  3. Domoticz
  4. Dimmer issues
Dimmer issues
1 Posts 1 Posters 1.0k Views 1 Watching
  • C
    C
    chickey
    I'm running a sketch based on the dimmer example on a pro-mini 5v. It works ok except that when switching on and off it ignores the set percentage and jumps to 100%. This also happens when using a blocky script. I wanted to have the light set at 25% after sunset but then when motion is detected from the motion sensor to set the light level to 100% for 1 min and then return to the previous light level. If i have the light off it returns to zero ok but would prefer it to run at 25% level after sunset.
    Anyone had any similar experiences?
     * This sketch provides a Dimmable LED Light along with Temp/Humidity/voltage sensing as well as Motion sensing.
    #define SN "SecurityLED"
    #define SV "1.2"
    #define CHILD_ID_HUM 0
    #define CHILD_ID_TEMP 1
    #define CHILD_ID_VOLTAGE 2
    #define CHILD_ID_PIR 3
    #define HUMIDITY_SENSOR_DIGITAL_PIN 6
    #define DIGITAL_INPUT_SENSOR 3   // The digital input you attached your motion sensor.
    #include <DHT.h>
    #include <SimpleTimer.h>
    // the timer object
    SimpleTimer timer;
    #define LED_PIN 5      // Arduino pin attached to MOSFET Gate pin
    //#define
    int FADE_DELAY=50;  // Delay in ms for each percentage fade up/down (10ms = 1s full-range dim)
    DHT dht;
    float lastTemp;
    boolean metric = true;
    float lastHum;
    float lastVolt;
    int oldBatteryPcnt = 0;
    int analogInput = A0;
    float vout = 0.0;
    float vin = 0.0;
    int value = 0;
    float R1 = 1000000.0;
    float R2 = 454500.0;
    boolean sensordelay;
    static int currentLevel = 0;  // Current dim level...
    MyMessage dimmerMsg(0, V_DIMMER);
    MyMessage lightMsg(0, V_LIGHT);
    MyMessage msgVolt(CHILD_ID_VOLTAGE, V_VOLTAGE);
    MyMessage msg(CHILD_ID_PIR, V_TRIPPED);
     * Dimmable LED initialization method
      Serial.println( SN );
      gw.begin( incomingMessage );
      gw.present( 0, S_DIMMER );
      gw.sendSketchInfo(SN, SV);
      // Pull the gateway's current dim level - restore light level upon sendor node power-up
      //gw.request( 0, V_DIMMER );
      gw.present(CHILD_ID_VOLTAGE, V_VOLTAGE);
      gw.present(CHILD_ID_PIR, S_MOTION);
      pinMode(analogInput, INPUT);
      timer.setInterval(120000,readTempHum);  // Send Temp every 2 mins
      timer.setInterval(300000,measureBattery);  // Send voltage every 5 mins
      fadeToLevel( 0 );
      readTempHum();
      measureBattery();
      sensordelay=0;
    void ResetTripped(){
          sensordelay=0;
          FADE_DELAY=50;
     *  Main processing loop
      gw.process();
      // Read digital motion value
      if (tripped ==1 && sensordelay==0) {
        FADE_DELAY=0;
        Serial.print("Security Sensor state : ");
        Serial.println(tripped);
        gw.send(msg.set(tripped?"1":"0"));  // Send tripped value to gw
        tripped=0;
        sensordelay=1;
        timer.setTimeout(10000,ResetTripped);
      timer.run();
      if (message.type == V_LIGHT || message.type == V_DIMMER) {
        requestedLevel *= ( message.type == V_LIGHT ? 100 : 1 );
        // Clip incoming level to valid range of 0 to 100
        Serial.print( "Changing level to " );
        Serial.print( ", from " );
        Serial.println( currentLevel );
        fadeToLevel( requestedLevel );
        gw.send(lightMsg.set(currentLevel > 0 ? 1 : 0));
        // hek comment: Is this really nessesary?
        gw.send( dimmerMsg.set(currentLevel) );
     *  This method provides a graceful fade up/down effect
    void fadeToLevel( int toLevel ) {
      int delta = ( toLevel - currentLevel ) < 0 ? -1 : 1;
      while ( currentLevel != toLevel ) {
        currentLevel += delta;
        analogWrite( LED_PIN, (int)(currentLevel / 100. * 255) );
        delay( FADE_DELAY );
    void readTempHum() {
      if (isnan(temperature)) {
        lastTemp = temperature;
        if (!metric) {
        Serial.print("T: ");
        Serial.println(temperature);
      if (isnan(humidity)) {
          lastHum = humidity;
          Serial.print("H: ");
          Serial.println(humidity);
    void measureBattery() {
       // read the value at analog input
       value = analogRead(analogInput);
       vout = (value * 5.0) / 1024.0; // see text
       vin = vout / (R2/(R1+R2));
       int batteryPcnt = value / 10;
       #ifdef DEBUG
       Serial.print(vin);
       Serial.println(" V");
       Serial.print(batteryPcnt);
       Serial.println(" %");
         // Power up radio after sleep
         gw.send(msgVolt.set(vin, 1));
         oldBatteryPcnt = batteryPcnt;
