  3. Building a WiFi Gateway with ESP-01
7 Posts 3 Posters 3.5k Views 3 Watching
  • DrKuebelD Offline
    DrKuebelD Offline
    DrKuebel
    Hi all,
    I´m trying to build a WiFi Gateway using a ESP-1 with 8 Pins.
    Unfortunately I did not manage to wire it up like discribed here:
    http://www.mysensors.org/build/esp8266_gateway
    The mentioned pins are not named the same way..
    • nRF24L01+ ESP8266
    • VCC VCC
    • CE GPIO4
    • CSN/CS GPIO15
    • SCK GPIO14
    • MISO GPIO12
    • MOSI GPIO13
    • GND GND
    On the ESP-1 the Pins are named:
    VCC
    GND
    TXD
    RXD
    CH_PD
    GPIO0
    GPIO2
    RST Reset
    Could anybody give me a hint?
    H 1 Reply Last reply
    • mfalkviddM Offline
      I've been using this image:
      from http://smarpl.com/content/esp8266-esp-201-module-first-impressions to map IO ports. Even printed it on paper to make it easy to reference. Maybe ESP-1 is similar enough?
      Edit: No, it looks like ESP-01 exposes too few pins to be usable? At least according to http://www.electrodragon.com/w/Category:ESP8266_Basic_Usage
      • DrKuebelD DrKuebel
        Hi all,
        • nRF24L01+ ESP8266
        • VCC VCC
        • CE GPIO4
        • CSN/CS GPIO15
        • SCK GPIO14
        • MISO GPIO12
        • MOSI GPIO13
        • GND GND
        VCC
        GND
        TXD
        RXD
        CH_PD
        GPIO0
        GPIO2
        RST Reset
        H Offline
        H Offline
        Heizelmann
        @DrKuebel ESP-01 has not enough general purpose data pins. Besides Vcc and GND you need 5 GPIOs. ESP-01 only has 4.
        • DrKuebelD Offline
          DrKuebelD Offline
          DrKuebel
          Thanks...
          so I will buy me a new one... wich ESP-?? would you recommend?
            Most people probably use the NodeMCU since it is recommended on the build page: http://www.mysensors.org/build/esp8266_gateway
            A nice comparison is available at http://blog.squix.ch/2015/03/esp8266-module-comparison-esp-01-esp-05.html (scroll to the bottom for a comparison table)
              Thanks...
              H Offline
              H Offline
              Heizelmann
              Depends on. An ESP-12 would be minimalistic. An ESP-201 can be used in breadboards. A node-MCU is a complete development board including the programming interface. But there are a lot of others.
              • DrKuebelD Offline
                DrKuebelD Offline
                DrKuebel
                Thanks for the fast help... I´ll try the NodeMCU
