  3. Looking for detailed description for hacking a sonoff
45 Posts 12 Posters 53.2k Views 15 Watching
  • EfflonE Efflon
    Here is a working example of using Sonoff with MySensors and the mqtt gateway.
    No need to replace any flash etc...
    alexsh1A
    alexsh1A
    alexsh1
    @Efflon we were talking about a different software whereby more flash was required
    Besides 1mb flash is not much in the esp8566 world
    • dbemowskD
      dbemowskD
      So I have been debating on getting some of these sonoffs. I am assuming the WiFi gateway in the build section of the site is what I would need to build? Is there a better option for using these with my Vera Plus?
      alexsh1A 1 Reply Last reply
      • dbemowskD dbemowsk
        alexsh1A
        alexsh1A
        alexsh1
        @dbemowsk no, the wifi gateway above is to connect nrf24l01+ via wifi. For Sonoff I just reflashed it with easyesp and it works via my normal router with Domoticz. You can have the MQTT setup with Sonoff - thats what @peterscargill did
        dbemowskD 1 Reply Last reply
        • alexsh1A alexsh1
          dbemowskD
          dbemowskD
          #24
          @alexsh1 said in Looking for detailed description for hacking a sonoff:
          Will it work with Vera? I purchased one of these recently from WalMart which also runs on an esp8266 module. I wonder if I can run run the easyesp firmware on that one also?
            alexsh1A
            alexsh1A
            alexsh1
            @dbemowsk Unfortunately, I am not familiar with Vera. Can you send http or json commands from Vera? If yes, it will work. On RPi this is easy to implement.
            Generally speaking you can flash many devices with easyesp if you find how to connect FTDI. I have ESP-01 and ESP-12 running easyesp. Again I am not familiar with the device you posted (the most important question is does it have FTDI or can you identify it by soldering corresponding pins?) and suggest to ask the same question on the easyesp forum.
            • dbemowskD
              dbemowskD
              @alexsh1 I think all the information I need to flash it is in this post that I found on Hackaday. It is a bit different than the sonoffs in that it does not have an unpopulated header port for programming, so you have to solder directly to the module to get it programmed, but what the heck, I'll give it a shot.
              As far a s controlling it from Domoticz, I am assuming that you just created a dummy switch that you used URLs for the on and off commands, correct? I will look into how to do that from Vera. Before I got my Vera (a month ago) I was using Domoticz.
                alexsh1A
                alexsh1A
                alexsh1
                @dbemowsk yes, with Domoticz it is very straight forward, but you have to setup the Sonoff as well.
                Check this out- http://www.letscontrolit.com/wiki/index.php/Tutorial_Domoticz_Switch
                • alexsh1A alexsh1
                  dbemowskD
                  dbemowskD
                  @alexsh1 Excellent information. I may try flashing the module that I have today and see if I can get it to work.
                  • Mark SwiftM
                    Mark SwiftM
                    Mark Swift
                    I have a standard ethernet gateway (NRF) and my controller is the home automation system 'Homey'. I presume I cannot connect these directly to my controller?
                    • Mark SwiftM Mark Swift
                      alexsh1A
                      alexsh1A
                      alexsh1
                      #30
                      @Mark-Swift the problem with home automation in general is a verity of controllers ;) I'm not familiar with Homey, but if it can handle MQTT, Sonoff will work with it.
                      A quick google found this:
                      https://forum.athom.com/discussion/858/published-mosquitto-mqtt-client-app
                      you are participating in this thread ;)
                      PS I have a standard Ethernet GW too. My controller Domoticz can handle JSON/http requests which makes it easy to handle devices like Sonoff connected to my home wifi and not requiring any further GW. Obviously, the setup can be more complicated with MQTT GW and Sonoff MQTT firmware
                        mgaman
                        Please checkout my hack of the Sonoff
                        Apart from turning the relay on/off it offers the following features
                        The device is managed via a set of commands published from any MQTT client. Statuses are published by the device. Subscribe to them on your MQTT client.
                        SSID/Password management - The local SPIFSS file system is used to store an array of WiFI credentials.
                        Extra GPIO On/Off. There is an 'extra' GPIO available (next to the Ground pin on the UART breakout on the Sonoff.
                        https://github.com/mgaman/Sonoff-modified
                        EfflonE 1 Reply Last reply
                        • M mgaman
                          EfflonE
                          EfflonE
                          Efflon
                          @mgaman Interesting code but I have a hard time understanding how you set ssid + passwd , through mqtt with your hard coded wifi user pass?
