  3. how to read other device status with arduino?
5 Posts 2 Posters 1.7k Views 2 Watching
  • L
    L
    leeoz
    wrote on last edited by leeoz
    Hey,
    I'm using veraEdge with arduino gateway and I have a few temperature sensors on my network.
    Ive search the forums and examples but could find a way to do what I want.
    Let say I have arduino1 has a DHT sensor and is a S_TEMP device #11 on my network
    and arduino2 has LCD and is set to be S_HVAC device #12 on my network
    I would like to show on arduino2 LCD the temperature read by arduino1.
    Can u please help?
    BartEB L 2 Replies Last reply
    • L leeoz
      Hey,
      Can u please help?
      BartEB
      BartEB
      BartE
      wrote on last edited by BartE
      @leeoz there are two ways to achieve this
      1. The easy way:
        Each time the temperature is changed in arduino1 and the controller is updated with a
        message like this:
      gw.send(msgTemp.set(((float)temperature / 10.0), 1));
      Also send a message to arduino2 something like this:
      arduino1 code:
      // This can be the sensor ID on arduino2 device #12 (but if you do not check each integer between 1-254 will do)
      #define MYSENSOR_TEMP_LCD  1
      MyMessage msgTempNode2 (MYSENSOR_TEMP_LCD,  V_TEMP);
      void loop ()
          gw.process();
          ... do stuff
         if (oldtemperature  != temperature)
         {     // inform the gateway we have a new temp.
              gw.wait(100); // give the gateway some time to process the 1ste message
             // inform our LCD slave node also about the temp. change
             msgTempNode2.setDestination(12); // This is the node ID on arduino2
             gw.send(msgTempNode2.set(((float)temperature / 10.0), 1),;
             oldtemperature  = temperature;
          ... do some more stuff
      The LCD arduino should handle the incoming TEMP message, arduino2 code:
         if (message.isAck()) {
              Serial.println(F("GW ack"));
         switch (message.type) {
            case V_TEMP:
                Serial.print("New temperature received : ");
                Serial.println(message.getFloat());
                ... do some stuff to update your LCD screen
                break;
      2)The second more complex way is to request the temperature from arduino2 to arduino1
      arduino1 code:
      void loop ()
          gw.process();
          ... do stuff
              // Store the temp.
         ... do more stuff
          if (mGetCommand(message) == C_REQ) {
               MyMessage answerMsg;
               Serial.print("Incoming request for sensor: ");
               Serial.println(message.sensor);
               mSetCommand(answerMsg, C_SET);
               answerMsg.setSensor(message.sensor);
               answerMsg.setDestination(message.sender);
               switch (message.sensor) {
                 case MYSENSOR_TEMP:
                     answerMsg.setType(V_TEMP);
                     gw.send(answerMsg.set((float)(oldtemperature/ 10.0), 1));
                     break;
          } else {
                  ... handle other messages
      arduino2 code:
      void loop ()
        gw.process();
          ... do stuff
         if (time_to_poll_for_temp())
         {     // Request for temperature
               gw.request(MYSENSOR_TEMP, V_TEMP, 12);   // This is the node ID on arduino2
            case V_TEMP:
                break;
      • L leeoz
        Hey,
        Can u please help?
        L
        L
        leeoz
        @BartE
        Tnx for the respose, great.
        Also, if i would like to request value from vera?
        So i use the gw.request(VeraDeviceID, V_TEMP,??)
        Also for solution 2, on the request from arduino2 code,
        MYSENSOR_TEMP is what?
        And why did u type 12? The sensor id is 11...
        I think that in general i dont understad the use of gw.request()
        BartEB 1 Reply Last reply
        • L leeoz
          @BartE
          BartEB
          BartEB
          BartE
          @leeoz said:
          @BartE
          Requesting Vera is not possible, there is no request interface between the GW and Vera
          Just a sensor ID on your arduino1
          True, this should have been 11
          gw,request() sends a message to a different node requesting for data, the requested node has to process this message and respond with a second message. Look at this link at the "Requesting data" paragraph
          L 1 Reply Last reply
          • BartEB BartE
            @leeoz said:
            @BartE
            L
            L
            leeoz
            @BartE
            Ok, I think I got it all. Great tnx a lot
