  3. Requesting time from MQTT/Openhab - How?
mqtt openhab
3 Posts 1 Posters 2.0k Views 1 Watching
  • greglG
    greglG
    gregl
    Im currently scratching my head trying to work out the best way to provide a sensor the current time, via MQTTClientGateway and Openhab.
    I don't have access to my hardware here ( im at work ) so cant test a lot of this, but I thought id put it out here now in case anyone has some ideas/thoughts..or solution ;-)
    Q: What message is sent to MQTT when a sensor node requests the time?
    Q: What does the Openhab "item" look like to watch for the request. This would then run a rule to return the epoch time back to the sensor node.
    Q: What MQTT message needs to be returned to the node?
    • greglG
      greglG
      gregl
      To answer myself, the mqtt message sent is onto topic
      mygateway1-out/x/255/3/0/1
      (where x is the node id )
      and the reply is likewise sent back to
      mygateway1-in/4/255/3/0/1 - with a payload being the epoch time
      So now to work out the plumbing within Openhab. I already have a Number item with the epoch time (albeit in UTC)...so just need to work on the rules.
      • greglG
        greglG
        gregl
        My memory is sh*t.... i even replied to this relevant post!
        http://forum.mysensors.org/topic/812/realtimeclockdisplaysensor-ino-no-fetch-time-from-controller/6