                          M 1 Reply Last reply
                          • EfflonE Efflon
                            mgaman
                            @Efflon
                            Did you read the PDF file? There I explain the methodology
                            From an MQTT client I publish commands which the Sonoff subscribes to.
                            These commands allow me to add to or delete from an array of SSID/Password pairs held in a file in the ESP8266 SPIFSS file system.
                            On power up I scan the local networks for SSID's and search the local file for matching SSID's.
                            If a match is found, I use it for connecting to the local WiFI network.
                            Does that help?
                            EfflonE ? 2 Replies Last reply
                            • M mgaman
                              @Efflon
                              Does that help?
                              EfflonE
                              EfflonE
                              Efflon
                              @mgaman Didn't read the pdf, but thanks for the explanation. Nice trick to make installation easier.
                              • M mgaman
                                @Efflon
                                Does that help?
                                A Former User
                                Hello @mgaman ,
                                Nice modified version. Because I can't flash it for now, can you tell me wether it's possible to use json commands together with MQTT features?
                                Let me explain : json requests sent from my home automation software are more reliable than MQTT, as they get acknowledgement via the HTTP response, so the sender immediately knows wether the device got the order or not. This is very important to me, as it may be necessary to send orders more than once if the sonoff device is far away from the wifi router. Maybe I'm not clear, your opinion will be appreciated.
                                • ? A Former User
                                  Hello @mgaman ,
                                  dbemowskD
                                  dbemowskD
                                  @Foune What automation software are you using? I have a Vera Plus controller and use a firmware called ESP Easy with my sonoffs. The Vera plugin that I use sends an HTTP request something like this:
                                  http://192.168.1.36/control?cmd=GPIO,12,1
                                  That is to tell the sonoff to use GPIO pin 12 which is my relay, and send it a 1 or ON command. The sonoff sends an immediate JSON response like this:
                                  "log": "GPIO 12 Set to 1",
                                  "plugin": 1,
                                  "pin": 12,
                                  "mode": "output",
                                  "state": 1
                                  This tells me that GPIO pin 12 was successfully set to a 1 state.
                                  The Vera plugin will occasionally check the up status of the node by sending a ping and checking the response. On the Vera controller, the device will either show Online or Offline.
                                    A Former User
                                    Thanks for your detailed answer. If your sonoff device is used in a scenario and the order is not received by it, your vera won't do anything to solve that. I'm looking for a synchronous protocol acknowledgement between the sender and the receiver so that I won't need to code a scheduled task to check whether the command was executed. I use eventghost together with domoticz : domoticz when its plugins are OK, eventghost if I want a fully customizable management, like for my 433 devices which are sometimes lazy to trigger.
                                    • ? A Former User
                                      dbemowskD
                                      dbemowskD
                                      @Foune said in Looking for detailed description for hacking a sonoff:
                                      Correct, but that is coding that needs to be done on the controller side and has little to do with the device. If the device receives the request, it will send the JSON response back.
                                      As I said, that needs to be coded on the controller side. If the sonoff doesn't receive the request, how is it going to send anything back saying that it didn't receive it. In the example I gave above, it shows the JSON acknowledgement that the command was received. The only thing you can do is write into the code that if the response is not received within some specified period of time, then re-send the command.
                                      Your 433 devices as you say are sometimes lazy to trigger. They may not be triggering because they did not properly receive the command sent by the controller.
                                      ? 1 Reply Last reply
                                        A Former User
                                        wrote on last edited by [[global:former-user]]
                                        #39
                                        @dbemowsk All right, so we all agree about the superiority of the json over the MQTT in term of synchronous acknowledgement. This is why I'm asking to mgaman whether I can send commands to the sonoff using json, having in the same time the MQTT features : status report, command, and his new wifi features. I'm sorry if it is a native feature, having read the official doc It seems that chosing one protocol disable the others.
                                        EDIT : I have my answer, I read the source code, there is only the MQTT feature on mgaman's version. I wish I had this wifi MQTT management in addition to the original espeasy code.
                                        • ? A Former User
                                          dbemowskD
                                          dbemowskD
                                          I never said that. I was merely commenting on how my setup works using the ESP Easy firmware which does send a return JSON response. I have never used MQTT, so I don't know if it sends a return response to a command or not. If it does, then I don't see any difference other than how you would process that response on the controller end.
                                          Also, with ESP Easy, I don't as you say "send commands to the sonoff using json". I send an HTTP request and receive the response in JSON format. If @mgaman has a way with MQTT to retrieve the status of a node, e.g. ON or OFF, then on your controller side code, you could send your ON/OFF command, and then right after send a status request command and check the response from that. Depending on the response, you could re-send the ON/OFF command if necessary.
