  3. Binary Switch Timer
Binary Switch Timer
6 Posts 2 Posters 2.0k Views 2 Watching
  • mikeg291M
    mikeg291M
    mikeg291
    I am trying to use the Binary switch example to monitor the state of a Switch .I want to be able to measure the length of time the switch is not in its normal state e.g.. "how long was the door/window open" I have found numerous timer sketch's but they seem to be for timing when something should happen . Anyone have suggestions or example sketch's
    BartEB 1 Reply Last reply
    • mikeg291M mikeg291
      BartEB
      BartEB
      BartE
      wrote on last edited by BartE
      @mikeg291 You can store the epoch time on state open (now();) and again on state close and subtract those values.
      But you have to init the time module with the GW time first. something like this sketch should work
      #include <Bounce2.h>
      #include <Time.h>
      #define CHILD_ID 3
      #define BUTTON_PIN  3  // Arduino Digital I/O pin for button/reed switch
      Bounce debouncer = Bounce();
      int oldValue=-1;
      time_t  lastSwitchTime = 0;
      void receiveTime(unsigned long controllerTime);
      bool timeReceived = false;
        gw.begin();
       // Setup the button
        pinMode(BUTTON_PIN,INPUT);
        // Activate internal pull-up
        debouncer.attach(BUTTON_PIN);
        debouncer.interval(5);
         gw.present(CHILD_ID, S_DOOR);
        // Make sure we get the system time, repeat request every 5 seconds until we have a valid time
        gw.requestTime(receiveTime);
        unsigned long lastRequest = millis();
        if ((millis() - lastRequest) >  5000) {
            gw.wait(100);
         lastSwitchTime = now();
        debouncer.update();
        // Get the update value
        int value = debouncer.read();
        if (value != oldValue) {
           Serial.print("Switch was ");
           Serial.print(oldValue ? "ON" : "OFF");
           Serial.print(" for: ");
           Serial.print(now() - lastSwitchTime);
           Serial.println(" seconds");
           // Send in the new value
           gw.send(msg.set(value==HIGH ? 1 : 0));
           oldValue = value;
      // This is called when a new time value was received
      void receiveTime(unsigned long controllerTime) {
         // OK, set incoming time
         Serial.print(F("Time value received: "));
         Serial.println(controllerTime);
         setTime(controllerTime);
         timeReceived = true;
      • mikeg291M
        mikeg291M
        mikeg291
        BartE I hope this isn't a test because I just failed . I get the following error when compiling .
        Arduino: 1.6.7 (Windows 7), Board: "Arduino Nano, ATmega328"
        C:\Users\repair\AppData\Local\Temp\arduino_7e89e922452d95ce255568999142a32b\sketch_mar10a.ino: In function 'void setup()':
        sketch_mar10a:43: error: expected primary-expression before ')' token
           if (( millis()- ) {
        sketch_mar10a:43: error: expected ')' before '{' token
           if (( millis()- ) {
        sketch_mar10a:47: error: expected primary-expression before '}' token
        sketch_mar10a:47: error: expected ';' before '}' token
        exit status 1
        enabled in File > Preferences.
             if (( millis()- ) {
             if (( millis()- ) {
          exit status 1
          BartEB
          BartEB
          BartE
          @mikeg291 Mm sorry must have been a copy/past error when posting the sketch i 've made an update you can try again.
          mikeg291M 1 Reply Last reply
          • BartEB BartE
            mikeg291M
            mikeg291M
            mikeg291
            That fixed the issue. It works great. To further enhance the sketch I added an alarm ,however I get an error as shown . Is there a way ; once the sent value of the alarm is set high that it is not changed based on future reading . requiring an acknowledgement or reset .
            #include <Time.h>
            #define CHILD_ID 3
            const int alarmtime = 15;
            int oldValue=-1;
              gw.begin();
              // Serial.begin(9600);
             // Setup the button
                  gw.wait(100);
              debouncer.update();
                 if (value < == alarmtime );
                 gw.send(msg.set(value==HIGH 1));
                 else
                 gw.send(msg.set(value=LOW 0));
                 oldValue = value;
              #include <Time.h>
              #define CHILD_ID 3
              int oldValue=-1;
                gw.begin();
               // Setup the button
                    gw.wait(100);
                debouncer.update();
                   else
                   oldValue = value;
              mikeg291M
              mikeg291M
              mikeg291
              @mikeg291 Arduino: 1.6.7 (Windows 7), Board: "Arduino Nano, ATmega328"
              C:\Users\repair\AppData\Local\Temp\arduino_9fa690567122ca1856b95eff67fbf9b8\pump_cycle_time_2.5.ino: In function 'void loop()':
              pump_cycle_time_2.5:66: error: expected primary-expression before '==' token
              pump_cycle_time_2.5:67: error: expected ')' before numeric constant
              pump_cycle_time_2.5:68: error: expected '}' before 'else'
                else
              pump_cycle_time_2.5:69: error: expected ')' before numeric constant
              C:\Users\repair\AppData\Local\Temp\arduino_9fa690567122ca1856b95eff67fbf9b8\pump_cycle_time_2.5.ino: At global scope:
              pump_cycle_time_2.5:73: error: expected declaration before '}' token
              exit status 1
