  3. How to use the Selector switch with mysensors
1 Posts 1 Posters 1.1k Views 1 Watching
  • Tore André RosanderT
    Tore André Rosander
    Hello again!
    Is it possible to use the selector switch in domoticz with mysensors?
    I found the IR sender sketch on this forum, the sketch present it selfe as a light switch and i can set what IR codes to be sent when turning the switch on and off.
    Im going to controll my tv and i need to be able to send at least 5-6 different IR codes with my node so using the selector switch would be the best choice i think.
    Heres the code i am going to use
     * Version 1.0 - Henrik EKblad
     * Example sketch showing how to control ir devices
     * An IR LED must be connected to Arduino PWM pin 3.
     * An optional ir receiver can be connected to PWM pin 8.
     * All receied ir signals will be sent to gateway device stored in VAR_1.
     * When binary light on is clicked - sketch will send volume up ir command
     * When binary light off is clicked - sketch will send volume down ir command
     * http://www.mysensors.org/build/ir
    #include <IRLib.h>
    int RECV_PIN = 8;
    #define CHILD_1  3  // childId
    IRsend irsend;
    IRrecv irrecv(RECV_PIN);
    IRdecode decoder;
    //decode_results results;
    unsigned int Buffer[RAWBUF];
    MyMessage msg(CHILD_1, V_VAR1);
      irrecv.enableIRIn(); // Start the ir receiver
      decoder.UseExtnBuf(Buffer);
      gw.begin(incomingMessage);
      gw.sendSketchInfo("IR Sensor", "1.0");
      // Register a sensors to gw. Use binary light for test purposes.
      gw.present(CHILD_1, S_LIGHT);
      gw.process();
      if (irrecv.GetResults(&decoder)) {
        irrecv.resume();
        decoder.decode();
        decoder.DumpResults();
        char buffer[10];
        sprintf(buffer, "%08lx", decoder.value);
        // Send ir result to gw
        gw.send(msg.set(buffer));
      if (message.type==V_LIGHT) {
         int incomingRelayStatus = message.getInt();
         if (incomingRelayStatus == 1) {
          irsend.send(NEC, 0x2AA22DD, 32); // Vol up yamaha ysp-900
         } else {
          irsend.send(NEC, 0x1EE1F807, 32); // Vol down yamaha ysp-900
         // Start receiving ir again...
    // Dumps out the decode_results structure.
    // Call this after IRrecv::decode()
    // void * to work around compiler issue
    //void dump(void *v) {
    //  decode_results *results = (decode_results *)v
    /*void dump(decode_results *results) {
      int count = results->rawlen;
      if (results->decode_type == UNKNOWN) {
        Serial.print("Unknown encoding: ");
      else if (results->decode_type == NEC) {
        Serial.print("Decoded NEC: ");
      else if (results->decode_type == SONY) {
        Serial.print("Decoded SONY: ");
      else if (results->decode_type == RC5) {
        Serial.print("Decoded RC5: ");
      else if (results->decode_type == RC6) {
        Serial.print("Decoded RC6: ");
      else if (results->decode_type == PANASONIC) {
        Serial.print("Decoded PANASONIC - Address: ");
        Serial.print(results->panasonicAddress,HEX);
        Serial.print(" Value: ");
      else if (results->decode_type == JVC) {
         Serial.print("Decoded JVC: ");
      Serial.print(results->value, HEX);
      Serial.print(" (");
      Serial.print(results->bits, DEC);
      Serial.println(" bits)");
      Serial.print("Raw (");
      Serial.print(count, DEC);
      Serial.print("): ");
      for (int i = 0; i < count; i++) {
        if ((i % 2) == 1) {
          Serial.print(results->rawbuf[i]*USECPERTICK, DEC);
        else {
          Serial.print(-(int)results->rawbuf[i]*USECPERTICK, DEC);
        Serial.print(" ");
      Serial.println("");
