  3. Powering nodes (3.3V) with 18650/26650
8 Posts 2 Posters 4.4k Views 2 Watching
  • alexsh1A
    alexsh1A
    alexsh1
    I am trying to power my node with 18650 or 26650 battery and have the following issue. The normal voltage of a fully charged battery is 4.2V and this is not tolerable by atmega328p. I tried to use AMS1117-3.3, but for this dropout voltage is about 1.1V, which is no use. Any recommendation on LDO how to power 3.3V properly given that battery voltage may drop to 2.75V?
    The other option is to use 3.2V LiFePo4 battery (they provide 3.4V fully charged), but these are more difficult to come by.
    Any ideas please?
    • AWIA
      AWIA
      AWI
      In most cases I use a 662K regulator in one of its housing variations. This regulator is also used on many of the 5v compatible I2C sensor boards. You can even power your circuit from the sensor board if a connection is available.
      0_1457002952962_upload-ee41d5bd-e95d-4117-87d0-f1a2268a558a on the Slim AA node
      0_1457003413549_upload-2c2cd5a6-282d-4537-a9a1-cb00870c37eb
      BMP180 with regulator and 3.3v output/input (other type of LDO)
      • alexsh1A
        alexsh1A
        alexsh1
        @AWI - Thanks. I was thinking about XC6206P332MR, but not sure how it behaves when voltage drops to, say, 2.7V?
        AWIA 1 Reply Last reply
        • alexsh1A alexsh1
          AWIA
          AWIA
          AWI
          @alexsh1 Thats the same component (662k) ;-) Don't worry about voltages below 2.7v, your battery will be dead by then :cold_sweat:
          0_1457004531508_upload-292d9e16-d7b6-420c-b3e0-41a8e16c62ed
          alexsh1A 1 Reply Last reply
          • alexsh1A
            alexsh1A
            alexsh1
            Just checked the datasheet:
            Output voltage range: 1.2V ~ 5.0V (0.1V increments).
            I can see they recommend using 1mF capacitors on pin 3 (VCC) and 2 (+3.3V)
            • AWIA AWI
              alexsh1A
              alexsh1A
              alexsh1
              @AWI Thanks - I am not concerned about below 2.7V as my battery PCB will cut it off anyway :)
              And yes I am aware this is the same component.
              Very useful diagram! Thanks
              Will be placing an order for XC6206P332MR
              • alexsh1A alexsh1
                AWIA
                AWIA
                AWI
                @alexsh1 You will probably need the 3.3 version. Any ceramic capacitor between 100nF and 1uF will do (1mF = 1000uF, is a litte to much ;-) ) I hold a stock of 'multi purpose' 100nF capacitors.
                • AWIA AWI
                  alexsh1A
                  alexsh1A
                  alexsh1
                  @AWI Right - I have about 50 104 (100nF) in my stock - they are very typical for atmega projects.
                  Thanks once again for your help
