bklB bkl
                                @NickBuilder
                                NickBuilderN
                                NickBuilderN
                                NickBuilder
                                @bkl
                                Ok. But for some reason the new value is not accepted in my case. I will try and see if the serial terminal, when connected to the sensor, will give a hint on what’s going on. It would be nice if the debug of the binding could show what is actually being sent to (and possibly through) the gateway. Is this possible already by ”activating” a certain debug.xml module?
                                The serial binding is quite clear in this regard as the message with payload according to the mysensor protocol is displayed in the debug log.
                                • Velo17V
                                  Velo17V
                                  Velo17
                                  ...trying to download the jar from the link in the first post, but server is not reachable. Is there any other URL to this .jar?
                                  • jerseyguy1996J
                                    jerseyguy1996J
                                    jerseyguy1996
                                    @bkl First off I want to thank you for the MySensors openhab binding. It works wonderfully!
                                    In the MySensors 2.0 there is an internal message that doesn't seem to be handled by the binding. I believe it needs to be handled in MySensorsBinding.java. I would do it myself but my knowledge of Java sucks....to put it lightly. The internal message is:
                                    I_DISCOVER_RESPONSE
                                    so my openhab log keeps getting spammed with:
                                    2016-10-21 22:16:21.653 [INFO ] [.b.m.internal.MySensorsBinding] - No item configured for "4;255;I_DISCOVER_RESPONSE"
                                    2016-10-21 22:26:21.374 [INFO ] [.b.m.internal.MySensorsBinding] - No item configured for "4;255;I_DISCOVER_RESPONSE"
                                    2016-10-21 22:36:22.127 [INFO ] [.b.m.internal.MySensorsBinding] - No item configured for "4;255;I_DISCOVER_RESPONSE"
                                    2016-10-21 22:46:21.847 [INFO ] [.b.m.internal.MySensorsBinding] - No item configured for "4;255;I_DISCOVER_RESPONSE"
                                    2016-10-21 22:56:21.569 [INFO ] [.b.m.internal.MySensorsBinding] - No item configured for "4;255;I_DISCOVER_RESPONSE"
                                    I'm assuming that we just need to add a line to:
                                    public void incommingMessage(Message message)
                                    to handle it but I would rather let you do it since like I said....I suck with Java. Is that something that would be an easy fix?
                                    • A
                                      A
                                      andreground
                                      Ethernet gw binding source seems to be missing in github repo.
                                      Any clue?
                                      : Compilation failure:
                                      [ERROR] /root/openhab/bundles/binding/org.openhab.binding.mysensors/src/main/java/org/openhab/binding/mysensors/internal/MySensorsBinding.java:[17]
                                      [ERROR] import org.openhab.binding.mysensors.internal.gateway.Ethernet;
                                      [ERROR] ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^
                                      [ERROR] The import org.openhab.binding.mysensors.internal.gateway.Ethernet cannot be resolved
                                      [ERROR] /root/openhab/bundles/binding/org.openhab.binding.mysensors/src/main/java/org/openhab/binding/mysensors/internal/MySensorsBinding.java:[117]
                                      [ERROR] gateway = new Ethernet(prop.getProperty("host"), Integer.parseInt(prop.getProperty("port", "5003")));
                                      [ERROR] ^^^^^^^^
                                      [ERROR] Ethernet cannot be resolved to a type
                                      [ERROR] 2 problems (2 errors)
                                      [ERROR] -> [Help 1]
                                      [ERROR]
                                      [ERROR] To see the full stack trace of the errors, re-run Maven with the -e switch.
                                      [ERROR] Re-run Maven using the -X switch to enable full debug logging.
                                      [ERROR]
                                      [ERROR] For more information about the errors and possible solutions, please read the following articles:
                                      [ERROR] [Help 1] http://cwiki.apache.org/confluence/display/MAVEN/MojoFailureException
                                      [ERROR]
                                      [ERROR] After correcting the problems, you can resume the build with the command
                                      [ERROR] mvn <goals> -rf :org.openhab.binding.mysensors
                                      • F
                                        F
                                        Fritzin
                                        How do I add the "my-sensors" add on to openhab2.0. I openhab2 up and running based on their rasp-image. I have downloaded a couple other adds and install just fine. I don't know how to place the .jar file into the adds. Is there a clear guide on how to get this done ? PLS HELP!
                                        • andredtsA
                                          andredtsA
                                          andredts
                                          @bkl Hi,
                                          Use this biding from it`s beginning, many thanks again. Just want to know if there is any function like the "ack" as there is on OH2 binding, where gateway re-sends the msg 5 times if it does not hear from the sensor after a command. It´s a killer function to make it more reliable, but I´m not ready for OH2 yet.
