  3. writing a code for 2 relays with 2 buttons and actuators
5 Posts 2 Posters 2.6k Views 5 Watching
  • SandeshHs94S
    SandeshHs94S
    SandeshHs94
    i want to add two buttons and two relays, i dont understand on how to combine them.
    I am having trouble with the incomingMessage function. The relay with Actuator example works fine but it does not have a button, what if i want a button or if i have relays on non-consecutive pins.
    i tried writing two functions for incoming message and it was just a foolish idea and i'm stuck.
    how do i get it to work.. please help..
    BartEB 1 Reply Last reply
    • SandeshHs94S SandeshHs94
      BartEB
      BartEB
      BartE
      wrote on last edited by BartE
      @SandeshHs94 The MySensors library RelayActuator example shows how to handle 2 (or more) child node messages. There is no need to change this incommingMessage function when adding a button. Adding button requires read functionality in the loop()
      This sketch should work with 2 buttons (attached to pin 6 and 7)
       * Version 1.0 - Henrik Ekblad
      #include <MySigningNone.h>
      #include <MyTransportNRF24.h>
      #include <MyTransportRFM69.h>
      #include <MyHwATMega328.h>
      #include <Bounce2.h>
      #define BUTTON_PIN_1 6
      //MyTransportRFM69 radio;
      //MySigningNone signer;
      MyHwATMega328 hw;
      MySensor gw(radio, hw);
      MyMessage msg[NUMBER_OF_RELAYS] = { MyMessage(1, V_LIGHT), MyMessage(2, V_LIGHT) } ;
      Bounce debouncer[NUMBER_OF_RELAYS] = { Bounce(), Bounce() };
        gw.sendSketchInfo("Relay", "1.0");
        // Fetch relay status
        for (int sensor=1, pin=RELAY_1, swpin=BUTTON_PIN_1; sensor <= NUMBER_OF_RELAYS;sensor++, pin++, swpin++) {
          gw.present(sensor, S_LIGHT);
          pinMode(pin, OUTPUT);
          digitalWrite(pin, gw.loadState(sensor)?RELAY_ON:RELAY_OFF);
          // Setup the button
          pinMode(swpin, INPUT);
          // Activate internal pull-up
          digitalWrite(swpin, HIGH);
          debouncer[sensor-1].attach(swpin);
          debouncer[sensor-1].interval(5);
        gw.process();
        for (int sensor = 0; sensor < NUMBER_OF_RELAYS; sensor++) {
            if (debouncer[sensor].update() && debouncer[sensor].read()) {
               gw.send(msg[sensor].set( (gw.loadState(sensor+1) ? RELAY_OFF : RELAY_ON)), true);
        if (message.type==V_LIGHT) {
           // Change relay state
           // Store state in eeprom
           // Write some debug info
           Serial.print(message.sensor);
      • SandeshHs94S
        SandeshHs94S
        SandeshHs94
        amazing.. thanks a lot but what about if i have to combine relayActuatorWithButton and
        relayActuator..
        do you have any code for that?
        and please explain what this line means and how it works..
        and how i can make the combination work without a for loop
        Thank you
        • BartEB
          BartEB
          BartE
          @SandeshHs94 The sketch exactly is that: a combination of the relayActuatorWithButton and
          relayActuator.. examples
          This line does several things
          message.getBool() --> gets the "payload of the message" in this case 1=ON or 0=OFF
          message.sensor --> gives the node id for which the message is meant for
          RELAY_1 --> is the first pin definition (for this sketch 3)
          RELAY_ON --> equals pin HIGH
          RELAY_OFF --> equals pin LOW
          digitalWrite(pin, value); --> sets an output pin in this case pin: message.sensor-1+RELAY_1 (so either pin 3 for node 1 or pin 4 for node 2 messages)
          The ? is a short notation for an if statement so when the message.getBool() = 1 the pin is set to HIGH and when 0 the pin is set to LOW
          I'm not sure why you want no "for-loop", but the sketch would look like this example
          #define RELAY_2  4  // Arduino Digital I/O pin number for first relay (second on pin+1 etc)
          #define BUTTON_PIN_2 7
          MyHwATMega328 hw;
          MyMessage msg1(1, V_LIGHT);
          MyMessage msg2(2, V_LIGHT);
          Bounce debouncer1 = Bounce();
          Bounce debouncer2 = Bounce();
            gw.present(1, S_LIGHT);
            pinMode(RELAY_1, OUTPUT);
            digitalWrite(RELAY_1, gw.loadState(1)?RELAY_ON:RELAY_OFF);
            // Setup the button
            pinMode(BUTTON_PIN_1, INPUT);
            digitalWrite(BUTTON_PIN_1, HIGH);
            debouncer1.attach(BUTTON_PIN_1);
            debouncer1.interval(5);
            gw.present(2, S_LIGHT);
            pinMode(RELAY_2, OUTPUT);
            digitalWrite(RELAY_2, gw.loadState(2)?RELAY_ON:RELAY_OFF);
            // Setup the button
            pinMode(BUTTON_PIN_2, INPUT);
            digitalWrite(BUTTON_PIN_2, HIGH);
            debouncer2.attach(BUTTON_PIN_2);
            debouncer2.interval(5);
            gw.process();
            if (debouncer1.update() && debouncer1.read()) {
                gw.send(msg1.set( (gw.loadState(1) ? RELAY_OFF : RELAY_ON)), true);
            if (debouncer2.update() && debouncer2.read()) {
                gw.send(msg2.set( (gw.loadState(2) ? RELAY_OFF : RELAY_ON)), true);
          • SandeshHs94S
            SandeshHs94S
            SandeshHs94
            I'm so sorry for such late reply... the reason i wanted no for loop was to see how the code for that would turn out...
            I have a project in mind with requires maybe 2 switches and if one is turned on then regardless of the message coming from controller for the second light it should stay off...
